I see in your port for this cpu, you have VLE turned on. Which GCC compiler support VLE code? To date, I am not aware of VLE support in GCC.
thanks
-T
Which GCC compiler
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Re: Which GCC compiler
It is a custom GCC from HighTec, it is included in the SPC5Studio suite that can be downloaded from the ST web site.
As far I know some VLE patches have been submitted for GCC, it is possible a free version will appear at some point.
Giovanni wrote:Hi,
Do you know if this compiler also supports the TPU? Most of the advantage of the SPC line over the ARM line is the availability of the TPU and offloading functions to it.
- Contact:
It does not support the TPU, there are other compilers as far I know but this question should be directed to ST.
Giovanni wrote:Hi,
We are looking for a free compiler for the TPU. We're not having any luck.
You should be able to get a 30 day evaluation license.
- russian
- Has thanked: 16 times
- Been thanked: 14 times
Giovanni wrote:As far I know some VLE patches have been submitted for GCC, it is possible a free version will appear at some point.
If I read the right thread and if I read the thread correctly, it seems like CodeSourcery VLE patch was rejected - and part of the deal is not only the patch itself but also the history of not maintaining previous contributions. At least at some point in the past GCC was under an impression that VLE should rather stay outside of GCC, they just do not need it that much considering the small amount of people interested in it and the lack of support from the interested parties.
See http://gcc.1065356.n5.nabble.com/GCC-support-for-PowerPC-VLE-td858805.html
See http://gcc.1065356.n5.nabble.com/PATCH-PowerPC-VLE-port-td867067.html
Is there any chance of a Code Worrier port? CW 2.1 has the free edition limited to 128Kb.
- Contact:
Cannot reveal details but it is very probably there will be a time unlimited compiler soon, the limit would be 256Kb code max.
- russian
Giovanni wrote:Cannot reveal details but it is very probably there will be a time unlimited compiler soon, the limit would be 256Kb code max.
Please try to make this happen!
NXP has just released the source code and binaries for the e200 GCC compiler with VLE extensions.
You can get it pre-compiled for both Linux and Windows with the S32 Design Studio for Power v1.1.
The source code is available as a download: http://www.nxp.com/lgfiles/updates/S32D ... .3.tar.bz2
I haven't yet tried to build it from source.
Users browsing this forum: No registered users and 20 guests
