#define icuGetPeriod(icup) icu_lld_get_period(icup) Topic is solved
dotaviper
Has thanked: 3 times
Post by dotaviper »
there is the following description in icu.h
* @brief Returns the width of the latest cycle.
* @details The cycle width is defined as number of ticks between a start
* edge and the next start edge.
* @note This function is meant to be invoked from the width capture
* callback only.
* @param[in] icup pointer to the @p ICUDriver object
* @return The number of ticks.
* @special
what is the meaning of the strart edge and the next start edge?
does it means the rising edge and the next rising edge? or the falling edge and the next falling edge?
expected your reply,thanks.
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Re: #define icuGetPeriod(icup) icu_lld_get_period(icup)
Post by RoccoMarco »
it depends on ICU configuration. If you have set ICU channel as ICU_INPUT_ACTIVE_HIGH it measure from a rising edge to next rising edge. Otherwise (ICU_INPUT_ACTIVE_LOW) from falling edge to next falling edge. Note that this configuration impacts also on icuGetWidth().
Hence, it is much more clear talk about start edge and stop edge.
RM
