hal_flash add flash_sector_t flashGetSector(BaseFlash *, flash_offset_t) Topic is solved
faisal
Has thanked: 44 times
Been thanked: 60 times
Postby faisal » Wed Dec 08, 2021 7:40 pm
Being able to map between a flash offset and the sector is useful (similar to the sector to offset func that currently exists).
So, something like this:
faisal
Re: hal_flash add flash_sector_t flashGetSector(BaseFlash *, flash_offset_t)
Postby faisal » Wed Dec 08, 2021 7:57 pm
Here's an implementation (untested).
 * @brief   Returns the sector of an offset.
 * @param[in] devp      pointer to a @p BaseFlash object
 * @param[in] offset    flash offset
 * @return the sector of the offset
flash_sector_t flashGetOffsetSector(BaseFlash *devp,
                                    flash_offset_t offset)
  flash_sector_t sector;
  const flash_descriptor_t *descriptor = flashGetDescriptor(devp);
  osalDbgAssert(offset > (descriptor->address + descriptor->size),
          "invalid offset");
  if (descriptor->sectors != NULL) {
      flash_offset_t sector_start;
      flash_offset_t sector_end;
      for (int i = 0; i < descriptor->sectors_count; i++)
          sector_start = descriptor->sectors[i].offset;
          sector_end = sector_start + descriptor->sectors[i].size - 1;
          if ((offset >= sector_start) && (offset <= sector_end))
              return sector;
      osalDbgAssert(TRUE, "invalid offset");
  else {
      sector = (descriptor->address + offset)/descriptor->sectors_size;
  return sector;
faisal
Postby faisal » Thu Dec 09, 2021 5:21 am
A small update:
  osalDbgAssert(offset > ((flash_offset_t)descriptor->address + descriptor->size),
          "invalid offset");
      for (flash_sector_t i = 0; i < descriptor->sectors_count; i++)
               sector = i;
               break;
  else {
      sector = ((flash_offset_t)descriptor->address + offset)/descriptor->sectors_size;
  return sector;
Postby Giovanni » Thu Dec 09, 2021 10:05 am
Is it tested now?
faisal
Postby faisal » Thu Dec 09, 2021 7:44 pm
Now it is tested (fixed a few bugs) but only the descriptor->sectors == NULL path (uniform sector sizes). I also added some more helpful functions that are commonly needed when interacting with hal-flash.
 * @brief   Get absolute address from offset
 * @param[in] ip                    pointer to a @p BaseFlash or derived class
 * @param[in] offset                offset
 * @return                          A pointer to the offset
 * @api
void * flashGetOffsetAddress(BaseFlash *devp, flash_offset_t offset)
    osalDbgCheck(devp != NULL);
    osalDbgAssert(offset < descriptor->size, "invalid offset");
    return (void *)((flash_offset_t)descriptor->address + offset);
 * @brief   Get offset from absolute address
 * @param[in] addr                  pointer
 * @return                          offset
 * @api
flash_offset_t flashGetAddressOffset(BaseFlash *devp, void * addr)
    osalDbgAssert(((flash_offset_t)addr >=
                (flash_offset_t)descriptor->address)
            && ((flash_offset_t)addr < (flash_offset_t)descriptor->address +
                descriptor->size),
            "invalid address");
    return (flash_offset_t)addr - (flash_offset_t)descriptor->address;
               sector = i;
               break;
      osalDbgAssert(FALSE, "invalid offset");
  else {
      sector = offset/descriptor->sectors_size;
  return sector;
faisal
Postby faisal » Thu Dec 30, 2021 4:57 am
Got an F769 Disco board, and finally was able to get better test coverage with a device with non-uniform sector sizes. Of_course it uncovered some bugs :). Updates below:
 * @api
 * @return                          offset
 * @api
            && ((flash_offset_t)addr <= (flash_offset_t)descriptor->address +
                descriptor->size),
            "invalid address");
          sector_end = sector_start + descriptor->sectors[i].size - 1U;
               sector = i;
               return sector;
  else {
      return sector;
  return 0;
