I'm using ChibiOS on a Arduino Pro Mini 3.3V @ 8MHz. I'm trying to run an SD data logger that logs some I2C sensor data to an SD card every 1.5ms. Using the data logger example as a base I got it all working fine with no overruns, but no matter what I do I can't get it to log faster than 1 sample every 2ms.
I think part of the problem is that I'm using an 8MHz board. Using the example code with it set up like:
// interval between points in units of 1024 usec
const uint16_t intervalTicks = 2;Then it actually collects data at a 4ms rate, and when I change intervalTicks to 1 the it collects at a 2ms rate. I can live with having to adjust my code to reflect half of what I want the sample right to be, but I need to collect data at something in between 1 and 2ms
So tried changing the thread sleep function to:
chThdSleepMicroseconds(1500);But didn't work either.
I tried playing with the "#define CH_FREQUENCY (F_CPU/16384L)" and "#define CH_TIME_QUANTUM 20" settings in the .h files but no matter what I did it still collects at 2.048ms.
I don't understand where the settings are that make my "intervalTicks" double and more importantly I can't figure out how to set an interval that isn't a multiple of 1024us. It seems like it should be possible.
The reason I'm running at 8MHz is because I need a small, 3.3V compatible arduino board and didn't have at 16MHz. I have a Teensy 3.1 that might also work, but looking at the example file in the ChibiOS_Arm folder it looks like that comment about "intervals of 1024us" is in there also and I don't want to tear my hardware setup all apart if it is going to have the same problem.
Can anybody help point me in the right direction?
Dylan
