Hard fault when enabling HSI on STM32F042
kisielk
Post by kisielk »
Just trying out the ChibiOS HAL on STM32F042 for the first time, but I'm running in to a hard fault almost right away. I tracked it down to the very first part of __early_init when HSI is enabled. Here's my GDB session:
(gdb) si
__early_init () at ../../ChibiOS/os/hal/boards/FREQMEASURE_PROTO/board.c:70
70   void __early_init(void) {
=> 0x8000ca0 <__early_init()>:   push   {r3, lr}
(gdb) si
72     stm32_clock_init();
=> 0x8000ca2 <__early_init()+2>:   bl   0x8000510 <stm32_clock_init()>
(gdb) si
stm32_clock_init () at ../../ChibiOS/os/hal/ports/STM32/STM32F0xx/hal_lld.c:140
140     RCC->CR |= RCC_CR_HSION;                  /* Make sure HSI is ON.         */
=> 0x8000510 <stm32_clock_init()>:   ldr   r2, [pc, #164]   ; (0x80005b8 <stm32_clock_init()+168>)
(gdb) si
0x08000512   140     RCC->CR |= RCC_CR_HSION;                  /* Make sure HSI is ON.         */
=> 0x8000512 <stm32_clock_init()+2>:   ldr   r3, [r2, #0]
(gdb) si
0x08000514   140     RCC->CR |= RCC_CR_HSION;                  /* Make sure HSI is ON.         */
=> 0x8000514 <stm32_clock_init()+4>:   orr.w   r3, r3, #1
(gdb) si
_unhandled_exception () at ../../ChibiOS/os/common/ports/ARMCMx/compilers/GCC/vectors.c:77
77   void _unhandled_exception(void) {
=> 0x8000c40 <_unhandled_exception()>:   b.n   0x8000c40 <_unhandled_exception()>
(gdb) mon reg
===== arm v7m registers
(0) r0 (/32): 0x00000002
(1) r1 (/32): 0xFFFFFFFF
(2) r2 (/32): 0x40021000
(3) r3 (/32): 0x00006483
(4) r4 (/32): 0xFFFFFFFF
(5) r5 (/32): 0xFFFFFFFF
(6) r6 (/32): 0xFFFFFFFF
(7) r7 (/32): 0xFFFFFFFF
(8) r8 (/32): 0xFFFFFFFF
(9) r9 (/32): 0xFFFFFFFF
(10) r10 (/32): 0xFFFFFFFF
(11) r11 (/32): 0xFFFFFFFF
(12) r12 (/32): 0xFFFFFFFF
(13) sp (/32): 0x20000400
(14) lr (/32): 0xFFFFFFFD
(15) pc (/32): 0x08000C40
(16) xPSR (/32): 0x01000003
(17) msp (/32): 0x20000400
(18) psp (/32): 0x200007D8
(19) primask (/1): 0x01
(20) basepri (/8): 0x00
(21) faultmask (/1): 0x00
(22) control (/2): 0x00
===== Cortex-M DWT registers
(23) dwt_ctrl (/32)
(24) dwt_cyccnt (/32)
(25) dwt_0_comp (/32)
(26) dwt_0_mask (/4)
(27) dwt_0_function (/32)
(28) dwt_1_comp (/32)
(29) dwt_1_mask (/4)
(30) dwt_1_function (/32)
(gdb)
The top of my mcuconf.h is:
#define STM32F0xx_MCUCONF
 * HAL driver system settings.
#define STM32_HSI14_ENABLED                 FALSE
#define STM32_PLLSRC                        STM32_PLLSRC_HSI_DIV2
#define STM32_PREDIV_VALUE                  1
#define STM32_PLLMUL_VALUE                  12
#define STM32_PPRE                          STM32_PPRE_DIV1
#define STM32_ADCSW                         STM32_ADCSW_PCLK
#define STM32_ADCPRE                        STM32_ADCPRE_DIV4
#define STM32_MCOSEL                        STM32_MCOSEL_NOCLOCK
#define STM32_CECSW                         STM32_CECSW_HSI
#define STM32_I2C1SW                        STM32_I2C1SW_HSI
#define STM32_USART1SW                      STM32_USART1SW_PCLK
#define STM32_RTCSEL                        STM32_RTCSEL_LSI
Not sure what is going on, seems like very basic code that should work. I must be making a simple mistake somewhere...
The board is a custom board we've designed, but I've verified the hardware functionality using the project template from GNU ARM Eclipse, just trying to make it work with the HAL now.
Re: Hard fault when enabling HSI on STM32F042
Have you tried the Nucleo32 demo for the F042? it works here.
kisielk
Post by kisielk »
Giovanni wrote:Have you tried the Nucleo32 demo for the F042? it works here.
Not yet since I was on 3.0.3, will update to 3.0.4 and try it out.
hi,
Those demos are on the trunk code, you need to checkout the subversion repository or get ChibiStudio 15 which also includes a snapshot of the repository.
giovanni
kisielk
Post by kisielk »
Thanks, I figured that out and checked it out from GitHub.
The Nucleo32 demo runs fine, so clearly I must have made some mistake when adapting one of the other boards. I guess I'll try using the Nucleo32 demo as a base and changing it to be os-less.
rew
Has thanked: 2 times
Been thanked: 14 times
Post by rew »
I always get the hardfaults when I've used a wrong board.c/board.h that was made for a different processor. Then you get initialization code for GPIO ports that are not available.
