STM32F030F4 Serial Receive not working Topic is solved
robert_o
Been thanked: 6 times
Post by robert_o »
I ported Chibios to a STM32F030F4P6 with the help of this Forum. I also made a board file for the ebay moduel (https://www.ebay.de/itm/1PCS-STM32F030F ... SwSv1Xkte~)
LED blink and serial send works fine but serial receive does not. :(
[EDIT]
I also found some examples on Github: (https://github.com/ceremcem/chibi-examp ... r/examples) and there is a note: "stm32f030f4-uart example is added. But we can not read from serial yet" but no explanation why.
[/EDIT]
Any ideas why.
I changed the following files:
Folders:
C:\ChibiStudio\chibios176\os\hal\ports\STM32\STM32F0xx
Files:
hal_lld.h
stm32_registry.h
Folders:
C:\ChibiStudio\chibios176\os\common\ext\CMSIS\ST\STM32F0xx
Files:
stm32f0xx.h
stm32f030x4.h
Folders:
C:\ChibiStudio\chibios176\os\common\startup\ARMCMx\compilers\GCC\ld
Files:
STM32F030x4.ld
main.c
#include "ch.h"
#include "hal.h"
#include "chprintf.h"
#include "shell.h"
/* Command line related.                                                     */
//#define SHELL_WA_SIZE   THD_WORKING_AREA_SIZE(2048)
#define streq(s1, s2)   (strcmp((s1), (s2)) == 0)
//static BaseSequentialStream *const chout = (BaseSequentialStream *)&SD1;
static void cmd_tst(BaseSequentialStream *chp, int argc, char *argv[]) {
  (void)argv;
  if (argc > 0) {
    chprintf(chp, "Usage: tst \r\n");
    return;
  chprintf(chp, "This is a test \r\n");
  if (palReadPad(GPIOA, GPIOA_LED_GREEN)){
    palClearPad(GPIOA, GPIOA_LED_GREEN);
  else{
    palSetPad(GPIOA, GPIOA_LED_GREEN);
static const ShellCommand commands[] = {
   {"tst", cmd_tst},
   {NULL, NULL}
static const ShellConfig shell_cfg1 = {
   (BaseSequentialStream *)&SD1,
   commands
/* Command line related end.                                                 */
 * Application entry point.
int main(void) {
  thread_t *shelltp = NULL;
   * System initializations.
   *   RTOS is active.
  shellInit();
   * Activates the serial driver 1, PA9 and PA10 are routed to USART1.
  palSetPadMode(GPIOA, 9, PAL_MODE_ALTERNATE(1));       /* USART1 TX.       */
  palSetPadMode(GPIOA, 10, PAL_MODE_ALTERNATE(1));      /* USART1 RX.       */
  sdStart(&SD1, NULL);
  chprintf((BaseSequentialStream *)&SD1, "System started.\r\n");
   * Normal main() thread activity, in this demo it does nothing.
  while (true) {
    if (!shelltp) {
      /* Spawns a new shell.*/
      //shelltp = shellCreate(&shell_cfg1, SHELL_WA_SIZE, NORMALPRIO);
      shelltp = chThdCreateFromHeap(NULL, SHELL_WA_SIZE, "shell", NORMALPRIO, shellThread, (void *) &shell_cfg1);
    if (chThdTerminatedX(shelltp)) {
      /* Recovers memory of the previous shell.*/
      chThdRelease(shelltp);
      shelltp = NULL;
    chThdSleepMilliseconds(500);
Makefile
# Stack size to be allocated to the Cortex-M process stack. This stack is
# the stack used by the main() thread.
ifeq ($(USE_PROCESS_STACKSIZE),)
  USE_PROCESS_STACKSIZE = 0x200
endif
# Stack size to the allocated to the Cortex-M main/exceptions stack. This
# stack is used for processing interrupts and exceptions.
ifeq ($(USE_EXCEPTIONS_STACKSIZE),)
