Improvement for serial_nor complex lib to support dummy cmd and 4-bytes address for normal SPI Topic is solved
choowf
Has thanked: 3 times
Postby choowf » Thu Mar 17, 2022 7:10 am
One of our serial nor flash required address to be 4-bytes and some commands receive need to have dummy cycles in normal SPI mode.
Suggest bus_cmd_addr_dummy_receive() and bus_cmd_dummy_receive() to be enabled for normal SPI mode as well and add SNOR_SPI_4BYTES_ADDRESS flag to tell the driver it's using 4 bytes addressing.
diff --git a/ChibiOS_20.x.x/os/hal/lib/complex/serial_nor/hal_serial_nor.h b/ChibiOS_20.x.x/os/hal/lib/complex/serial_nor/hal_serial_nor.h
index cca029775..b5041b668 100644
--- a/ChibiOS_20.x.x/os/hal/lib/complex/serial_nor/hal_serial_nor.h
+++ b/ChibiOS_20.x.x/os/hal/lib/complex/serial_nor/hal_serial_nor.h
@@ -65,6 +65,15 @@
 #if !defined(SNOR_SHARED_BUS) || defined(__DOXYGEN__)
 #define SNOR_SHARED_BUS                     TRUE
+ * @brief   SPI 4-bytes address switch
+ * @details If set to @p TRUE the device will use 4-bytes address
+ *          in SPI bus, only relevant if SPI is used
+#if !defined(SNOR_SPI_4BYTES_ADDRESS) || defined(__DOXYGEN__)
+#define SNOR_SPI_4BYTES_ADDRESS             FALSE
+#endif
@@ -156,8 +165,10 @@ typedef struct {
 #ifdef __cplusplus
 extern "C" {
+#if SNOR_SHARED_BUS == TRUE
   void bus_acquire(BUSDriver *busp, const BUSConfig *config);
   void bus_release(BUSDriver *busp);
+#endif
   void bus_cmd(BUSDriver *busp, uint32_t cmd);
   void bus_cmd_send(BUSDriver *busp, uint32_t cmd, size_t n, const uint8_t *p);
   void bus_cmd_receive(BUSDriver *busp,
@@ -175,7 +186,6 @@ extern "C" {
                             flash_offset_t offset,
                             size_t n,
                             uint8_t *p);
-#if (SNOR_BUS_DRIVER == SNOR_BUS_DRIVER_WSPI) || defined(__DOXYGEN__)
   void bus_cmd_dummy_receive(BUSDriver *busp,
                              uint32_t cmd,
                              uint32_t dummy,
@@ -187,7 +197,6 @@ extern "C" {
                                   uint32_t dummy,
                                   size_t n,
                                   uint8_t *p);
-#endif
   void snorObjectInit(SNORDriver *devp);
   void snorStart(SNORDriver *devp, const SNORConfig *config);
   void snorStop(SNORDriver *devp);
diff --git a/ChibiOS_20.x.x/os/hal/lib/complex/serial_nor/hal_serial_nor.c b/ChibiOS_20.x.x/os/hal/lib/complex/serial_nor/hal_serial_nor.c
index 82d90835e..d369c59cf 100644
--- a/ChibiOS_20.x.x/os/hal/lib/complex/serial_nor/hal_serial_nor.c
+++ b/ChibiOS_20.x.x/os/hal/lib/complex/serial_nor/hal_serial_nor.c
@@ -169,9 +169,6 @@ static flash_error_t snor_start_erase_all(void *instance) {
   /* Actual erase implementation.*/
   err = snor_device_start_erase_all(devp);
-  /* Ready state again.*/
-  devp->state = FLASH_READY;
   /* Bus released.*/
   bus_release(devp->config->busp);
@@ -483,14 +480,22 @@ void bus_cmd_addr(BUSDriver *busp, uint32_t cmd, flash_offset_t offset) {
   mode.dummy = 0U;
   wspiCommand(busp, &mode);
 #else
-  uint8_t buf[4];
+  uint8_t buf[5];
   spiSelect(busp);
   buf[0] = cmd;
+#if (SNOR_SPI_4BYTES_ADDRESS == TRUE)
+  buf[1] = (uint8_t)(offset >> 24);
+  buf[2] = (uint8_t)(offset >> 16);
+  buf[3] = (uint8_t)(offset >> 8);
+  buf[4] = (uint8_t)(offset >> 0);
+  spiSend(busp, 5, buf);
+#else
   buf[1] = (uint8_t)(offset >> 16);
   buf[2] = (uint8_t)(offset >> 8);
   buf[3] = (uint8_t)(offset >> 0);
   spiSend(busp, 4, buf);
+#endif
   spiUnselect(busp);
@@ -522,14 +527,22 @@ void bus_cmd_addr_send(BUSDriver *busp,
   mode.dummy = 0U;
   wspiSend(busp, &mode, n, p);
 #else
-  uint8_t buf[4];
+  uint8_t buf[5];
   spiSelect(busp);
   buf[0] = cmd;
+#else
+#endif
   spiSend(busp, n, p);
   spiUnselect(busp);
@@ -562,20 +575,27 @@ void bus_cmd_addr_receive(BUSDriver *busp,
   mode.dummy = 0U;
   wspiReceive(busp, &mode, n, p);
 #else
-  uint8_t buf[4];
+  uint8_t buf[5];
   spiSelect(busp);
   buf[0] = cmd;
+#else
+#endif
   spiReceive(busp, n, p);
   spiUnselect(busp);
  * @brief   Sends a command followed by dummy cycles and a
  *          data receive phase.
