Error with GPT driver in several threads
radiotechkz
Post by radiotechkz »
Hi all,
I got a strange bug in my code with GPT. Below I will give my code. In a nutshell, I create two threads and pull pin with 1kHz frequency in each. If used one thread no problem, in oscilloscope I can see normal signal.
If used two threads signal looks like this:
A different scale
#include "ch.h"
#include "hal.h"
#include <chprintf.h>
static WORKING_AREA(waThread2, 128);
static msg_t Thread2(void *arg) {
    (void)arg;
    chRegSetThreadName("Ring1");
    while (TRUE) {
        moveRing1(TRUE, TRUE, 400, 150);
static WORKING_AREA(waThread3, 128);
static msg_t Thread3(void *arg) {
    (void)arg;
    chRegSetThreadName("Ring2");
    while (TRUE) {
        moveRing2(TRUE, TRUE, 400, 150);
void moveRing1(bool_t enable, bool_t dir, uint32_t stepsNum, uint32_t period) {
    uint32_t count = 0;
    if (enable != TRUE) {
        palSetPad(GPIOE, GPIOE_INT2);        // if not enable set pin GPIOE.1, stop driver
    else {
        palClearPad(GPIOE, GPIOE_INT2);        // if enable clear pin GPIOE.1, start driver
    if (dir == TRUE) {
        palSetPad(GPIOE, GPIOE_PIN12);        // directory of rotary, DIR pin on Driver, GPIOE.12
    else {
        palClearPad(GPIOE, GPIOE_PIN12);
    while(count < stepsNum) {
        palSetPad(GPIOC, GPIOC_PIN6);
        gptPolledDelay(&GPTD2, period);
        palClearPad(GPIOC, GPIOC_PIN6);
        count ++;
void moveRing2(bool_t enable, bool_t dir, uint32_t stepsNum, uint32_t period) {
    uint32_t count = 0;
        palSetPad(GPIOE, GPIOE_PIN2);        // if not enable set pin GPIOE.1, stop driver
    else {
        palClearPad(GPIOE, GPIOE_PIN2);        // if enable clear pin GPIOE.1, start driver
    if (dir == TRUE) {
        palSetPad(GPIOE, GPIOE_PIN13);        // directory of rotary, DIR pin on Driver, GPIOE.12
    else {
        palClearPad(GPIOE, GPIOE_PIN13);
        palSetPad(GPIOC, GPIOC_MCLK);
        gptPolledDelay(&GPTD3, period);
        palClearPad(GPIOC, GPIOC_MCLK);
        count ++;
* GPT2 configuration.
static GPTConfig gpt2cfg =
    300000,     /* timer clock.*/
    NULL        /* Timer callback.*/
* GPT3 configuration.
static GPTConfig gpt3cfg =
void ringInit() {
    palSetPadMode(GPIOE, GPIOE_INT2, PAL_MODE_OUTPUT_PUSHPULL);
    palSetPadMode(GPIOE, GPIOE_PIN12, PAL_MODE_OUTPUT_PUSHPULL);
    palSetPadMode(GPIOC, GPIOC_PIN6, PAL_MODE_OUTPUT_PUSHPULL); // step pin for ring 1
    palSetPadMode(GPIOE, GPIOE_PIN2, PAL_MODE_OUTPUT_PUSHPULL);
    palSetPadMode(GPIOE, GPIOE_PIN13, PAL_MODE_OUTPUT_PUSHPULL);
    palSetPadMode(GPIOC, GPIOC_MCLK, PAL_MODE_OUTPUT_PUSHPULL); // step pin for ring2
    palSetPadMode(GPIOE, GPIOE_CS_SPI, PAL_MODE_OUTPUT_PUSHPULL);
    palSetPadMode(GPIOE, GPIOE_PIN14, PAL_MODE_OUTPUT_PUSHPULL);
    palSetPadMode(GPIOB, GPIOB_PIN0, PAL_MODE_OUTPUT_PUSHPULL); // step pin for ring3
    palSetPadMode(GPIOE, GPIOE_PIN4, PAL_MODE_OUTPUT_PUSHPULL);
    palSetPadMode(GPIOE, GPIOE_PIN15, PAL_MODE_OUTPUT_PUSHPULL);
    palSetPadMode(GPIOB, GPIOB_PIN1, PAL_MODE_OUTPUT_PUSHPULL); // step pin for ring3
// Application entry point.
int main(void) {
     * System initializations.
     *   RTOS is active.
      * Activates the serial driver 2 using the driver default configuration.
        * PA2(TX) and PA3(RX) are routed to USART2.
    /*sdStart(&SD2, NULL);
    palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
    palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));*/
    ringInit();
    gptStart(&GPTD2, &gpt2cfg);
    gptStart(&GPTD3, &gpt3cfg);
     * Creates the example thread.
    chThdCreateStatic(waThread2, sizeof(waThread2), NORMALPRIO, Thread2, NULL);
    chThdCreateStatic(waThread3, sizeof(waThread3), NORMALPRIO, Thread3, NULL);
     * sleeping in a loop.
    while (TRUE) {
        //chprintf((BaseSequentialStream *) &SD2, " %d\r", 101);
        chThdSleepMilliseconds(1);     // Задержка для считывания новых данных, заменить на пин прерывания DRDY
Help. I don't understand something simple.
Re: Error with GPT driver in several threads
You have two threads at same priority which perform chPolledDelay(). It is a polled delay so the CPU is not made available to other threads.
What you are seeing the is the round robin mechanism, the two threads each use a slice of time and alternates.
radiotechkz
Giovanni wrote:Hi,
Thanks, Giovanni.
But how can I resolve this task with delays in microseconds which not using cpu time?
Using ChibiOS 3.0 you can increase the system time frequency to 1MHz and use chThdSleepMicroseconds but you will discover that your generated signal will be affected heavily by jitter. You should not rely on threads for timings at that timescale.
If you need to generate signals you may use the PWM driver or use HW timers directly.
