Board generator templates path
omcdr
Has thanked: 7 times
Post by omcdr »
I'm trying to use board generator in ChibiStudio, I'm using board.chcfg from discovery F4.
I change name for four pins, click generate files from configuration data and nothing happen, console is empty.
If these links are correct in board.chcfg file ? I don't see these files
resources/gencfg/processors/boards/stm32f4xx/templates
http://www.chibios.org/xml/schema/boards/stm32f4xx_board.xsd
I have tried with "New->Other...->ChibiOS/RT->ChibiOS/RT Configuration Wizard" and the same problem.
steved
Has thanked: 12 times
Been thanked: 138 times
Re: Board generator templates path
Post by steved »
Make sure you have the file name highlighted in the left-hand window (Project Explorer).
The template files are somewhere in the Eclipse addin directories.
Correct, the .chcfg file needs to be selected in the project explorer then click the button that appears in the toolbar.
Files are usually generated in "..", the parent directory of the .chcfg file.
omcdr
Post by omcdr »
It's a magic, but working, thank you.
