SPI Write Collision
Moderator: tfAteba
Marco
Has thanked: 4 times
Been thanked: 11 times
SPI Write Collision
Post by Marco »
I found a bug in the AVR SPI driver.
When doing multiple multi-byte SPI write operations, the Write Collision Flag (WCOL) bit in SPI Status Register (SPSR) gets set.
This is caused by calling
_spi_isr_code(spip);
while the transmission is still in progress.
Attached is a patch to fix this issue.
Marco
hal_spi_lld_patch.zip
SPI Write Collision fix
(635 Bytes) Downloaded 533 times
utzig
Been thanked: 20 times
Re: SPI Write Collision
Post by utzig »
That patch doesn't seem to have been created against trunk. What version are you using?
Marco
Post by Marco »
No i'm sorry. I'm using the git mirror at commit 11eb96e. (svn://svn.code.sf.net/p/chibios/svn/trunk@9759).
Attached is the patch created against trunk.
hal_spi_lld.c.patch.zip
(575 Bytes) Downloaded 600 times
utzig
Post by utzig »
Both patches apply the same changes.
Marco
Post by Marco »
Yes, i just recreated the patch with TortoiseSVN on the SVN trunk. The changes are the same.
utzig
Post by utzig »
The problem seemed to arrive from using patch on Mac OS X with CRLF line endings...
Applied, thanks!
