ADCv2 Dual and triple mode
neums
Has thanked: 10 times
Been thanked: 5 times
Post by neums »
i want to use the STM32F4xx in dual and triple mode. Therefor i need to write a certain configuration to the CCR register. Is it possible to add this register in the ADCv2 LLD?
Re: ADCv2 Dual and triple mode
It would possible to add the double mode, we already do that for the F3, however there aren't immediate plans to do so.
neums
Post by neums »
Are there some side effects when this register is added or other arguments to do it not in this way? If not it whould be easy to implement it.
Look at the implementation on the F3, quite not that simple.
daniel_s
Post by daniel_s »
I'd appreciate this implementation for the F4 as well
