Hello
Another port added. This one is for RPBRX62N board (RX600 family), which I received from Renesas last days. Port supports only serial driver at the moment. It seems working stable and passess all tests.
Sources are in rx_dev branch, enjoy.
Regards
lb
Renesas RX62N port
Moderator: lbednarz
Re: Renesas RX62N port
Very good, I got one of those boards on my desk as well!
Guys, I really appreciate to see how you share your ports, this will clearly help to spread the RTOS further.
- Has thanked: 1074 times
- Been thanked: 921 times
- Contact:
- Has thanked: 1 time
- Been thanked: 20 times
- Contact:
Giovanni, I should have checked there first!
Anyway, I have an RPBRX210‎ promotional board (RX21x) based. This code should make it easier to make a port for the RX210. My main issue with it is that I was not able to make the Segger J-Link interface work in Linux/Mac so I have to rely on Windows to work with it.
lbednarz,
Are you able to program your board (seems to use J-Link too) on anything other than Windows?
Btw, are you minux from go-nuts?
Best regards,
Fabio Utzig
lbednarz,
Best regards,
Fabio Utzig
- DeusExMachina
- Has thanked: 3 times
- Been thanked: 3 times
I have RL78/G13 Promotional Board, but even haven't unpacked . I wanted to make a port, but haven't had time yet. I think can do it in Jan or Feb.
- DeusExMachina
RL78 has an interesting power saving options. With Chibios 3.0 it will be delicious
- Contact:
It seems some kind of Z80 derivative, even if not binary compatible. A port should not be difficult.
