I've tried to use PAL_LINE and associated macros on a STM32F103. Compiling fails due to stm32_gpio_t's definition is missing from GPIOv1's pal_lld.h
On devices which use GPIOv2 (e.g. STM32L152) it works without problems.
I'm using git branch stable_16.1.x
What are some possible solutions to enable PAL_LINE support on STM32F1xx? Switching over to GPIOv2 wouldn't work because of reported HW incompatibilities. Or is it necessary to patch ./os/hal/ports/STM32/LLD/GPIOv1/pal_lld.h ?
PAL_LINE on STM32F1xx
Re: PAL_LINE on STM32F1xx
The PAL driver for GPIOv1 already includes the required macros, it is just that board files for F1 devices do not include the LINE_ definitions. You could try to define them and verify the functionality of the driver.
A note, board files for STM32 non-F1 devices are generated automatically, it is easier to keep them up to date. F1 board files have to be edited manually.
Thank you for your answer. But I think there's a misunderstanding. The problem isn't that the macros are missing, because they're clearly there. And I'm using them already for other boards.
It is the missing definition for the type stm32_gpio_t in os/hal/ports/STM32/LLD/GPIOv1/pal_lld.h which is used by some of those macros which in turn causes those macros to fail.
I've wrote a patch that seem to fix the problem. I've haven't tested it yet thoroughly though.
Greb
Greb
From ddcce2d168cf8b6e2be56527f21cf5a5a4823e0e Mon Sep 17 00:00:00 2001
Date: Tue, 5 Apr 2016 14:41:24 +0200
Subject: [PATCH] Fix missing stm32_gpio_t for older boards
os/hal/ports/STM32/LLD/GPIOv1/pal_lld.h | 13 +++++++++++++
1 file changed, 13 insertions(+)
diff --git a/os/hal/ports/STM32/LLD/GPIOv1/pal_lld.h b/os/hal/ports/STM32/LLD/GPIOv1/pal_lld.h
index f2eb590..2cb4925 100644
--- a/os/hal/ports/STM32/LLD/GPIOv1/pal_lld.h
+++ b/os/hal/ports/STM32/LLD/GPIOv1/pal_lld.h
@@ -99,6 +99,19 @@
+ * @brief STM32 GPIO register block.
+typedef struct {
+ volatile uint32_t CRL;
+ volatile uint32_t CRH;
+ volatile uint32_t IDR;
+ volatile uint32_t ODR;
+ volatile uint32_t BSRR;
+ volatile uint32_t BRR;
+ volatile uint32_t LCKR;
+} stm32_gpio_t;
* @brief GPIO port setup info.
typedef struct {
2.6.2
It should work also by replacing stm32_gpio_t with GPIO_TypeDef, there is no need to redefine the structure.
I committed this change on trunk (bug #730).
