ChibiStudio stm32f4discovery-failed to load demo project.
przem312
Post by przem312 »
Hi there!
I've got an issue regarding starting demo project by using chibistudio preview 5. Once I've build the ARMCM4-STM32F407-DISCOVERY project, started the openocd with stm32f4discovery.cfg, ran the debug and here's what i got:
Open On-Chip Debugger 0.7.0 (2013-05-05-10:41)
Licensed under GNU GPL v2
For bug reports, read
Warn : Interface already configured, ignoring
Error: already specified hl_layout stlink
Info : This adapter doesn't support configurable speed
Info : STLINK v2 JTAG v14 API v2 SWIM v0 VID 0x0483 PID 0x3748
Info : Target voltage: 2.886772
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : accepting 'gdb' connection from 3333
Info : device id = 0x10016413
Info : flash size = 1024kbytes
Warn : acknowledgment received, but no packet pending
undefined debug reason 6 - target needs reset
target state: halted
xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
Info : Padding image section 0 with 8 bytes
Error: timeout waiting for algorithm, a target reset is recommended
Error: error executing stm32x flash write algorithm
Error: flash write failed = 00000040
Error: error writing to flash at address 0x08000000 at offset 0x00000000
Warn : The target is not in the halted nor running stated, stepi/continue ignored.
Warn : target not halted
Error: address + size wrapped(0xfffffffe, 0x00000004)
Info : rejected 'gdb' connection, no more connections allowed
Info : dropped 'gdb' connection
Error: Target is already running an algorithm
Error: error starting target flash write algorithm
Error: jtag status contains invalid mode value - communication failure
Polling target stm32f4x.cpu failed, GDB will be halted. Polling again in 100ms
Error: JTAG failure -4
Polling target stm32f4x.cpu succeeded again
Any ideas what might go wrong? Flash is ofc clean as should.
Re: ChibiStudio stm32f4discovery-failed to load demo project
It could be an HW issue looking at that. Do you have another board to try?
inca
Post by inca »
I can confirm the same occurs in the RT-STM32F429-DISCOVERY demo project in ChibiStudio Preview 10.7.
Steps to repeat on this STM32F429Discovery board:
* Build project
* Start openocd (onboard stlink-v2 via libusb-win32 1.2.6.0 zadig), select the scripts/board/stm32f429discovery.cfg
* OpenOCD [Flash, Run]
* At main entry point, select continue or step through the code.
$ ./bin/openocd.exe -f scripts/board/stm32f429discovery.cfg
Open On-Chip Debugger 0.9.0-dev-00268-ga9c90a0 (2015-02-08-10:38)
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Info : STLINK v2 JTAG v23 API v2 SWIM v0 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 2.892127
Info : accepting 'telnet' connection on tcp/4444
Info : accepting 'gdb' connection on tcp/3333
Info : device id = 0x10036419
Info : flash size = 2048kbytes
Info : Padding image section 0 with 4 bytes
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x20000042 msp: 0xfffffffc
xPSR: 0x01000000 pc: 0x080001c0 msp: 0x00000400
Info : Previous state query failed, trying to reconnect
Polling target stm32f4x.cpu failed, GDB will be halted. Polling again in 300ms
Polling target stm32f4x.cpu failed, GDB will be halted. Polling again in 700ms
Polling target stm32f4x.cpu failed, GDB will be halted. Polling again in 1500ms
Stepping through the code results in the following trace to pal_lld.c:
static void initgpio(stm32_gpio_t *gpiop, const stm32_gpio_setup_t *config) {}
gpiop->MODER   = config->moder;
I turned off optimization and now breakpoints don't seem to be getting hit for main(). We immediately get stuck in _unhandled_exception().
As far as I can tell, the code and hardware are in the virgin state.
I'll try the demo on a STM32F4 Disco board as well and report back if anything interesting occurs.
inca
Post by inca »
The F4 Disco board has Black Magic Debugger on it and I'm not terribly interested in learning how to interface it to eclipse, even though it should be trivial.
The F3 Disco board demo, RT-STM32F303-DISCOVERY, works flawlessly. Breakpoints and all.
