when my project was small I used used the $(PORTLD)/STM32F407xG_CCM.ld linker script. Everything worked nicely. But when my project grew linking with that script started to fail. Disabling the debug features of ChibiOS/RT helped at first, but now even that doesn't help. And the debug features are way too useful to disable them anyway. The only way to link my project now is to use the $(PORTLD)/STM32F407xG.ld script. But that wastes precious RAM.
The linker errors I get are:
arm-none-eabi-g++ ../build/obj/crt0.o ../build/obj/vectors.o ../build/obj/chcore.o ../build/obj/chcore_v7m.o ../build/obj/nvic.o ../build/obj/chsys.o ../build/obj/chdebug.o ../build/obj/chlists.o ../build/obj/chvt.o ../build/obj/chschd.o ../build/obj/chthreads.o ../build/obj/chdynamic.o ../build/obj/chregistry.o ../build/obj/chsem.o ../build/obj/chmtx.o ../build/obj/chcond.o ../build/obj/chevents.o ../build/obj/chmsg.o ../build/obj/chmboxes.o ../build/obj/chqueues.o ../build/obj/chmemcore.o ../build/obj/chheap.o ../build/obj/chmempools.o ../build/obj/hal.o ../build/obj/adc.o ../build/obj/can.o ../build/obj/ext.o ../build/obj/gpt.o ../build/obj/i2c.o ../build/obj/icu.o ../build/obj/mac.o ../build/obj/mmc_spi.o ../build/obj/mmcsd.o ../build/obj/pal.o ../build/obj/pwm.o ../build/obj/rtc.o ../build/obj/sdc.o ../build/obj/serial.o ../build/obj/serial_usb.o ../build/obj/spi.o ../build/obj/tm.o ../build/obj/uart.o ../build/obj/usb.o ../build/obj/stm32_dma.o ../build/obj/hal_lld.o ../build/obj/adc_lld.o ../build/obj/ext_lld_isr.o ../build/obj/can_lld.o ../build/obj/ext_lld.o ../build/obj/mac_lld.o ../build/obj/sdc_lld.o ../build/obj/pal_lld.o ../build/obj/i2c_lld.o ../build/obj/usb_lld.o ../build/obj/rtc_lld.o ../build/obj/spi_lld.o ../build/obj/gpt_lld.o ../build/obj/icu_lld.o ../build/obj/pwm_lld.o ../build/obj/serial_lld.o ../build/obj/uart_lld.o ../build/obj/board.o ../build/obj/lwipthread.o ../build/obj/sys_arch.o ../build/obj/etharp.o ../build/obj/dhcp.o ../build/obj/dns.o ../build/obj/init.o ../build/obj/mem.o ../build/obj/memp.o ../build/obj/netif.o ../build/obj/pbuf.o ../build/obj/raw.o ../build/obj/stats.o ../build/obj/sys.o ../build/obj/tcp.o ../build/obj/tcp_in.o ../build/obj/tcp_out.o ../build/obj/udp.o ../build/obj/autoip.o ../build/obj/icmp.o ../build/obj/igmp.o ../build/obj/inet.o ../build/obj/inet_chksum.o ../build/obj/ip.o ../build/obj/ip_addr.o ../build/obj/ip_frag.o ../build/obj/def.o ../build/obj/timers.o ../build/obj/api_lib.o ../build/obj/api_msg.o ../build/obj/err.o ../build/obj/netbuf.o ../build/obj/netdb.o ../build/obj/netifapi.o ../build/obj/sockets.o ../build/obj/tcpip.o ../build/obj/nonstd.o ../build/obj/stubs.o ../build/obj/rng_afm.o ../build/obj/chprintf.o ../build/obj/evtimer.o ../build/obj/syscalls.o ../build/obj/ch.o ../build/obj/list.o ../build/obj/dataBuffer.o ../build/obj/debugPrinter.o ../build/obj/connector.o ../build/obj/connection.o ../build/obj/connectionKey.o ../build/obj/lwipRawTcpConnector.o ../build/obj/lwipRawTcpConnection.o ../build/obj/lwipRawTcpBufferManager.o ../build/obj/jump.o ../build/obj/module.o ../build/obj/segment.o ../build/obj/base.o ../build/obj/message.o ../build/obj/state.o ../build/obj/worker.o ../build/obj/workerTicket.o ../build/obj/workerTimer.o ../build/obj/master.o ../build/obj/main.o -mcpu=cortex-m3 -O0 -ggdb -fomit-frame-pointer -falign-functions=16 -ffunction-sections -fdata-sections -fno-common -nostartfiles -Wl,-Map=../build/upm.map,--cref,--no-warn-mismatch,--library-path=,--script=../ChibiOS/os/ports/GCC/ARMCMx/STM32F4xx/ld/STM32F407xG_CCM.ld,--gc-sections -mno-thumb-interwork -mthumb -o ../build/upm.elf
c:/users/frank/chibi-eclipse/tools/gcc-arm-none-eabi-4_9-2015q2-20150609/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: address 0x10001220 of ../build/upm.elf section `.data' is not within region `ram'
c:/users/frank/chibi-eclipse/tools/gcc-arm-none-eabi-4_9-2015q2-20150609/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld.exe: address 0x1001740c of ../build/upm.elf section `.bss' is not within region `ram'
make: *** [../build/upm.elf] Error 1
The .data sections are ending up in the CCM.
I don't know much about linker scripts so any help would be appreciated. I could switch to ChibiOS/RT 3.0 if that will solve my problem.
Greetings
Frank
ChibiOS/RT 2.6.7 STM32F407 CCM linker error
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Re: ChibiOS/RT 2.6.7 STM32F407 CCM linker error
3.0 linker script allow for a more flexible allocation of objects in the various memory areas.
Switching to 3.1 made it the CCM work. Thank you very much.
Users browsing this forum: No registered users and 40 guests
