STM32f429 Demo - Suspend not possible
Anubirux
Post by Anubirux »
Hello !
I have strange problem. I cant suspend program while debugging. I'm using demo from 2.6.x repository. Program is working fine, all test go through, breakpoints are working but when I press "suspend" it just stops and gdb crashes a while later. What is most interesting is when I use similar demo but from chibi 3.0 it has no problems ... Any ideas what could be wrong ?
Re: STM32f429 Demo - Suspend not possible
I am not experiencing this, verify if you have differences in Eclipse debug configurations.
Anubirux
Post by Anubirux »
Guilty found, I'm using bleeding edge toolchain and looks like its gdb is somehow corrupted, however its first time when I see something like that. Maybe newer version wont have this problem (Now I see that I'm using a little outdated version). I'll check and post info ;)
Btw thx for interest. Like always faster then lightning ;P
Edit:
Nope, "gcc-arm-none-eabi-4_7-131005-win-x64" package still have the same problem.
Freddie Chopin
Post by Freddie Chopin »
Try the most recent release - 131228. I think I've stumbled upon the same problem as you with the previous versions (from August, October and the one from 2 days ago), but in the new version the problem is solved - at least here (;
4\/3!!
