RT-STM32F407-DISCOVERY build error
I wanted to give ChibiOS/RT 3.x a try and therefore I checked out the kernel_3_dev branch. I tried to compile the RT-STM32F407-DISCOVERY demo but I ended up with a kind of error that I've never seen before:
main.c: In function 'Thread1':
main.c:36:1: warning: no return statement in function returning non-void [-Wreturn-type]
Linking build/ch.elf
main.c: In function 'main':
main.c:41:5: internal compiler error: Segmentation fault
 int main(void) {
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper: arm-none-eabi-gcc returned 1 exit status
c:/program files (x86)/gnu tools arm embedded/4.8 2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld.exe: lto-wrapper failed
make: *** [build/ch.elf] Error 1
Any ideas? I'm compiling on Windows 8.1 using cygwin and the GNU ARM GCC compiler. However, I don't expect this to be the problem as all the 2.6.3 demos compile without any problems. Can you compile the demo?
saraben
Re: RT-STM32F407-DISCOVERY build error
Post by saraben »
Tectu,
I note that you are using gcc-arm-none-eabi-4_8-2014q1.
I have noticed that LTO appears to be a problem with V3 demos with this version on Linux. I have turned it off for now.
There does not appear to be an issues with gcc-arm-none-eabi-4_7-2013q3.
Haven't had time to look any closer.
saraben
Thank you very much saraben. I disabled LTO and I can now successfully build the demo using gcc-arm-none-eabi-4_8-2014q1.
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
there is a bug with gcc-arm-none-eabi-4_8-2014q1 which prevent to use -flto and -gddb together.
For tuning, you can disable flto and enable gddb.
For performance, enable flto and disable gddb.
Alexandre
alex31 wrote:there is a bug with gcc-arm-none-eabi-4_8-2014q1 which prevent to use -flto and -gddb together.
Good information, thank you very much!
russian
Has thanked: 16 times
Been thanked: 14 times
Post by russian »
I know this is old thread and this is maybe less relevant for Chibios 3+ but https://bugs.launchpad.net/gcc-arm-embe ... ug/1674525
Thanks for sharing that bug, interesting.
I implemented a workaround but it is good they are aware of it (I should look at commits, I don't remember which workaround exactly).
