Doubt on I2C LLD
Moderator: tfAteba
carldong
Doubt on I2C LLD
Post by carldong »
I am doubting the implementation of the AVR I2C LLD here. I run the testhal example, where the designated address is 0x50. However, on an oscilloscope, I found that 0xA0 was used as address. The IRQ is kind of big so I need some more time processing, but I do find a suspicious line:
    TWDR = (i2cp->addr << 1);
Which is exactly what makes 0x50 to be 0xA0. I don't know why it is there (without digging into the TWI docs), but it looks like the source of problems.
BTW, this is a snippet that allows full frequency range of AVR TWI/I2C, I modified from the ChibiOS 16.something.
void i2c_lld_start(I2CDriver *i2cp) {
  uint32_t clock_speed = 100000;
  // uint32_t clock_speed = 1000;
  /* TODO: Test TWI without external pull-ups (use internal) */
  if (i2cp->config != NULL)
    clock_speed = i2cp->config->clock_speed;
  uint32_t bdiv = ((F_CPU / clock_speed) - 16 ) / 2;
  if (bdiv < 256) {
    /* Configure prescaler to 1 */
    TWSR &= 0xF8;
    TWBR = bdiv;
  else if (bdiv < 1024) {
    /* Prescale 4.*/
    TWSR &= 0xF9;
    TWSR |= 0x01;
    TWBR = bdiv / 4;
  else if (bdiv < 4096) {
    TWSR &= 0xFA;
    TWSR |= 0x02;
    TWBR = bdiv / 16;
  else {
    TWSR &= 0xFB;
    TWSR |= 0x03;
    TWBR = bdiv / 64;
  /* Configure baudrate */
  // TWBR = ((F_CPU / clock_speed) - 16) / 2;
utzig
Been thanked: 20 times
Re: Doubt on I2C LLD
Post by utzig »
In I2C the address goes in the upper 7 bits and the LSb defines if it is a read or a write. So if you're reading 0xA0 you're actually sending to address 0x50.
carldong
Post by carldong »
utzig wrote:In I2C the address goes in the upper 7 bits and the LSb defines if it is a read or a write. So if you're reading 0xA0 you're actually sending to address 0x50.
That is exactly the problem. A write should give 0x50, while a read should give 0x51. Note that 0xA0 = 0x50 << 1. Also, there are multiple states in the IRQ, this action is performed on something about repeating(didn't see it for a few hours, so memory is blur). I have not located code for reading and writing data yet, but in my understanding, the left shift operation should not be executed when I am just trying to transmit.
carldong
Post by carldong »
I got it. Yeah, ChibiOS uses 7-bit addresses instead of the 8 given on my LCD datasheet. That is why there is the `<<1` operation... So I do need to manually convert address to 0x28.
utzig
Post by utzig »
That is not a ChibiOS thing. That is standard I2C. Your LCD manual may be providing the wrong address than. I'm curious, what LCD model is that? Where is the DS?
carldong
Post by carldong »
utzig wrote:That is not a ChibiOS thing. That is standard I2C. Your LCD manual may be providing the wrong address than. I'm curious, what LCD model is that? Where is the DS?
NHD-0420D3Z-NSW-BBW-V3 is the LCD. The specified I2C address ix 0x50. However, it is actually 0x28.
Also, a sample code I used (outside OS, that is) also uses 8-bit address.
Note that the oscilloscope I used also have the option to include R/W bit inside address. So I assume that this is a valid way to specify an address (the LCD DS specifically says the address "must be an even number", and it says "8-bit number").
