STM32L4 support Topic is solved
- RoccoMarco
- Has thanked: 83 times
- Been thanked: 67 times
Re: STM32L4 support
No luck for me with RT-STM32L432KC-NUCLEO32-USB_CDC.
Onboard led stops blinking when cable is connected and "USB Device not recognized" on PC side.
Tried couple different cables, 1.5K pullup on D+ (ARD_D2), and D2/D10 pins to Alternate 10 mode before usbStart().
My connections:
ARD_D2 (PA12) -> 20 Ohm Res -> USB_DP (Green)
ARD_D10 (PA11) -> 20 Ohm Res -> USB_DM (White)
GND -> GND - BLack
My connections:
GND -> GND - BLack
- RoccoMarco
Re: STM32L4 support
Yes, as I've mentioned they are set to alt10 before usb calls:
palSetPadMode(GPIOA, GPIOA_ARD_D10, PAL_MODE_ALTERNATE(10));
palSetPadMode(GPIOA, GPIOA_ARD_D2, PAL_MODE_ALTERNATE(10));- RoccoMarco
- RoccoMarco
Re: STM32L4 support
I believe any old USB cable would do the job.
I've also did the clock source reconfigure to HSE bypass from onboard ST-LINK 8Mhz. No luck, still the same behavior:
exception at the descriptors read, when cable is connected.
- RoccoMarco
Re: STM32L4 support
Can you sent us the stack trace status when application stucks? The enumeration starts? It stucks when you connect the cable or it even if it is disconnected?
Edit: I have edited few things. Checkout trunk before perform tests.
Re: STM32L4 support
It stucks when the cable is connected. Updated lld and registry from trunk, no change:
Thread [1] (Suspended)
9 _unhandled_exception() vectors.c:46 0x08005580
8 <signal handler called>() 0xfffffff1
7 usb_lld_read_setup() hal_usb_lld.c:746 0x08003a7a
6 _usb_ep0setup() hal_usb.c:757 0x08003a7a
5 usb_serve_endpoints() hal_usb_lld.c:328 0x0800109c
4 Vector14C() hal_usb_lld.c:443 0x0800109c
3 <signal handler called>() 0xfffffffd
2 <symbol is not available> 0x55555554
1 <symbol is not available> 0x55555554
On PC side:
Unknown USB device
A request for the USB device descriptor failed.
On PC side:
Unknown USB device
