Few updates:
PIC32: PWM LLD
the PIC HW is a "bit" odd in terms that it does not generate interrupt on compare in PWM mode, so no such events supported
the other mode of Output Compare module is promising but I can't get expected output so I'll try to find an oscilloscope to continue with integration
PWM HAL: extend API with pwmChannelChangeWidth
MIPS32 port
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Re: MIPS32 port
Good job.
It is maturing so fast, after the 2.6.0 release we should discuss the details about merging with mainline.
Re: MIPS32 port
Thanks guys.
I believe only few remaining things are there:
- ethernet(have some doubts whether anyone needs that)
- flash write(that's useful if there will be a chibi-boot at some point)
Re: MIPS32 port
what was the reason of swapping interrupt and data endpoints in your last change to usbcfg.c ?
I could not make the serial-over-USB work until I restored the definitions to match USB spec.
Re: MIPS32 port
thanks for pointing on that. In fact that was a typo. I have already submitted correction.
Re: MIPS32 port
Great, thanks. I am not very familiar with USB so I thought that it may be done in purpose which I don't understand.
Re: MIPS32 port
Some preliminary mac_lld code is available from http://code.google.com/p/ecos-pic32/dow ... p&can=2&q=
It currently runs on ESK (Ethernet Startup Kit) board.
Users browsing this forum: No registered users and 14 guests
