spi speed of stm32l demo
yushanh
Post by yushanh »
I just checked out the example under "ChibiOS-RT/demos/ARMCM3-STM32L152-DISCOVERY". The SPI setting of the demo is as the following:
 * SPI configuration structure.
 * Maximum speed (12MHz), CPHA=0, CPOL=0, 16bits frames, MSb transmitted first.
 * The slave select line is the pin GPIOA_SPI1NSS on the port GPIOA.
static const SPIConfig spicfg = {
  spicb,
  /* HW dependent part.*/
  GPIOB,
  12,
  SPI_CR1_DFF
  palSetPad(GPIOB, 12);
  palSetPadMode(GPIOB, 12, PAL_MODE_OUTPUT_PUSHPULL |
                           PAL_STM32_OSPEED_HIGHEST);           /* NSS.     */
  palSetPadMode(GPIOB, 13, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);           /* SCK.     */
  palSetPadMode(GPIOB, 14, PAL_MODE_ALTERNATE(5));              /* MISO.    */
  palSetPadMode(GPIOB, 15, PAL_MODE_ALTERNATE(5) |
                           PAL_STM32_OSPEED_HIGHEST);           /* MOSI.    */
The comment of "spicfg" points out the maximal speed would be 12MHz. When I read the datasheet, the maximal clock rate of APB2 should be 32MHz, and after the prescaler calculation (000: fclk/2), it should be 32MHz / 2 = 16MHz, instead of 12MHz. Did I misunderstand anything here?
Thanks!
~S
Re: spi speed of stm32l demo
It is very possible there is an error, that demo has been copy/pasted from another demo for another STM32.
