[NO REPLY] Base types and pointers (rev #3, 2018-1-15)
A place of insane ideas, nothing to see here.
Has thanked: 1135 times
Been thanked: 947 times
Postby Giovanni » Sun Dec 10, 2017 5:50 pm
Constants
  • Binary constants are allowed using the 0b prefix.
  • The c and s suffixes are added for char and short constants. Can be used with u.
Types checking
  • Strong checking, mixing types always gives errors (not warnings).
  • No integer promotion mechanism, mixing types is forbidden without explicit casts.
    • Sign-extension and truncation is only done through casts.
  • Casts are mandatory for constants assigned to derived types.
  • Constant suffixes or casts are mandatory for everything but "int".
Bool type
  • Bool is a base type not compatible with integer types without an explicit cast, it can be assigned with true/false or the result of comparison operators.
  • The words true and false are actual keywords not macros.
  • Comparison operators explicitly return a bool.
  • Conditional statements if, do, while, for ( ; condition; ) explicitly require a bool.
Pointers
There are several restrictions:
  • Assigning pointers to different pointer types is an error.
  • Comparing pointers with different pointer types is an error.
  • A cast between pointers is possible only if the two pointers are "related", meaning that one pointer points to an ancestor type of the other type.
  • The void type is considered ancestor to all types. It is always possible to cast from/to a pointer to void.
  • Constants can be assigned to pointers using casts but only if the constant is compatible with the pointed type alignment constraints.
  • The void type has no alignment constraints. If you NEED to create an unaligned pointer then cast it first to void* then to the final pointer type.
Return to “Safer C”
Users browsing this forum: No registered users and 42 guests