  USE_EXCEPTIONS_STACKSIZE = 0x200
endif
# Enables the use of FPU (no, softfp, hard).
ifeq ($(USE_FPU),)
  USE_FPU = no
endif
# Architecture or project specific options
# Project, sources and paths
# Define project name here
PROJECT = ch
# Imported source files and paths
CHIBIOS = ../../chibios176/
# Startup files.
include $(CHIBIOS)/os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32f0xx.mk
# HAL-OSAL files (optional).
include $(CHIBIOS)/os/hal/ports/STM32/STM32F0xx/platform.mk
include $(CHIBIOS)/os/hal/boards/China_STM32F030F4/board.mk
include $(CHIBIOS)/os/hal/osal/rt/osal.mk
# RTOS files (optional).
include $(CHIBIOS)/os/rt/rt.mk
include $(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/mk/port_v6m.mk
# Other files (optional).
#include $(CHIBIOS)/test/rt/test.mk
include $(CHIBIOS)/os/hal/lib/streams/streams.mk
include $(CHIBIOS)/os/various/shell/shell.mk
# Define linker script file here
LDSCRIPT= $(STARTUPLD)/STM32F030x4.ld
stm32_registry
#elif defined(STM32F030x4)
/* ADC attributes.*/
#define STM32_HAS_ADC1                      TRUE
#define STM32_HAS_ADC2                      FALSE
#define STM32_HAS_ADC3                      FALSE
#define STM32_HAS_ADC4                      FALSE
/* CAN attributes.*/
#define STM32_HAS_CAN1                      FALSE
#define STM32_HAS_CAN2                      FALSE
/* DAC attributes.*/
#define STM32_HAS_DAC1_CH1                  FALSE
#define STM32_HAS_DAC1_CH2                  FALSE
#define STM32_HAS_DAC2_CH1                  FALSE
#define STM32_HAS_DAC2_CH2                  FALSE
/* DMA attributes.*/
#define STM32_ADVANCED_DMA                  FALSE
#define STM32_HAS_DMA1                      TRUE
#define STM32_HAS_DMA2                      FALSE
//#define STM32_DMA_STREAMS                   5
#define STM32_DMA_SUPPORTS_CSELR            FALSE
#define STM32_DMA1_NUM_CHANNELS             5
#define STM32_DMA2_NUM_CHANNELS             0
#define STM32_DMA1_CH1_HANDLER              Vector64
#define STM32_DMA1_CH23_HANDLER             Vector68
#define STM32_DMA1_CH4567_HANDLER           Vector6C
#define STM32_DMA1_CH1_NUMBER               9
#define STM32_DMA1_CH23_NUMBER              10
#define STM32_DMA1_CH4567_NUMBER            11
#define STM32_DMA1_CH2_NUMBER               STM32_DMA1_CH23_NUMBER
#define STM32_DMA1_CH3_NUMBER               STM32_DMA1_CH23_NUMBER
#define DMA1_CH2_CMASK                      0x00000006U
#define DMA1_CH3_CMASK                      0x00000006U
#define STM32_DMA1_CH4_NUMBER               STM32_DMA1_CH4567_NUMBER
#define STM32_DMA1_CH5_NUMBER               STM32_DMA1_CH4567_NUMBER
#define STM32_DMA1_CH6_NUMBER               STM32_DMA1_CH4567_NUMBER
#define STM32_DMA1_CH7_NUMBER               STM32_DMA1_CH4567_NUMBER
#define DMA1_CH4_CMASK                      0x00000078U
#define DMA1_CH5_CMASK                      0x00000078U
#define DMA1_CH6_CMASK                      0x00000078U
#define DMA1_CH7_CMASK                      0x00000078U
/* ETH attributes.*/
#define STM32_HAS_ETH                       FALSE
/* EXTI attributes.*/
#define STM32_EXTI_NUM_CHANNELS             28
/* GPIO attributes.*/
#define STM32_HAS_GPIOA                     TRUE
#define STM32_HAS_GPIOB                     TRUE
#define STM32_HAS_GPIOC                     FALSE
#define STM32_HAS_GPIOD                     FALSE
#define STM32_HAS_GPIOE                     FALSE
#define STM32_HAS_GPIOF                     TRUE
#define STM32_HAS_GPIOG                     FALSE
