Hi, I just upgraded my previous project from Chibi 2.5 to 2.6.1.
I upgraded the board files also, with the new definition for using SPI2 peripherals on PB12-13-14-15; but when I run the demo, SPI2 does not work.
If I do pin configuration in demo software (main.c) SPI2 works fine, so question is: why board file configuration is not working?
thanks.
-g
STM32F4 Initialization
Re: STM32F4 Initialization
Which board? all the board files I see have those pins undefined or assigned to OTG HS.
Oh, well... it's a custom made board
It's a design of mine
which runs ChibiOS successfull since release 2.4.2
-g
PS. this is part of my board.h, which defines SPI2 pins:
-g
#define VAL_GPIOB_MODER (PIN_MODE_OUTPUT(GPIOB_LED2) | \
PIN_MODE_OUTPUT(GPIOB_LED1) | \
PIN_MODE_INPUT(GPIOB_PWR_IND) | \
PIN_MODE_ALTERNATE(GPIOB_I2S3_SCLK) | \
PIN_MODE_OUTPUT(GPIOB_OSC_EN) | \
PIN_MODE_INPUT(GPIOB_I2S3_SDAT) | \
PIN_MODE_ALTERNATE(GPIOB_I2C1_SCL) | \
PIN_MODE_ALTERNATE(GPIOB_I2C1_SDA) | \
PIN_MODE_ALTERNATE(GPIOB_SDIO_D4) | \
PIN_MODE_ALTERNATE(GPIOB_SDIO_D5) | \
PIN_MODE_OUTPUT(GPIOB_EMMC_RST) | \
PIN_MODE_INPUT(GPIOB_SPI2_INT) | \
PIN_MODE_ALTERNATE(GPIOB_SPI2_NSS) | \
PIN_MODE_ALTERNATE(GPIOB_SPI2_SCK) | \
PIN_MODE_ALTERNATE(GPIOB_SPI2_MISO) | \
PIN_MODE_ALTERNATE(GPIOB_SPI2_MOSI))
#define VAL_GPIOB_OTYPER (PIN_OTYPE_PUSHPULL(GPIOB_LED2) | \
PIN_OTYPE_PUSHPULL(GPIOB_LED1) | \
PIN_OTYPE_PUSHPULL(GPIOB_PWR_IND) | \
PIN_OTYPE_PUSHPULL(GPIOB_I2S3_SCLK) | \
PIN_OTYPE_PUSHPULL(GPIOB_OSC_EN) | \
PIN_OTYPE_PUSHPULL(GPIOB_I2S3_SDAT) | \
PIN_OTYPE_OPENDRAIN(GPIOB_I2C1_SCL) | \
PIN_OTYPE_OPENDRAIN(GPIOB_I2C1_SDA) | \
PIN_OTYPE_PUSHPULL(GPIOB_SDIO_D4) | \
PIN_OTYPE_PUSHPULL(GPIOB_SDIO_D5) | \
PIN_OTYPE_PUSHPULL(GPIOB_EMMC_RST) | \
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_INT) | \
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_NSS) | \
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_SCK) | \
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_MISO) | \
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_MOSI))
#define VAL_GPIOB_OSPEEDR (PIN_OSPEED_100M(GPIOB_LED2) | \
PIN_OSPEED_100M(GPIOB_LED1) | \
PIN_OSPEED_2M(GPIOB_PWR_IND) | \
PIN_OSPEED_100M(GPIOB_I2S3_SCLK) | \
PIN_OSPEED_100M(GPIOB_OSC_EN) | \
PIN_OSPEED_100M(GPIOB_I2S3_SDAT) | \
PIN_OSPEED_100M(GPIOB_I2C1_SCL) | \
PIN_OSPEED_100M(GPIOB_I2C1_SDA) | \
PIN_OSPEED_100M(GPIOB_SDIO_D4) | \
PIN_OSPEED_100M(GPIOB_SDIO_D5) | \
