IOPORT8 Compilation Error
Moderator: tfAteba
major4x
Post by major4x »
I am using the PAL driver on an Arduino AVR ATMEGA2560. For some reason when I use:
palClearPad(IOPORT2, 2);
everything compiles (and works) OK, but when I use:
palClearPad(IOPORT8, 6);
then I get the following compilation error:
avr-gcc -c -mmcu=atmega2560 -I. -x c++ -gdwarf-2 -DF_CPU=16000000UL -O2 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -fno-exceptions -Wall -Wa,-adhlns=./main.lst -Iport -Ikernel/include -Ihal/include -Iplatform -Iboard -I/os/various -MMD -MP -MF .dep/main.o.d main.cpp -o main.o
main.cpp: In function 'int main()':
main.cpp:221:28: warning: asm operand 0 probably doesn't match constraints [enabled by default]
main.cpp:221:28: error: impossible constraint in 'asm'
I was wondering if I am doing something wrong? I am trying to communicate with a digital output on PINH.
Thanks a lot for your help,
-- Alex
major4x
Re: IOPORT8 Compilation Error
Post by major4x »
I know what the problem is.
palClearPad() on AVR translates to assembly instruction "cbi" (clear a bit in an I/O register). Problem is that the operand of cbi is 8 bit and it does not support I/O ports in the upper address space. That's why I get the error. The proper way to use port H is:
palClearPort(IOPORT8, (1 << PH6));
Of course, this gets translated to several assembly instructions and the operation is not atomic anymore, so one should take care of synchronicity...