#define STM32_HAS_GPIOH                     FALSE
#define STM32_HAS_GPIOI                     FALSE
#define STM32_HAS_GPIOJ                     FALSE
#define STM32_HAS_GPIOK                     FALSE
#define STM32_GPIO_EN_MASK                  (RCC_AHBENR_GPIOAEN |           \
                                             RCC_AHBENR_GPIOBEN |           \
                                             RCC_AHBENR_GPIOCEN |           \
                                             RCC_AHBENR_GPIODEN |           \
                                             RCC_AHBENR_GPIOFEN)
/* I2C attributes.*/
#define STM32_HAS_I2C1                      TRUE
#define STM32_I2C_I2C1_RX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 3)
#define STM32_I2C_I2C1_TX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 2)
#define STM32_HAS_I2C2                      FALSE
#define STM32_I2C_I2C2_RX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 5)
#define STM32_I2C_I2C2_TX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 4)
#define STM32_HAS_I2C3                      FALSE
/* RTC attributes.*/
#define STM32_HAS_RTC                       TRUE
#define STM32_RTC_HAS_SUBSECONDS            TRUE
#define STM32_RTC_HAS_PERIODIC_WAKEUPS      FALSE
#define STM32_RTC_NUM_ALARMS                1
#define STM32_RTC_HAS_INTERRUPTS            FALSE
/* SDIO attributes.*/
#define STM32_HAS_SDIO                      FALSE
/* SPI attributes.*/
#define STM32_HAS_SPI1                      TRUE
#define STM32_SPI_SPI1_RX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 2)
#define STM32_SPI_SPI1_TX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 3)
#define STM32_HAS_SPI2                      FALSE
#define STM32_SPI_SPI2_RX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 4)
#define STM32_SPI_SPI2_TX_DMA_STREAM        STM32_DMA_STREAM_ID(1, 5)
#define STM32_HAS_SPI3                      FALSE
#define STM32_HAS_SPI4                      FALSE
#define STM32_HAS_SPI5                      FALSE
#define STM32_HAS_SPI6                      FALSE
/* TIM attributes.*/
#define STM32_TIM_MAX_CHANNELS              4
#define STM32_HAS_TIM1                      TRUE
#define STM32_TIM1_IS_32BITS                FALSE
#define STM32_TIM1_CHANNELS                 4
#define STM32_HAS_TIM3                      TRUE
#define STM32_TIM3_IS_32BITS                FALSE
#define STM32_TIM3_CHANNELS                 4
#define STM32_HAS_TIM6                      FALSE
#define STM32_TIM6_IS_32BITS                FALSE
#define STM32_TIM6_CHANNELS                 0
#define STM32_HAS_TIM14                     TRUE
#define STM32_TIM14_IS_32BITS               FALSE
#define STM32_TIM14_CHANNELS                1
#define STM32_HAS_TIM15                     FALSE
#define STM32_TIM15_IS_32BITS               FALSE
#define STM32_TIM15_CHANNELS                2
#define STM32_HAS_TIM16                     TRUE
#define STM32_TIM16_IS_32BITS               FALSE
#define STM32_TIM16_CHANNELS                1
#define STM32_HAS_TIM17                     TRUE
#define STM32_TIM17_IS_32BITS               FALSE
#define STM32_TIM17_CHANNELS                1
#define STM32_HAS_TIM2                      FALSE
#define STM32_HAS_TIM4                      FALSE
#define STM32_HAS_TIM5                      FALSE
#define STM32_HAS_TIM7                      FALSE
#define STM32_HAS_TIM8                      FALSE
#define STM32_HAS_TIM9                      FALSE