@@ -593,6 +613,7 @@ void bus_cmd_dummy_receive(BUSDriver *busp,
                            uint32_t dummy,
                            size_t n,
                            uint8_t *p) {
+#if SNOR_BUS_DRIVER == SNOR_BUS_DRIVER_WSPI
   wspi_command_t mode;
   mode.cmd   = cmd;
@@ -601,6 +622,16 @@ void bus_cmd_dummy_receive(BUSDriver *busp,
   mode.alt   = 0U;
   mode.dummy = dummy;
+#else
+  osalDbgAssert(dummy <= 15, "maximum 15 dummy bytes");
+  uint8_t buf[16];
+  spiSelect(busp);
+  buf[0] = cmd;
+  spiSend(busp, dummy+1, buf);
+  spiReceive(busp, n, p);
+  spiUnselect(busp);
+#endif
@@ -622,6 +653,7 @@ void bus_cmd_addr_dummy_receive(BUSDriver *busp,
                                 uint32_t dummy,
                                 size_t n,
                                 uint8_t *p) {
   mode.cmd   = cmd;
@@ -630,8 +662,28 @@ void bus_cmd_addr_dummy_receive(BUSDriver *busp,
   mode.alt   = 0U;
   mode.dummy = dummy;
+#else
+  uint8_t buf[20];
+  spiSelect(busp);
+  buf[0] = cmd;
+  spiSend(busp, dummy+5, buf);
+#else
+  buf[1] = (uint8_t)(offset >> 16);
+  buf[2] = (uint8_t)(offset >> 8);
+  buf[3] = (uint8_t)(offset >> 0);
+  spiSend(busp, dummy+4, buf);
+#endif
+#endif
-#endif /* SNOR_BUS_DRIVER == SNOR_BUS_DRIVER_WSPI */
  * @brief   Initializes an instance.
Re: Improvement for serial_nor complex lib to support dummy cmd and 4-bytes address for normal SPI
Postby Giovanni » Fri Apr 15, 2022 11:07 am
Added support for 4 bytes address but had to do some changes, "dummy" is meant to be expressed in cycles not in bytes, the assertions checks that the passed value is a multiple of 8. I also avoided the use of that 16 bytes buffer and the number of dummies is now unlimited.
I don't have HW to test this, I would appreciate if you could confirm that the change is functional.
choowf
Postby choowf » Fri Apr 22, 2022 8:27 am
Giovanni wrote:Hi,
Some corrections on the code:
Missing cmd statement
#if (SNOR_BUS_DRIVER == SNOR_BUS_DRIVER_SPI) || defined(__DOXYGEN__)
void snor_spi_cmd_addr(BUSDriver *busp, uint32_t cmd, flash_offset_t offset) {
uint8_t buf[5];
buf[0] = cmd;
#else
uint8_t buf[4];
buf[0] = cmd;
Don't do spiIgnore if dummy = 0, in both bus_cmd_dummy_receive() and bus_cmd_addr_dummy_receive()
uint32_t cmd,
uint32_t dummy,
size_t n,
uint8_t *p) {
mode.cmd = cmd;
mode.cfg = SNOR_WSPI_CFG_CMD_DATA;
mode.addr = 0U;
mode.alt = 0U;
mode.dummy = dummy;
#else
uint8_t buf[1];
osalDbgAssert((dummy & 7) == 0U, "multiple of 8 dummy cycles");
spiSelect(busp);
buf[0] = cmd;
spiSend(busp, 1, buf);
if(dummy != 0)
spiIgnore(busp, dummy / 8U);
spiUnselect(busp);
Also I added below into snorStart(), potential bug if SNOR_SHARED_BUS = FALSE
/* Bus acquisition.*/
bus_acquire(devp->config->busp, devp->config->buscfg);
#if ((SNOR_BUS_DRIVER == SNOR_BUS_DRIVER_WSPI) && \
(SNOR_SHARED_BUS == FALSE)) || defined(__DOXYGEN__)
wspiStart(devp->config->busp, devp->config->buscfg);
#if (SNOR_BUS_DRIVER == SNOR_BUS_DRIVER_SPI) && \
/* Device identification and initialization.*/
snor_device_init(devp);
Tested with my hardware and it works. Please check if above make sense.
Thanks!
Postby Giovanni » Fri Apr 22, 2022 10:12 am
Fixes committed, thanks a lot.
choowf
Postby choowf » Sun Apr 24, 2022 7:58 am
I looked at your latest fix, the "if dummy != 0" condition should cover the spiIgnore instead of spiReceive.
Besides this, we also need to do the same condition for function bus_cmd_addr_dummy_receive()
Postby Giovanni » Sun Apr 24, 2022 8:09 am
Should be fixed now.
