facing problem with openOCD for F401RE
ep.hobbyiest
Has thanked: 4 times
Post by ep.hobbyiest »
I am using Nucleo401RE and chibi studio.
My OS version is Windows 10 - 64bit.
open ocd is giving following error.
Open On-Chip Debugger 0.10.0-dev-00107-ge4848fe (2015-11-13-11:49)
Licensed under GNU GPL v2
For bug reports, read
Warn : Interface already configured, ignoring
Error: already specified hl_layout stlink
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Unable to match requested speed 2000 kHz, using 1800 kHz
Info : clock speed 1800 kHz
Error: open failed
in procedure 'init'
in procedure 'ocd_bouncer'
I tried all .cfg file related to stm32f4xxx.cfg but not working.
Is this problem with chibi studio or open ocd or something else.
Re: facing problem with openOCD for F401RE
There are similar reports from other W10 users: viewtopic.php?f=13&t=3655
I don't have W10 but I know for sure OpenOCD should work, others used it.
ep.hobbyiest
Problem is solved now I tried with different ocd.
demant
Post by demant »
Hello, Can I Know Which openOCD you used to solve the problem? I tried with all available openOCD but I have not solved
ep.hobbyiest
I have downloaded the open OCD from following linkhttp://www.chibios.com/forum/viewto ... =13&t=3457
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Post by RoccoMarco »
this is the latest version of OpenOCD I have built
http://www.playembedded.org/blog/wp-content/uploads/2016/07/openocd.zip
can you give us a feedback after using it?
demant
Post by demant »
I tried the openocd provided by RoccoMarco but the problem persists while the link provided by ep.hobbyiest leads me to a blank page. However my problem might be different even though the message shown by Chibistudio is the same, because I can not connect even by ST-Link tool. My problem is described in more detail in this topic viewtopic.php?f=13&t=3655 . Thanks for support.
RoccoMarco
As said here, try to make a full chip erase with ST Link Utility.
Ciao
