STM32L4 support Topic is solved
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Re: STM32L4 support
Post by RoccoMarco »
Yes thanks. Let me know!
DEHiCKA
Has thanked: 4 times
Been thanked: 3 times
Re: STM32L4 support
Post by DEHiCKA »
No luck for me with RT-STM32L432KC-NUCLEO32-USB_CDC.
Onboard led stops blinking when cable is connected and "USB Device not recognized" on PC side.
Tried couple different cables, 1.5K pullup on D+ (ARD_D2), and D2/D10 pins to Alternate 10 mode before usbStart().
My connections:
ARD_D2 (PA12) -> 20 Ohm Res -> USB_DP (Green)
ARD_D10 (PA11) -> 20 Ohm Res -> USB_DM (White)
GND -> GND - BLack
RoccoMarco
Re: STM32L4 support
Note that pin should be set as alternate. I missed this in my demo.
DEHiCKA
Re: STM32L4 support
Post by DEHiCKA »
Yes, as I've mentioned they are set to alt10 before usb calls:
  palSetPadMode(GPIOA, GPIOA_ARD_D10, PAL_MODE_ALTERNATE(10));
  palSetPadMode(GPIOA, GPIOA_ARD_D2, PAL_MODE_ALTERNATE(10));
RoccoMarco
Re: STM32L4 support
Thanks I will take a look.
RoccoMarco
Re: STM32L4 support
Just ordered a USB breakout board.
Thanks to everyone
DEHiCKA
Re: STM32L4 support
Post by DEHiCKA »
I believe any old USB cable would do the job.
I've also did the clock source reconfigure to HSE bypass from onboard ST-LINK 8Mhz. No luck, still the same behavior:
exception at the descriptors read, when cable is connected.
DEHiCKA
Re: STM32L4 support
Post by DEHiCKA »
UPD: CubeMX + Keil simple USB CDC project runs fine with just a cable cut and connected to PA11 & PA12 & GND.
So it is not a harware or clock problem.
RoccoMarco
Re: STM32L4 support
Can you sent us the stack trace status when application stucks? The enumeration starts? It stucks when you connect the cable or it even if it is disconnected?
Edit: I have edited few things. Checkout trunk before perform tests.
DEHiCKA
Re: STM32L4 support
Post by DEHiCKA »
It stucks when the cable is connected. Updated lld and registry from trunk, no change:
Thread [1] (Suspended)
9 _unhandled_exception() vectors.c:46 0x08005580
8 <signal handler called>() 0xfffffff1
7 usb_lld_read_setup() hal_usb_lld.c:746 0x08003a7a
6 _usb_ep0setup() hal_usb.c:757 0x08003a7a
5 usb_serve_endpoints() hal_usb_lld.c:328 0x0800109c
4 Vector14C() hal_usb_lld.c:443 0x0800109c
3 <signal handler called>() 0xfffffffd
2 <symbol is not available> 0x55555554
1 <symbol is not available> 0x55555554
On PC side:
Unknown USB device
A request for the USB device descriptor failed.
