[DONE] Starting ChibiOS on STM32F107 with Keil
Maxxie
Re: [TODO] Starting ChibiOS on STM32F107 with Keil
Post by Maxxie »
Giovanni wrote:The frame size is set to 1522 which is the maximum. Probably it is because the IPv4 header is up to 20 bytes long.
Frame length is 1514 max. Look for this packet:
I mean, it is set to 1522 in the driver.
#define STM32_MAC_BUFFERS_SIZE 1522
Maxxie
Post by Maxxie »
It seems Ethernet MTU is 1500 max. in my system.
Maxxie
Post by Maxxie »
Giovanni, can you please explain IRAM2 definition in compiler options? What address is it? Why is it only 1 byte long?
Keil IRAM2.jpg (78.15 KiB) Viewed 3950 times
Since the free Keil compiler does not allow proper scatter files that dummy RAM section is used to calculate the end of the memory heap. In the linker tab you can see how it is used.
It is one byte long to make evident it is not an error but intentional, only the start address is used.
