problem with buffer for DAC DUAL
vambwodonk
Post by vambwodonk »
I'm trying DUAL DAC from TESTHAL but cannot get sine wave output.
I'm using STM32-F4 Discovery. Looks like this,
then after i see this note:
The buffer is organized as a matrix of M*N elements where M is the
 *          channels number configured into the conversion group and N is the
 *          buffer depth. The samples are sequentially written into the buffer
 *          with no gaps.
i change my code buffer 100 sample sine wave to this:
#define DAC_BUFFER_SIZE 200
 * DAC test buffer (sine wave).
static const dacsample_t dac_buffer[2][100] = {
            2048,2176,2304,2431,2557,2680,2801,2919,3034,3145,
            3251,3353,3449,3540,3625,3704,3776,3842,3900,3951,
            3995,4031,4059,4079,4091,4095,4091,4079,4059,4031,
            3995,3951,3900,3842,3776,3704,3625,3540,3449,3353,
            3251,3145,3034,2919,2801,2680,2557,2431,2304,2176,
            2048,1919,1791,1664,1538,1415,1294,1176,1061,950,
            844,742,646,555,470,391,319,253,195,144,
            100,64,36,16,4,0,4,16,36,64,
            100,144,195,253,319,391,470,555,646,742,
            844,950,1061,1176,1294,1415,1538,1664,1791,1919
then start DAC:
dacStartConversion(&DACD1, &dacgrpcfg1, *dac_buffer, DAC_BUFFER_SIZE);
But, i got no luck, my DUAL DAC still fail to load correct buffer,
Please help me.
Arif,
Re: problem with buffer for DAC DUAL
That looks like a driver problem, I will verify this, stay tuned but it will take some days, there are other things in queue.
Just a note.
I haven't forgot this, I am waiting for an oscilloscope at home in order to test the driver.
vambwodonk
May i can help you with my oscilloscope?,
if your Oscilloscope not ready yet.
Arif,
I need to do some debugging so I need one :) it is almost here anyway, during the weekend I will be on this.
OK, oscilloscope received :)
I have been able to see the problem in the DAC_DUAL demo, I am trying to understand the problem.
It was a wrong DMA setting, the driver sent twice the data specified so garbage was added at the end of the stream.
Fixed in repository as bug #677.
vambwodonk
Nice update !! :D
