STM32F437I-EVAL-LWIP
INCAS_Xtick
Postby INCAS_Xtick » Fri Jul 19, 2013 3:29 pm
I'm working on porting ChibiOS to an STM32F437I-EVAL. I'm looking to use the Ethernet port, the USB-HS port and probably the SD card.
So far I successfully enabled the ethernet port and the LEDS.
Here's my code. It's pretty messy and not optimized at all since a lot of unused options/code are still present. I planned to remove them as soon as I'm sure that they're not usefull.
If you want to get it running, you'll have to solder a wire between the TP15 test point and the JP5 pin 2. This is because I don't want to use an external crystal to provide the necessary 50MHz clock to use the RMII mode for ethernet. And i can't use the MCO1 neither because I will use it for the USB-HS. So since MCO2 is not wire to the PHY on the board you have to do it manually. Also I commented the PWR check on the hal_lld.c (line ~145) because I can't seem to get it working.
I'm currently working on having the USB-HS working but I have not clue how and when it will be done.
I'm still figuring out where the choice between USB-FS (which seems to be used in every example I've seen so far) and USB-HS is made... Any help is welcome!!
Have fun!
Xtick.
STM32F437I-EVAL-LWIP.rar
(4.17 MiB) Downloaded 131 times
Has thanked: 888 times
Been thanked: 768 times
Re: STM32F437I-EVAL-LWIP
Postby Giovanni » Fri Jul 19, 2013 5:23 pm
Thanks for the code. You can enable FS, HS or both peripherals in mcuconf.h, then you see them as USBD1 and/or USBD2. This is true in general for all peripherals.
Return to “User Projects”
