CAN High Level Driver States
neums
Has thanked: 10 times
Been thanked: 5 times
Postby neums » Tue Feb 23, 2016 10:17 am
in the documentation of the CAN driver's state machine are transitions from CAN_STARTING and READY to itselfs by calling canStart(). In code it is an illegal call/transition due to osalDbgAssert
void canStart(CANDriver *canp, const CANConfig *config) {
  osalDbgCheck(canp != NULL);
  osalSysLock();
  osalDbgAssert(canp->state == CAN_STOP, "invalid state");
Is this a bug?
Has thanked: 889 times
Been thanked: 769 times
Re: CAN High Level Driver States
Postby Giovanni » Tue Feb 23, 2016 11:00 am
It looks like a bug, I will look into it, queued for next release.
neums
Postby neums » Tue Feb 23, 2016 11:55 am
thanks for your help.
How i can restart the CAN when it is gone into BUS OFF without using the automatic bus off management (ABOM)?
I know that i can stop and start it again. But in the context where i want to restart it the CANConfig structure is not available due to my software structure. May it is a good feature to have a function which just restarts the driver or writes the RESET bit in MCR? So the configuration is unaffected but the CAN gets reset.
Postby Giovanni » Tue Feb 23, 2016 12:06 pm
All drivers keep a pointer to the configuration structure internally, do not assume that the structure is no more required after starting the driver, some drivers could incidentally work but the structure is supposed to be persistent.
neums
Postby neums » Tue Feb 23, 2016 12:49 pm
So a restart can be done with
canStart(&CAND1,&CAND1->config)
where the reset bit is set in the mcr register of the config structure?
Postby Giovanni » Tue Feb 23, 2016 2:17 pm
canStart reinitializes the CAN controller, see INRQ bit in the STM32 RM, then MCR is initialized again.
neums
Postby neums » Tue Feb 23, 2016 2:37 pm
OK that is the first way. But why not reset the CAN controller with an procedure like this:
// clear all transmit mailboxes
canp->can->TSR |= CAN_TSR_ABRQ0 | CAN_TSR_ABRQ1 | CAN_TSR_ABRQ2;
// reset CAN controller by setting the RESET BIT which is cleared again by hardware
canp->can->MCR |= CAN_MCR_RESET;
In this procedure the CANConfig structure is not needed because of the canStart call. So the user can reset the CAN controller in case of CAN High-Low short without the availability of the CANConfig structure which is required by canStart.
Postby Giovanni » Tue Feb 23, 2016 4:04 pm
To be placed where?
neums
Postby neums » Tue Feb 23, 2016 4:16 pm
Something like this in the LLD:
void can_lld_reset_controller(CANDriver *canp) {
and this in HLD:
void canResetController(CANDriver *canp) {
  osalSysLock();
  osalDbgAssert((canp->state == CAN_STOP) || (canp->state == CAN_READY),
                "invalid state");
  can_lld_reset_can_controller(canp);
  osalSysUnlock();
And if it makes sence an I-class function to reset the controller from the error callback.
Postby Giovanni » Sun Jan 06, 2019 5:09 pm
Moving topic.
Last bumped by Giovanni on Sun Jan 06, 2019 5:09 pm.