PIN_OSPEED_100M(GPIOB_EMMC_RST) | \
PIN_OSPEED_2M(GPIOB_SPI2_INT) | \
PIN_OSPEED_100M(GPIOB_SPI2_NSS) | \
PIN_OSPEED_100M(GPIOB_SPI2_SCK) | \
PIN_OSPEED_100M(GPIOB_SPI2_MISO) | \
PIN_OSPEED_100M(GPIOB_SPI2_MOSI))
#define VAL_GPIOB_PUPDR (PIN_PUPDR_FLOATING(GPIOB_LED2) | \
PIN_PUPDR_FLOATING(GPIOB_LED1) | \
PIN_PUPDR_PULLUP(GPIOB_PWR_IND) | \
PIN_PUPDR_FLOATING(GPIOB_I2S3_SCLK) | \
PIN_PUPDR_FLOATING(GPIOB_OSC_EN) | \
PIN_PUPDR_FLOATING(GPIOB_I2S3_SDAT) | \
PIN_PUPDR_FLOATING(GPIOB_I2C1_SCL) | \
PIN_PUPDR_FLOATING(GPIOB_I2C1_SDA) | \
PIN_PUPDR_FLOATING(GPIOB_SDIO_D4) | \
PIN_PUPDR_FLOATING(GPIOB_SDIO_D5) | \
PIN_PUPDR_FLOATING(GPIOB_EMMC_RST) | \
PIN_PUPDR_PULLUP(GPIOB_SPI2_INT) | \
PIN_PUPDR_FLOATING(GPIOB_SPI2_NSS) | \
PIN_PUPDR_FLOATING(GPIOB_SPI2_SCK) | \
PIN_PUPDR_FLOATING(GPIOB_SPI2_MISO) | \
PIN_PUPDR_FLOATING(GPIOB_SPI2_MOSI))
#define VAL_GPIOB_ODR (PIN_ODR_HIGH(GPIOB_LED2) | \
PIN_ODR_HIGH(GPIOB_LED1) | \
PIN_ODR_HIGH(GPIOB_PWR_IND) | \
PIN_ODR_HIGH(GPIOB_I2S3_SCLK) | \
PIN_ODR_HIGH(GPIOB_OSC_EN) | \
PIN_ODR_HIGH(GPIOB_I2S3_SDAT) | \
PIN_ODR_HIGH(GPIOB_I2C1_SCL) | \
PIN_ODR_HIGH(GPIOB_I2C1_SDA) | \
PIN_ODR_HIGH(GPIOB_SDIO_D4) | \
PIN_ODR_HIGH(GPIOB_SDIO_D5) | \
PIN_ODR_HIGH(GPIOB_EMMC_RST) | \
PIN_ODR_HIGH(GPIOB_SPI2_INT) | \
PIN_ODR_HIGH(GPIOB_SPI2_NSS) | \
PIN_ODR_HIGH(GPIOB_SPI2_SCK) | \
PIN_ODR_HIGH(GPIOB_SPI2_MISO) | \
PIN_ODR_HIGH(GPIOB_SPI2_MOSI))
#define VAL_GPIOB_AFRL (PIN_AFIO_AF(GPIOB_LED2, 0) | \
PIN_AFIO_AF(GPIOB_LED1, 0) | \
PIN_AFIO_AF(GPIOB_PWR_IND, 0) | \
PIN_AFIO_AF(GPIOB_I2S3_SCLK, 6) | \
PIN_AFIO_AF(GPIOB_OSC_EN, 0) | \
PIN_AFIO_AF(GPIOB_I2S3_SDAT, 6) | \
PIN_AFIO_AF(GPIOB_I2C1_SCL, 4) | \
PIN_AFIO_AF(GPIOB_I2C1_SDA, 4))
#define VAL_GPIOB_AFRH (PIN_AFIO_AF(GPIOB_SDIO_D4, 12) | \
PIN_AFIO_AF(GPIOB_SDIO_D5, 12) | \
PIN_AFIO_AF(GPIOB_EMMC_RST, 0) | \
PIN_AFIO_AF(GPIOB_SPI2_INT, 0) | \
PIN_AFIO_AF(GPIOB_SPI2_NSS, 5) | \
PIN_AFIO_AF(GPIOB_SPI2_SCK, 5) | \
PIN_AFIO_AF(GPIOB_SPI2_MISO, 5) | \
PIN_AFIO_AF(GPIOB_SPI2_MOSI, 5))
This is strange because board files do not depend on anything external. Not sure abut what the problem could be, you should verify if the GPIO registers are initialized correctly.
I forget to tell you I run another application (bootloader) just before the main app.
But the board configuration files are always the same.
-g
-g
I do initialize SPI device in a separate process: could this be the problem of incorrect initialization of spi pins?
-g
-g