#define STM32_HAS_TIM10                     FALSE
#define STM32_HAS_TIM11                     FALSE
#define STM32_HAS_TIM12                     FALSE
#define STM32_HAS_TIM13                     FALSE
#define STM32_HAS_TIM18                     FALSE
#define STM32_HAS_TIM19                     FALSE
/* USART attributes.*/
#define STM32_HAS_USART1                    TRUE
#define STM32_UART_USART1_RX_DMA_STREAM     STM32_DMA_STREAM_ID(1, 3)
#define STM32_UART_USART1_TX_DMA_STREAM     STM32_DMA_STREAM_ID(1, 2)
#define STM32_HAS_USART2                    FALSE
#define STM32_UART_USART2_RX_DMA_STREAM     STM32_DMA_STREAM_ID(1, 5)
#define STM32_UART_USART2_TX_DMA_STREAM     STM32_DMA_STREAM_ID(1, 4)
#define STM32_HAS_USART3                    FALSE
#define STM32_HAS_UART4                     FALSE
#define STM32_HAS_UART5                     FALSE
#define STM32_HAS_USART6                    FALSE
/* USB attributes.*/
#define STM32_HAS_USB                       FALSE
#define STM32_HAS_OTG1                      FALSE
#define STM32_HAS_OTG2                      FALSE
/* LTDC attributes.*/
#define STM32_HAS_LTDC                      FALSE
/* DMA2D attributes.*/
#define STM32_HAS_DMA2D                     FALSE
/* FSMC attributes.*/
#define STM32_HAS_FSMC                      FALSE
mcuconf.h
#define STM32F0xx_MCUCONF
 * HAL driver system settings.
#define STM32_HSI14_ENABLED                 TRUE
#define STM32_PREDIV_VALUE                  1
#define STM32_PLLMUL_VALUE                  6
#define STM32_PPRE                          STM32_PPRE_DIV1
#define STM32_ADCSW                         STM32_ADCSW_HSI14
#define STM32_ADCPRE                        STM32_ADCPRE_DIV4
#define STM32_MCOSEL                        STM32_MCOSEL_NOCLOCK
#define STM32_CECSW                         STM32_CECSW_HSI
#define STM32_I2C1SW                        STM32_I2C1SW_SYSCLK
#define STM32_USART1SW                      STM32_USART1SW_SYSCLK
#define STM32_RTCSEL                        STM32_RTCSEL_LSI
board.h
#ifndef BOARD_H
#define BOARD_H
 * Setup for STMicroelectronics STM32F030F4P6 China board.
 * Board identifier.
#define BOARD_China_STM32F030F4
#define BOARD_NAME                  "STMicroelectronics STM32F030F4P6 China"
 * Board oscillators-related settings.
 * NOTE: LSE not fitted.
#if !defined(STM32_LSECLK)
#define STM32_LSECLK                0U
#define STM32_LSEDRV                (3U << 3U)
#if !defined(STM32_HSECLK)
#define STM32_HSECLK                8000000U
 * MCU type as defined in the ST header.
#define STM32F030x4
 * IO pins assignments.
#define GPIOA_ARD_A0                0U
#define GPIOA_ADC1_IN0              0U
#define GPIOA_ARD_A1                1U
#define GPIOA_ADC1_IN1              1U
#define GPIOA_ARD_D1                2U
#define GPIOA_USART2_TX             2U
#define GPIOA_ARD_D0                3U
#define GPIOA_USART2_RX             3U
#define GPIOA_ARD_A2                4U
#define GPIOA_ADC1_IN4              4U
#define GPIOA_LED_GREEN             4U
#define GPIOA_ARD_D13               5U
#define GPIOA_ARD_D12               6U
#define GPIOA_ARD_D11               7U
#define GPIOA_ARD_D7                8U
#define GPIOA_USART1_TX             9U
#define GPIOA_USART1_RX             10U
#define GPIOA_PIN11                 11U
#define GPIOA_PIN12                 12U
#define GPIOA_SWDIO                 13U
#define GPIOA_SWCLK                 14U
#define GPIOA_PIN15                 15U
 * IO lines assignments.
