Allow forward declaration of chibios hal structs Topic is solved
rolanddixon
Been thanked: 2 times
Postby rolanddixon » Tue Jun 22, 2021 10:33 am
Hi All,
This is a fairly simple request and I do not mind submitting a patch for it but I thought I would ask as it could be against a previous design decision.
I will use the SerialConfig as an example. Currently the structure is defined as:
typedef struct
   uint32_t speed;
} SerialConfig;
This has the adverse effect that it cannot be forward declared. Instead the struct could look like the following:
typedef struct _SerialConfig
   uint32_t speed;
} SerialConfig;
This would allow for forward declaration as:
typedef struct _SerialConfig SerialConfig;
As far as I can tell, it would only be the definitions that need updating and the actual source code will remain the same.
This is useful when implementing pimpl and factory type patterns in C++.
Re: Allow forward declaration of chibios hal structs
Postby Giovanni » Tue Jun 22, 2021 11:19 am
This is already done for some (newer) drivers, see hal_sio.h for example. If you are going to propose a patch please follow comment and naming patterns as seen in that file.
rolanddixon
Postby rolanddixon » Wed Jun 23, 2021 9:18 am
Ok, yes. I'll submit one patch at a time per driver if that is OK with you.
Roland
rolanddixon
Postby rolanddixon » Wed Jun 23, 2021 11:15 am
Here is the first hal_serial patch. I have applied it and built all code in "testhal". All the arm based code compiles file. Some of the AVR based code fails but not due to the changes I made. I probably have a mismatch of version of the avr-gcc compiler.
I have zipped the patch along with the build log text file.
I used "git diff --no-prefix" to generate the patch which can be appled with "patch -p0 << /path/to/patch/patch.diff" in the root of the repo.
hal_serial_patch.diff.zip
(8.96 KiB) Downloaded 132 times
rolanddixon
Postby rolanddixon » Wed Jun 23, 2021 3:34 pm
Here are the can, uart and serial patches.
These are the peripherals that I am using at the moment. I will upload the other when I use the peripherals which won't be for a while.
hal_typedef_patches.zip
(3.28 KiB) Downloaded 131 times
Postby Giovanni » Wed Jun 23, 2021 5:43 pm
Thanks, will apply.
rolanddixon
Postby rolanddixon » Tue Oct 26, 2021 2:59 pm
It has been a while but here is a patch for the i2c driver and config typedefs (hal_i2c_config and hal_i2c_driver).
I have tested the builds for the STM32 testhal projects.
i2c_driver_patch.diff.zip
(1.43 KiB) Downloaded 111 times
Postby Giovanni » Tue Oct 26, 2021 6:50 pm
Thanks, will try it tomorrow.
Postby Giovanni » Sun Oct 31, 2021 7:34 am
Thanks, patch applied.
