New Cortex-M GCC release directly from ARM ?!
DrunkenDonkey
Re: New Cortex-M GCC release directly from ARM ?!
It produces quite bigger (both chibi and codesourcery) binary for me, but since I don't have hardware (again) to test it, I'm all for official gcc
JetForMe wrote:Is this a toolchain that can run on Mac OS X?
Yes, should work for OS X if you rebuild it. I have a prebuilt one here, including the build script, for OS X and Linux: http://www.sidebranch.nl/cortexm3/
It is not bleeding-edge, but it is proven.
Regards,
Leon.
Hi guys,
Finally I reveal my Gentoo linux desktop and instal this prebuild compiler. It works fine, but if I call some functions from stdlib (asctime() for example) than I got compile errors:
Priviously I used Yagarto toolchain on WinXP and there was no such errors. So my question, is there way to avoid this errors withot defining my own stub functions?
/opt/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/armv7e-m/libc.a(lib_a-abort.o): In function `abort':
abort.c:(.text+0xa): undefined reference to `_exit'
/opt/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/armv7e-m/libc.a(lib_a-signalr.o): In function `_kill_r':
signalr.c:(.text+0xe): undefined reference to `_kill'
/opt/arm-none-eabi-gcc-4_6/bin/../lib/gcc/arm-none-eabi/4.6.2/../../../../arm-none-eabi/lib/armv7e-m/libc.a(lib_a-signalr.o): In function `_getpid_r':
signalr.c:(.text+0x28): undefined reference to `_getpid'Priviously I used Yagarto toolchain on WinXP and there was no such errors. So my question, is there way to avoid this errors withot defining my own stub functions?
Hello barthess,
I carry the following defines:
stubs.c:
and stubs.h
Haven't discovered any side effects ^^ (Greetings from Dubai Airport)
stubs.c:
* stubs.c
* Created on: Jul 10, 2011
* Author: mabl
#include <stdio.h>
#include "ch.h"
#include "hal.h"
#include "stubs.h"
// FIXME: Stubs - HATE THEM
void _exit(int status){
(void) status;
chSysHalt();
while(TRUE){}
pid_t _getpid(void){
return 1;
void _kill(pid_t id){
(void) id;
/* guard variables */
int __cxa_guard_acquire(__guard *g) {return !*(char *)(g);};
void __cxa_guard_release (__guard *g) {*(char *)g = 1;};
void __cxa_guard_abort (__guard * g __attribute__((unused))) {};
and stubs.h
* stubs.h
* Created on: Aug 6, 2011
* Author: mabl
#ifndef STUBS_H_
#define STUBS_H_
///* The ABI requires a 64-bit type. */
__extension__ typedef int __guard __attribute__((mode (__DI__)));
int __cxa_guard_acquire(__guard *);
void __cxa_guard_release (__guard *);
void __cxa_guard_abort (__guard *);
void *__dso_handle = NULL;
#endif /* STUBS_H_ */
DrunkenDonkey
They have released an updated version, that now generates way smaller code than yagarto and way faster, at least my RSA calcuation code went down 4k and encryption from 54 to 47 seconds, I'm officially in love with that toolchain now
Interesting, I ran the test scripts on it:
YAGARTO 4.6.2:
ARM GCC 4.6.2:
Performance is not much different, some TC a bit faster others a bit slower.
