No rule to make target crt0
idcavili
Post by idcavili »
When I try to compile in Eclipse, I get "no rule to make target crt0.c." I have placed linked folders to the os and board folders but it apparently doesn't find them. Are there some more environment variables to set?
Re: No rule to make target crt0
There are no particular env vars to set except PATH.
It is most likely a problem with the toolchain, could you try ChibiStudio? it is a preconfigured Eclipse environment with all the latest components.
idcavili
Post by idcavili »
Chibistudio doesn't seem to download. Did it take forever for you as well?
It is on the sourceforge page, you can also select another mirror if I remember well. Choose one closer to you.
idcavili
Post by idcavili »
I got chibistudio and it still has this message. Perhaps I should start a new project.
Does this happen using one of the existing projects or a new project you created?
idcavili
Post by idcavili »
Existing.
Are you launching ChibiStudio using the provided link/batch or by launching directly Eclipse.exe? you should use the link, it sets required env variables.
idcavili
Post by idcavili »
Which project type should I select when starting a new one? I tried chibios and makefile project and neither of them come with the files pre loaded.
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Post by RoccoMarco »
Can I ask what platform are you using?
