Maximum PWM clock frequency on STM32F4
manton
Post by manton »
I 'm not sure if you have come across this issue. It seems that I couldn't use more than 2 MHz for clock frequency when config the PWM.
I tried to create PWM signal of 10kHz frequency with complementary output + dead time so I config PWM as below (using 20MHz pwm clock frequency). But it couldn't run pass pwmStart().
If I change the clock to 2MHz, it runs fine - I get the outputs from CH1 and CH1N. But whenever I use something more than 2MHz, it fails.
Could you please verify if I have something wrong inside my codes.
My board is STM32f4 discovery.
Eclipse+Yagarto GCC 4.6.2 to compile Chibios 2.5.0.
Many thanks in advance.
Man
#include "ch.h"
#include "hal.h"
static PWMConfig pwmcfg = {
      20000000,                                    /*PWM clock frequency.   */
      2000,                                    /* Initial PWM period     */
      NULL,
            {PWM_COMPLEMENTARY_OUTPUT_ACTIVE_HIGH | PWM_OUTPUT_ACTIVE_HIGH, NULL},
            {PWM_OUTPUT_DISABLED, NULL},
      0,
      200
 * Application entry point.
int main(void) {
    * System initializations.
    *   RTOS is active.
   palSetPadMode(GPIOE, 8, PAL_MODE_ALTERNATE(1));
   palSetPadMode(GPIOE, 9, PAL_MODE_ALTERNATE(1));
   while (TRUE) {
      palClearPad(GPIOD, GPIOD_LED4);
      pwmStart(&PWMD1, &pwmcfg);
      chThdSleepMilliseconds(2000);
      palSetPad(GPIOD, GPIOD_LED4);
       * Starts the PWM channel 0 using 75% duty cycle.
      pwmEnableChannel(&PWMD1, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD1, 7500));
       * Changes the PWM channel 0 to 50% duty cycle.
      pwmEnableChannel(&PWMD1, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD1, 5000));
       * Changes the PWM channel 0 to 25% duty cycle.
      pwmEnableChannel(&PWMD1, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD1, 2500));
      chThdSleepMilliseconds(5000);
       * Changes PWM period to half second the duty cycle becomes 50%
       * implicitly.
      pwmChangePeriod(&PWMD1, 5000);
       * Disables channel 0 and stops the drivers.
      pwmDisableChannel(&PWMD1, 0);
      pwmStop(&PWMD1);
   return 0;
Re: Maximum PWM clock frequency on STM32F4
I assume that you are working with assertions enabled or the driver would not stop inside pwmStart().
Are you sure that the PWM input frequency is exactly 20MHz? inside pwmStart() there is an assertion that makes sure that the input frequency is a multiple of the configured frequency. If this is not true then execution is stopped.
The input frequency is the programmed clock for APB1 or APB2 depending on the timer you are using. Verify your APB settings in mcuconf.h.
manton
Post by manton »
Thanks very much Giovanni.
I think I found my mistake. I set APB2 at 168MHz so I should use the frequency that makes the prescaler an integer.
Initially I thought that I could use any frequency that is less than APB2 and the prescaler calculation will take care of it. Obviously, if I use 20MHz, the psc is 7.4. That's why I got stuck.
Cheers.
Man
DrunkenDonkey
Post by DrunkenDonkey »
I simply nuked that assert, as I call for varying frequencies and anything nearby suits me, does not have to be exact and it works fine.
hkerner
Post by hkerner »
I have determined that my application is halting on this same assert, but I am not sure where APB1 and 2 are set, and there is nothing about APB in mcuconf. Could someone please point me to where I can see the frequency of these? Thank you!
In mcuconf.h look for:
#define STM32_PPRE1 STM32_PPRE1_DIV4
#define STM32_PPRE2 STM32_PPRE2_DIV2
