How to execute code from RAM (STM32F3 CCM RAM)
Critek
Re: How to execute code from RAM (STM32F3 CCM RAM)
Post by Critek »
I already browsed through many doscussions in order to find what I ma looking for. I think your idea is sensible and will work but I don't have any file named vectors.c
and the only place where I find my vector is in a startup_stm32f3303xc.s. How do you think, is it a good idea to invoke the memcpy function on the begining of the SytemInit() function?
mobyfab
Has thanked: 21 times
Been thanked: 31 times
Post by mobyfab »
I should work, but you can do a manual copy in the init file, ie:
#if CRT0_INIT_CCM
  /* CCM segment initialization.*/
    uint32_t *tp, *dp, *end;
    extern vectors_t _vectors_CCM;
    tp = &_siccm;
    dp = &_sccm;
    while (dp < &_eccm)
      *dp++ = *tp++;
    tp = (uint32_t*)&_vectors;
    dp = (uint32_t*)&_vectors_CCM;
    end = (uint32_t*)((&_vectors_CCM)+sizeof(vectors_t));
    while (dp < end)
      *dp++ = *tp++;
   SCB->VTOR = (uint32_t)&_vectors_CCM;
I think now the init file is in assembly, but that works as well if you know how to do it.
The vector file is here: os/common/ports/ARMCMx/compilers/GCC/vectors.c
I will test this code tonight but it compiles :)
mobyfab
Post by mobyfab »
I tried to make it a bit cleaner.
 * init.c
#include "ch.h"
#include "vectors.h"
 * @brief   CCM segment initialization switch.
#if !defined(CRT0_INIT_CCM) || defined(__DOXYGEN__)
#define CRT0_INIT_CCM              TRUE
 * @brief   ROM image of the CCM segment start.
 * @pre     The symbol must be aligned to a 32 bits boundary.
extern uint32_t _siccm;
 * @brief   CCM segment start.
extern uint32_t _sccm;
 * @brief   CCM segment end.
extern uint32_t _eccm;
 * @brief   ISR Vector table.
extern vectors_t _vectors;
 * @brief   STM32 CCM vectors table.
void __late_init(void)
#if CRT0_INIT_CCM
    tp = &_siccm;
    dp = &_sccm;
    while (dp < &_eccm)
      *dp++ = *tp++;
    while (dp < end)
      *dp++ = *tp++;
File: bootloader/build/bootloader.elf
    65: 10000000   416 OBJECT  LOCAL  DEFAULT    3 _vectors_CCM.5062
   425: 08000000   416 OBJECT  GLOBAL DEFAULT    1 _vectors
You will have to have a vector.h file with the vector_t typedef from vectors.c
What I did is split the definition out of the c file.
That would be nice if giovanni could do that. (move the vector typedefs to a header file or put some kind of hook/helper fuction to copy/move the table)
I will look into it when I return on startup files.
mobyfab
Post by mobyfab »
Awesome :)
There is probably some noticeable performance gains here.
Even for devices without CCM, putting the vectors in ram would help.
I tested the code and it works fine, I just had to fix a cast.
#if CRT0_INIT_CCM
    tp = &_siccm;
    dp = &_sccm;
    while (dp < &_eccm)
      *dp++ = *tp++;
    end = ((uint32_t*)(&_vectors_CCM)+sizeof(vectors_t));
    while (dp < end)
      *dp++ = *tp++;