#define LINE_ARD_A0                 PAL_LINE(GPIOA, 0U)
#define LINE_ADC1_IN0               PAL_LINE(GPIOA, 0U)
#define LINE_ARD_A1                 PAL_LINE(GPIOA, 1U)
#define LINE_ADC1_IN1               PAL_LINE(GPIOA, 1U)
#define LINE_ARD_D1                 PAL_LINE(GPIOA, 2U)
#define LINE_USART2_TX              PAL_LINE(GPIOA, 2U)
#define LINE_ARD_D0                 PAL_LINE(GPIOA, 3U)
#define LINE_USART2_RX              PAL_LINE(GPIOA, 3U)
#define LINE_ARD_A2                 PAL_LINE(GPIOA, 4U)
#define LINE_ADC1_IN4               PAL_LINE(GPIOA, 4U)
#define LINE_LED_GREEN              PAL_LINE(GPIOA, 4U)
#define LINE_ARD_D13                PAL_LINE(GPIOA, 5U)
#define LINE_ARD_D12                PAL_LINE(GPIOA, 6U)
#define LINE_ARD_D11                PAL_LINE(GPIOA, 7U)
#define LINE_ARD_D7                 PAL_LINE(GPIOA, 8U)
#define LINE_USART1_TX              PAL_LINE(GPIOA, 9U)
#define LINE_USART1_RX              PAL_LINE(GPIOA, 10U)
#define LINE_SWDIO                  PAL_LINE(GPIOA, 13U)
#define LINE_SWCLK                  PAL_LINE(GPIOA, 14U)
 * GPIOA setup:
 * PA0  - ARD_A0 ADC1_IN0           (input pullup).
 * PA1  - ARD_A1 ADC1_IN1           (input pullup).
 * PA2  - ARD_D1 USART2_TX          (alternate 1).
 * PA3  - ARD_D0 USART2_RX          (alternate 1).
 * PA4  - ARD_A2 ADC1_IN4 LED_GREEN (output pushpull maximum).
 * PA5  - ARD_D13                   (input floating).
 * PA6  - ARD_D12                   (input pullup).
 * PA7  - ARD_D11                   (input pullup).
 * PA8  - ARD_D7                    (input pullup).
 * PA9  - USART1_TX                 (alternate 1).
 * PA10 - USART1_RX                 (alternate 1).
 * PA11 - PIN11                     (input pullup).
 * PA12 - PIN12                     (input pullup).
 * PA13 - SWDIO                     (alternate 0).
 * PA14 - SWCLK                     (alternate 0).
 * PA15 - PIN15                     (input pullup).
#endif /* BOARD_H */
Re: STM32F030F4 Serial Receive not working
Your board.h is empty, make sure to generate correct board files.
robert_o
Post by robert_o »
I am sorry. I posted only the relevant lines becaue of the max. of 60000 characters. It is NOT empty.
    ChibiOS - Copyright (C) 2006..2016 Giovanni Di Sirio
 * This file has been automatically generated using ChibiStudio board
 * generator plugin. Do not edit manually.
#ifndef BOARD_H
#define BOARD_H
 * Board identifier.
