Build error on hal_usb_lld.c Topic is solved
josesimoes
Has thanked: 43 times
Been thanked: 23 times
Post by josesimoes »
This is in master branch.
Compiling with GCC give an error in hal_usb_lld.c line 295 because
asm
is unknown.
Replacing with
__asm
does build fine.
Re: Build error on hal_usb_lld.c
Which GCC are you using? asm is used everywhere.
josesimoes
v6-2017-q1 and if, it matters, c11
Moving this topic in bug reports.
That asm was a debug leftover, I just removed it.
josesimoes
awesome! thanks :)
networkfusion
Been thanked: 6 times
Post by networkfusion »
Is there any chance the GitHub repo can be synchronised so that this fix is available to us?
Many thanks,
Robin.
I don't manage it, try sending a private message to barthess, he does the synchronization.
If you are in a hurry then checkout the main subversion repository (trunk), you may also create your own git clone and update at will.
networkfusion
Thanks, will do.
