Program crash after few running minutes Topic is solved
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Post by tfAteba »
Hi all,
By trying to help an member "RTOSman" you can see here: http://forum.chibios.org/phpbb/viewtopic.php?f=21&t=3155
I made a few test and here is my configuration:
- ChibiOS 3.0.4
- Nucléo F401 RE board
The code juste blink the on board LED.
  #include "ch.h"
  #include "hal.h"
   * LED blinker thread, times are in milliseconds.
  static THD_FUNCTION(Thread1, arg){
      uint32_t time = ST2MS(chVTGetSystemTime());
      (void)arg;
      while (true){
          palTogglePad(GPIOA, GPIOA_LED_GREEN);
          time += 1000;
          chThdSleepUntil(MS2ST(time));
   * Application entry point.
  int main(void){
      * System initializations.
      *   RTOS is active.
      * Creates the blinker thread.
      * sleeping in a loop.
      while (true){
          chThdSleepMilliseconds(1);
As a result, the on board led blink but after 7 minutes of running it turn off and stop blink.
Did I made miss something?
How can I used the debugger to catch such event?
Cheers,
Theo
Re: Program crash after few running minutes
Theodore ATEBA wrote:How can I used the debugger to catch such event?
This could help: http://chibios.org/dokuwiki/doku.php?id ... ebug_guide
tfAteba
Post by tfAteba »
Thanks, I'm going to try to locate the problem. But in géneral, what can cause such problem?
cheers,
Theo.
tfAteba
Post by tfAteba »
Sorry, all is explain in the debugger guide.
I will spare you a debug session, this time only :)
Look at your loop and compare with the example here: http://www.chibios.org/dokuwiki/doku.ph ... :kb:timing
Hint, it is not equivalent.
tfAteba
Post by tfAteba »
Thank you for you help and you hint ;) .
I did not use the MS2ST function properly. While the system tick was under the value I passed to the chThdSleepUntil function every thing was ok.
But this was not true every time so that why the program stopped when this condition was false.
Thank you,
cheers, Theo.
