MSP430 math.h build error
rpcaldeira
Post by rpcaldeira »
Hello guys!
I'm having a problem where i'm trying to use the math library in my code but it doesen't work.
#include <stdio.h>
#include <string.h>
#include <inttypes.h>
#include <stdint.h>
#include <stdlib.h>
#include <math.h>
it is included and present in the makefile:
# Start of default section
# List all default C defines here, like -D_DEBUG=1
DDEFS = -D__MSP430F1611__
# List all default ASM defines here, like -D_DEBUG=1
DADEFS =
# List all default directories to look for include files here
DINCDIR =
# List the default directory to look for the libraries here
DLIBDIR = /usr/msp430/lib
# List all default libraries here
DLIBS = -lm
can anyone help me? Thanks guys
Re: MSP430 math.h build error
You should detail the "does not work" part.
rpcaldeira
I'm deeply sorry, must have been the rush :/
When comes to the linking part, it gives me the undefined reference error
msp430-gcc ../../os/ports/GCC/MSP430/chcoreasm.o ../../os/kernel/src/chsys.o ../../os/kernel/src/chdebug.o ../../os/kernel/src/chlists.o ../../os/kernel/src/chvt.o ../../os/kernel/src/chschd.o ../../os/kernel/src/chthreads.o ../../os/kernel/src/chdynamic.o ../../os/kernel/src/chregistry.o ../../os/kernel/src/chsem.o ../../os/kernel/src/chmtx.o ../../os/kernel/src/chcond.o ../../os/kernel/src/chevents.o ../../os/kernel/src/chmsg.o ../../os/kernel/src/chmboxes.o ../../os/kernel/src/chqueues.o ../../os/kernel/src/chmemcore.o ../../os/kernel/src/chheap.o ../../os/kernel/src/chmempools.o ../../test/test.o ../../test/testthd.o ../../test/testsem.o ../../test/testmtx.o ../../test/testmsg.o ../../test/testmbox.o ../../test/testevt.o ../../test/testheap.o ../../test/testpools.o ../../test/testdyn.o ../../test/testqueues.o ../../test/testbmk.o ../../os/hal/src/hal.o ../../os/hal/src/adc.o ../../os/hal/src/can.o ../../os/hal/src/ext.o ../../os/hal/src/gpt.o ../../os/hal/src/i2c.o ../../os/hal/src/icu.o ../../os/hal/src/mac.o ../../os/hal/src/mmc_spi.o ../../os/hal/src/mmcsd.o ../../os/hal/src/pal.o ../../os/hal/src/pwm.o ../../os/hal/src/rtc.o ../../os/hal/src/sdc.o ../../os/hal/src/serial.o ../../os/hal/src/serial_usb.o ../../os/hal/src/spi.o ../../os/hal/src/tm.o ../../os/hal/src/uart.o ../../os/hal/src/usb.o ../../os/hal/platforms/MSP430/hal_lld.o ../../os/hal/platforms/MSP430/pal_lld.o ../../os/hal/platforms/MSP430/serial_lld.o ../../boards/TRENZ_0600_02/board.o ../../os/various/memstreams.o ../../os/various/chprintf.o ../../os/various/shell.o ../../os/various/evtimer.o RF/driver/RF.o RF/basicrf/basic_rf.o main.o  -mmcu=msp430x1611 -Tmsp430.x -Wl,-Map=Thesis.map,--cref,--no-warn-mismatch -L/usr/msp430/lib -lm  -o Thesis.elf
RF/basicrf/basic_rf.o: In function `randn':
basic_rf.c:(.text+0x5cc): undefined reference to `exp'
RF/basicrf/basic_rf.o: In function `expon':
basic_rf.c:(.text+0x6e4): undefined reference to `log'
collect2: ld returned 1 exit status
thanks again :)
It looks related to the compiler, did you build it yourself? check if in the library there are those symbols because apparently not.
rpcaldeira
Hey, no it was not built by me. Those are the packages msp430-libc, msp430mcu, mspdebug from XUbuntu 14.04.
That was my frist thought too but when i looked at the math.h file...
#ifndef _REENT_ONLY
#ifndef __math_6881
extern double acos _PARAMS((double));
extern double asin _PARAMS((double));
extern double atan2 _PARAMS((double, double));
extern double cosh _PARAMS((double));
extern double sinh _PARAMS((double));
extern double exp _PARAMS((double));
extern double ldexp _PARAMS((double, int));
extern double log _PARAMS((double));
extern double log10 _PARAMS((double));
extern double logb _PARAMS((double));
extern double pow _PARAMS((double, double));
extern double sqrt _PARAMS((double));
extern double fmod _PARAMS((double, double));
#endif /* ! defined (__math_68881) */
#endif /* ! defined (_REENT_ONLY) */
The functions are defined, so they should be implemented :S
Thanks again,
Rui
The functions are defined in the header, you should verify if the library really contains them.
rpcaldeira
You were right i used
nm ./libm.a | grep -w T | grep -E 'log|exp'
and they were not there.
Thanks a million,
Rui :)