YAGARTO 4.6.2:
Platform : PowerPC
OS Setup : Full kernel
Compiler : powerpc-eabi-gcc (Sourcery G++ Lite 4.4-79) 4.4.1
Options : -O2 -DCH_OPTIMIZE_SPEED=TRUE
Kernel Size = 12136
Platform : PowerPC
Options : -O2 -DCH_OPTIMIZE_SPEED=FALSE
Kernel Size = 11660
Platform : PowerPC
OS Setup : Minimal kernel
Options : -O2
Kernel Size = 2196
Platform : PowerPC
Options : -Os -DCH_OPTIMIZE_SPEED=TRUE
Kernel Size = 10664
Platform : PowerPC
Options : -Os -DCH_OPTIMIZE_SPEED=FALSE
Kernel Size = 10124
Platform : PowerPC
Options : -Os
Kernel Size = 2220
Platform : ARM Cortex-M3
Compiler : arm-none-eabi-gcc (GCC) 4.6.2
Options : -O2 -mthumb -DCH_OPTIMIZE_SPEED=TRUE
Kernel Size = 6312
Options : -O2 -mthumb -DCH_OPTIMIZE_SPEED=FALSE
Kernel Size = 5892
Kernel Size = 1496
Options : -Os -mthumb -DCH_OPTIMIZE_SPEED=TRUE
Kernel Size = 5672
Options : -Os -mthumb -DCH_OPTIMIZE_SPEED=FALSE
Kernel Size = 5344
Kernel Size = 1332
Platform : ARM Cortex-M0
Kernel Size = 5628
Kernel Size = 5408
Kernel Size = 1356
Kernel Size = 5120
Kernel Size = 4968
Kernel Size = 1220
Platform : ARM7TDMI (ARM mode)
Kernel Size = 9424
Kernel Size = 8876
Options : -O2
Kernel Size = 1932
Kernel Size = 8616
Kernel Size = 8240
Options : -Os
Kernel Size = 1676
Platform : ARM7TDMI (THUMB mode)
Options : -O2 -mthumb -DCH_OPTIMIZE_SPEED=TRUE -DTHUMB -DTHUMB_PRESENT -DTHUMB_NO_INTERWORKING
Kernel Size = 6184
Options : -O2 -mthumb -DCH_OPTIMIZE_SPEED=FALSE -DTHUMB -DTHUMB_PRESENT -DTHUMB_NO_INTERWORKING
Kernel Size = 5948
Options : -O2 -mthumb -DTHUMB -DTHUMB_PRESENT -DTHUMB_NO_INTERWORKING
Kernel Size = 1384
Options : -Os -mthumb -DCH_OPTIMIZE_SPEED=TRUE -DTHUMB -DTHUMB_PRESENT -DTHUMB_NO_INTERWORKING
Kernel Size = 5700
Options : -Os -mthumb -DCH_OPTIMIZE_SPEED=FALSE -DTHUMB -DTHUMB_PRESENT -DTHUMB_NO_INTERWORKING
Kernel Size = 5512
Options : -Os -mthumb -DTHUMB -DTHUMB_PRESENT -DTHUMB_NO_INTERWORKING
Kernel Size = 1256
Platform : MSP430
Compiler : msp430-gcc (GCC) 4.6.3 20120301 (mspgcc LTS 20120406 unpatched)
Kernel Size = 6592
Platform : MSP430
Kernel Size = 6164
Platform : MSP430
Options : -O2
Kernel Size = 1164
Platform : MSP430
Kernel Size = 5888
Platform : MSP430
Kernel Size = 5584
Platform : MSP430
Options : -Os
Kernel Size = 988
ARM GCC 4.6.2:
Platform : PowerPC
Kernel Size = 12136
Platform : PowerPC
Kernel Size = 11660
Platform : PowerPC
Options : -O2
Kernel Size = 2196
Platform : PowerPC
Kernel Size = 10664
Platform : PowerPC
Kernel Size = 10124
Platform : PowerPC
Options : -Os
Kernel Size = 2220
Compiler : arm-none-eabi-gcc (GNU Tools for ARM Embedded Processors) 4.6.2 20120316 (release) [ARM/embedded-4_6-branch revision 185452]
Kernel Size = 6504
Kernel Size = 6060
Kernel Size = 1480
Kernel Size = 5624
Kernel Size = 5296
Kernel Size = 1316
Kernel Size = 5832
Kernel Size = 5600
Kernel Size = 1356
Kernel Size = 5120
Kernel Size = 4968
Kernel Size = 1220
Kernel Size = 9424
Kernel Size = 8876
Options : -O2
Kernel Size = 1932
Kernel Size = 8616
Kernel Size = 8240
Options : -Os
Kernel Size = 1676
Kernel Size = 6184
Kernel Size = 5948
Kernel Size = 1384
Kernel Size = 5700
Kernel Size = 5512
Kernel Size = 1256
Platform : MSP430
Kernel Size = 6592
Platform : MSP430
Kernel Size = 6164
Platform : MSP430
Options : -O2
Kernel Size = 1164
Platform : MSP430
Kernel Size = 5888
Platform : MSP430
Kernel Size = 5584
Platform : MSP430
Options : -Os
Kernel Size = 988
DrunkenDonkey
Great test suite you got there
I'm using only Os, quite flash size limited and went from 24 to 20 on the crypto code, maybe just hit something that ARM toolchain likes to optimize, mainly math in there. Btw you used the Update 1 they have posted right? Because with the original ARM 4.6.2 they posted yagarto was the winner
