[DONE] Demo for STM32F401C Discovery board
trepidacious
Post by trepidacious »
Hi All,
I've ported a simple demo to the F401C disco board, based on the 407 demos. This just blinks the 4 LEDs and sets up a USB serial shell. You will need to change the CHIBIOS path in the Makefile to wherever you have ChibiOS trunk.
The board.h changes needed were to change the MCU define to STM32F401xx, rename PB11 to make it clear it is unusable, to rename PE2, 4 and 5 to show they are connected to the LSM303DLHC, and to remove the GPIO ports that aren't present.
I also modified the mcuconf.h to produce an 84MHz system clock and remove settings for devices that aren't present.
Finally, I made a new .ld file for the 401xC
Other than this things seem to run very similarly - I think I've probably update everything needed, but I might well have missed something. Hopefully this will be helpful in adding an official demo! I would have ported the SPI and PWM stuff, but the MEMs sensor is a different model, so I'm not sure the driver would be compatible.
ARMCM4-STM32F401C-DISCOVERY.zip
Archive of demo project.
(111.62 KiB) Downloaded 432 times
Re: Demo for STM32F401C Discovery board
Thanks, I'll add it.
lilvinz
Been thanked: 6 times
Post by lilvinz »
Some things to fix:
mcuconf.h:
* F401 doesn't have backup sram
* F401 doesn't have EXTI20 and 21
* F401 doesn't have timers 6, 7, 8 but has timer 10
* F401 has UART1, 2 and 6
hal:
* The exti driver doesn't recognize the missing lines 20 and 21 and fails to build
* The vector table lacks the last vector (0x190 - SPI4)
* F401 has SPI4 but in hal_lld.h its defined to FALSE
Thats what i have found so far.
@Giovanni do you have an idea if / when the hal will be fixed so i can reasonably decide if its worth tentatively fixing it myself.
Cheers,
Vinz
Re: [TODO] Demo for STM32F401C Discovery board
Added to the TODO list. I had no idea there were so many differences, the 401 support is very experimental.
I made all fixes, could you confirm I didn't forget something?
lilvinz
Re: [DONE] Demo for STM32F401C Discovery board
Post by lilvinz »
Sorry for the late reply. I can't see where you added the missing vector 0x190 for SPI4.
I was looking at this commit:
https://github.com/ChibiOS/ChibiOS-RT/c ... a30ee19005
edit: disregard comment, i was looking at the wrong commit.
edit: this is the right one: https://github.com/ChibiOS/ChibiOS-RT/c ... ec7#diff-6
lilvinz
Post by lilvinz »
there is one fix i missed:
The F401 doesn't have EXTI line 19 (ETH_WKUP_IQRn).
It has to be disabled in ext_lld_isr.c.
Thanks and regards,
Vinz
