[NO REPLY] State machines as a construct
A place of insane ideas, nothing to see here.
Has thanked: 1074 times
Been thanked: 921 times
Postby Giovanni » Wed Dec 13, 2017 1:45 pm
One common problems in embedded programming is to correctly implement state machines, often with the added complexity of interactions with the asynchronous world (IRQ, tasks).
Here is the idea, define a specific construct for implementing state machines of any kind, directly in the language. Consider an extension to the structures definition:
struct sm {
  state enum st {STOPPED = 0, STARTED, ERROR};
  int i;
  char *message;
  /* other fields */
  /* this is the new part, attaching actions to variables transitions */
  transition st: STOPPED => STARTED;
    activate_motor();
    if (activation_failure())
      st = ERROR;
  transition st: STARTED => STOPPED;
    stop_motor();
    if (brake_failure())
      st = ERROR;
  transition st: @@ => ERROR;
     report_error();
  default:
    invalid_transition();
sm motor1 = {STOPPED, ...};
sm = STARTED; /* starting motor */
sleep(100);
sm = STOPPED; /* stopping motor */
Two new keywords would be required: state and transition. @@ means "any state", => defines a transition. The typical use case is like in ChibiOS HAL drivers, each driver has a state machine, multiple peripherals of the same driver has a separate state machine instance. The XXXDriver structures in HAL could be implemented using this construct.
Syntax is invented and probably could be better or more elegant.
Return to “Safer C”
