Zip file contain LPC11xx I2C, PWM, EXT driver and test HAL for PWM and EXT.
Limitations:
I2C Driver - only support master
PWM Driver - support max 2 channels for each timer
Drivers tested on LPC1114 custom board.
- LPC11xx_I2C_PWM_EXT_driver.zip
- (38.66 KiB) Downloaded 1174 times
Re: LPC11xx I2C, PWM, EXT driver
Marcin,
Thanks for that, I'll see about merging them to trunk.
mike
mike
Finally added I2C, PWM and EXT drivers to LPC11xx port.
Also added board definition for LPC Xpresso LPC11C24. PWM & EXT drivers tested against this board.
Marcin,
I re-targetted the hal tests to the LPC11C24 Xpresso instead of your custom board.
mike
Marcin,
mike
Ok, but some comments in testhal examples are wrong. I've forgotten to change them.
Great progress. Here's what I ended up using with the CANopen ROm drivers:
MEMORY
flash : org = 0x00000000, len = 32k
/* RAM: 0x10000050..B8 reserved for CANopen ROM use, see UM10398, p.313 */
ram : org = 0x10000100, len = 8k - 256
