I2C Fallback - add support for non Open-drain boards
Posted: Mon May 29, 2023 9:28 pm
by dexter93
Not all supported boards have Open-drain as an option for GPIO configuration, which is an assumption the I2C fallback driver makes.
Small patch to enable support for basic input/output I2C bitbang. Tested up to ~350kHz
furthermore, some delays have been added here to make sure the driver is following the I2C specifications
diff --git a/os/hal/lib/fallback/I2C/hal_i2c_lld.c b/os/hal/lib/fallback/I2C/hal_i2c_lld.c
index 205fa19d47..f01acce89a 100644
--- a/os/hal/lib/fallback/I2C/hal_i2c_lld.c
+++ b/os/hal/lib/fallback/I2C/hal_i2c_lld.c
@@ -29,13 +29,23 @@
 /* Driver local definitions.                                                 */
-#define CHECK_ERROR(msg)                                                    \
-  if ((msg) < (msg_t)0) {                                                   \
-    palSetLine(i2cp->config->sda);                                          \
-    palSetLine(i2cp->config->scl);                                          \
-    return MSG_TIMEOUT;                                                     \
+#if (SW_I2C_USE_OPENDRAIN == TRUE) || defined(__DOXYGEN__)
+#  define CHECK_ERROR(msg)                                                    \
+    if ((msg) < (msg_t)0) {                                                   \
+      palSetLine(i2cp->config->sda);                                          \
+      palSetLine(i2cp->config->scl);                                          \
+      return MSG_TIMEOUT;                                                     \
+#else
+      palSetLineMode(i2cp->config->scl, PAL_MODE_OUTPUT_PUSHPULL);            \
+      palSetLineMode(i2cp->config->sda, PAL_MODE_OUTPUT_PUSHPULL);            \
+#endif
 /* Driver constants.                                                         */
@@ -85,12 +95,17 @@ static inline void i2c_delay(I2CDriver *i2cp) {
 static inline msg_t i2c_check_arbitration(I2CDriver *i2cp) {
+#if (SW_I2C_USE_OPENDRAIN == FALSE)
+  palSetLineMode(i2cp->config->sda, PAL_MODE_INPUT);
+#endif
+  i2c_delay(i2cp);
   if (palReadLine(i2cp->config->sda) == PAL_LOW) {
     i2cp->errors |= I2C_ARBITRATION_LOST;
     return MSG_RESET;
+#endif
   return MSG_OK;
@@ -106,6 +121,10 @@ static inline msg_t i2c_check_timeout(I2CDriver *i2cp) {
 static msg_t i2c_wait_clock(I2CDriver *i2cp) {
+  palSetLineMode(i2cp->config->scl, PAL_MODE_INPUT);
+#endif
+  i2c_delay(i2cp);
   while (palReadLine(i2cp->config->scl) == PAL_LOW) {
     if ((i2cp->start != i2cp->end) &&
@@ -114,7 +133,9 @@ static msg_t i2c_wait_clock(I2CDriver *i2cp) {
     i2c_delay(i2cp);
+#endif
   return MSG_OK;
@@ -126,6 +147,7 @@ static inline msg_t i2c_write_start(I2CDriver *i2cp) {
   palClearLine(i2cp->config->sda);
   i2c_delay(i2cp);
   palClearLine(i2cp->config->scl);
+  i2c_delay(i2cp);
   return MSG_OK;
@@ -169,6 +191,7 @@ static msg_t i2c_write_stop(I2CDriver *i2cp) {
 static msg_t i2c_write_bit(I2CDriver *i2cp, unsigned bit) {
   palWriteLine(i2cp->config->sda, bit);
   i2c_delay(i2cp);
   i2c_delay(i2cp);
@@ -182,14 +205,16 @@ static msg_t i2c_write_bit(I2CDriver *i2cp, unsigned bit) {
+  i2c_delay(i2cp);
   return MSG_OK;
 static msg_t i2c_read_bit(I2CDriver *i2cp) {
   msg_t bit;
+#endif
   i2c_delay(i2cp);
@@ -197,22 +222,33 @@ static msg_t i2c_read_bit(I2CDriver *i2cp) {
   CHECK_ERROR(i2c_wait_clock(i2cp));
   i2c_delay(i2cp);
   bit = palReadLine(i2cp->config->sda);
+#endif
+  i2c_delay(i2cp);
   return bit;
 static msg_t i2c_write_byte(I2CDriver *i2cp, uint8_t byte) {
   msg_t msg;
-  uint8_t mask;
   CHECK_ERROR(i2c_check_timeout(i2cp));
+  uint8_t mask;
   for (mask = 0x80U; mask > 0U; mask >>= 1U) {
     CHECK_ERROR(i2c_write_bit(i2cp, (byte & mask) != 0));
+#else
+  for(uint8_t i = 0; i < 8; i++) {
+    unsigned bit = ((0x80U >> i) & byte);
+    CHECK_ERROR(i2c_write_bit(i2cp, bit));
+#endif
   msg = i2c_read_bit(i2cp);
   CHECK_ERROR(msg);
diff --git a/os/hal/lib/fallback/I2C/hal_i2c_lld.h b/os/hal/lib/fallback/I2C/hal_i2c_lld.h
index c0a8d37baf..f2c43ac2b8 100644
--- a/os/hal/lib/fallback/I2C/hal_i2c_lld.h
+++ b/os/hal/lib/fallback/I2C/hal_i2c_lld.h
@@ -39,6 +39,16 @@
  * @name    Configuration options
+ * @brief   Use Open-drain configuration.
+ * @details If set to @p TRUE then the driver expects the SDA and SCL
+ *          pins to be in open-drain configuration else it handles
+ *          I2C functionality by switching input and output state.
+#if !defined(SW_I2C_USE_OPENDRAIN) || defined(__DOXYGEN__)
+#define SW_I2C_USE_OPENDRAIN                FALSE
+#endif
  * @brief   Use OSAL delays.
  * @details If set to @p TRUE then delays are implemented using the
