port for netduino2
pete_jan
port for netduino2
Post by pete_jan »
I have started a port for netduino2 which I have, I did not figure out how you were building the port pins board.h files, I build them from a csv file and awk, which was a bit crude, but works.
I managed to get this woking on the netduino2, blinking the LED and a serial port on UART2 PA2 and PA3
http://netduino.com/netduino2/netduino2 link.
I have some more work to do, will post some more if anyone is interested.
Regards,
Pete
netduino2.patch.gz
diff file from trunk, adding project and board files
(17.73 KiB) Downloaded 476 times
Re: port for netduino2
Thank you very much for sharing your work. We've sent out a tweet - Probably someone will get interested and can help you.
pete_jan wrote:I did not figure out how you were building the port pins board.h files, I build them from a csv file and awk, which was a bit crude, but works.
The board files are generated from an eclipse plugin inside the ChibiStudio IDE.
pete_jan
Post by pete_jan »
Attached patch against branches/stable_2.6.x for netduino2 board, and demo project, using board generator fmpp
netduino2.patch.gz
patch against chibios branches/stable_2.6.x
(13.96 KiB) Downloaded 454 times
The board files contain a link not C code, you should also include the .chcfg file too.
pete_jan
Post by pete_jan »
Sorry about that, I though svn added them as files not links.
try attached patch.
I could not figure how you had included the cfg file, as I had them in gencfg to build them, but found an example, does that work?
Peter
netduino2.patch.gz
included files (not links) and cfg file
(22.22 KiB) Downloaded 449 times
