Where are the ChibiOS/RT Eclipse plugins
colin
Post by colin »
Is there a place where I can download the ChibiOS/RT debug plugin and ChibiOS/RT configuration plugin for Eclipse? I work mostly on Linux and I'd like to be able to just install the plugins in my stock Eclipse IDE.
Re: Where are the ChibiOS/RT Eclipse plugins
The repository with the latest code is here: http://sourceforge.net/p/chibios/svn/HE ... dio_trunk/
You can take the binary plugins from the ChibiStudio zip file, they work in Linux too.
colin
Post by colin »
OK, thanks. I'll give it a shot.
It would be awesome if there was a way to use the Eclipse Help | Install New Software feature and just type in a URL of a Software Site that provided the ChibiOS Eclipse plugins. Is this feasible? I don't know how Eclipse software distribution works, but I would hope that it could be served by a standard web server. Is there a chance we could have a Software Site set up on chibios.org at some point?
Just ask :)
http://www.chibios.org/eclipse/chibistudio/
Never really tested it, I wanted to enable it in ChibiStudio 6. Don't select the compiler feature while installing because it is for SPC5Studio and would give you a missing dependency.
colin
Post by colin »
Awesome, I installed it on my Eclipse 3.8 successfully through the software site and Eclipse's Install New Software feature. Haven't tested using the plugin yet but I'll give it a shot.
DeusExMachina
Has thanked: 3 times
Been thanked: 3 times
Post by DeusExMachina »
I tried to install it, but got this:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact not found: http://www.chibios.org/eclipse/chibistu ... 121101.jar.
Eclipse IDE for C/C++ Developers
Version: Mars.2 Release (4.5.2)
Build id: 20160218-0600