#define STM32F030x4
#define GPIOB_ARD_A3                0U
#define GPIOB_ADC1_IN8              0U
#define GPIOB_PIN1                  1U
#define GPIOB_PIN2                  2U
#define GPIOB_SWO                   3U
#define GPIOB_ARD_D3                3U
#define GPIOB_ARD_D5                4U
#define GPIOB_ARD_D4                5U
#define GPIOB_ARD_D10               6U
#define GPIOB_PIN7                  7U
#define GPIOB_ARD_D15               8U
#define GPIOB_ARD_D14               9U
#define GPIOB_ARD_D6                10U
#define GPIOB_PIN11                 11U
#define GPIOB_PIN12                 12U
#define GPIOB_PIN13                 13U
#define GPIOB_PIN14                 14U
#define GPIOB_PIN15                 15U
#define GPIOC_ARD_A5                0U
#define GPIOC_ADC1_IN11             0U
#define GPIOC_ARD_A4                1U
#define GPIOC_ADC1_IN10             1U
#define GPIOC_PIN2                  2U
#define GPIOC_PIN3                  3U
#define GPIOC_PIN4                  4U
#define GPIOC_PIN5                  5U
#define GPIOC_PIN6                  6U
#define GPIOC_ARD_D9                7U
#define GPIOC_PIN8                  8U
#define GPIOC_PIN9                  9U
#define GPIOC_PIN10                 10U
#define GPIOC_PIN11                 11U
#define GPIOC_PIN12                 12U
#define GPIOC_BUTTON                13U
#define GPIOC_OSC32_IN              14U
#define GPIOC_OSC32_OUT             15U
#define GPIOD_PIN0                  0U
#define GPIOD_PIN1                  1U
#define GPIOD_PIN2                  2U
#define GPIOD_PIN3                  3U
#define GPIOD_PIN4                  4U
#define GPIOD_PIN5                  5U
#define GPIOD_PIN6                  6U
#define GPIOD_PIN7                  7U
#define GPIOD_PIN8                  8U
#define GPIOD_PIN9                  9U
#define GPIOD_PIN10                 10U
#define GPIOD_PIN11                 11U
#define GPIOD_PIN12                 12U
#define GPIOD_PIN13                 13U
#define GPIOD_PIN14                 14U
#define GPIOD_PIN15                 15U
#define GPIOF_OSC_IN                0U
#define GPIOF_OSC_OUT               1U
#define GPIOF_PIN2                  2U
#define GPIOF_PIN3                  3U
#define GPIOF_PIN4                  4U
#define GPIOF_PIN5                  5U
#define GPIOF_PIN6                  6U
#define GPIOF_PIN7                  7U
#define GPIOF_PIN8                  8U
#define GPIOF_PIN9                  9U
#define GPIOF_PIN10                 10U
#define GPIOF_PIN11                 11U
#define GPIOF_PIN12                 12U
#define GPIOF_PIN13                 13U
#define GPIOF_PIN14                 14U
#define GPIOF_PIN15                 15U
#define LINE_ARD_A3                 PAL_LINE(GPIOB, 0U)
#define LINE_ADC1_IN8               PAL_LINE(GPIOB, 0U)
#define LINE_SWO                    PAL_LINE(GPIOB, 3U)
#define LINE_ARD_D3                 PAL_LINE(GPIOB, 3U)
#define LINE_ARD_D5                 PAL_LINE(GPIOB, 4U)
#define LINE_ARD_D4                 PAL_LINE(GPIOB, 5U)
#define LINE_ARD_D10                PAL_LINE(GPIOB, 6U)
#define LINE_ARD_D15                PAL_LINE(GPIOB, 8U)
#define LINE_ARD_D14                PAL_LINE(GPIOB, 9U)
#define LINE_ARD_D6                 PAL_LINE(GPIOB, 10U)
#define LINE_ARD_A5                 PAL_LINE(GPIOC, 0U)
#define LINE_ADC1_IN11              PAL_LINE(GPIOC, 0U)
#define LINE_ARD_A4                 PAL_LINE(GPIOC, 1U)
#define LINE_ADC1_IN10              PAL_LINE(GPIOC, 1U)
#define LINE_ARD_D9                 PAL_LINE(GPIOC, 7U)
#define LINE_BUTTON                 PAL_LINE(GPIOC, 13U)
#define LINE_OSC32_IN               PAL_LINE(GPIOC, 14U)
#define LINE_OSC32_OUT              PAL_LINE(GPIOC, 15U)
#define LINE_OSC_IN                 PAL_LINE(GPIOF, 0U)
#define LINE_OSC_OUT                PAL_LINE(GPIOF, 1U)
 * I/O ports initial setup, this configuration is established soon after reset
 * in the initialization code.
 * Please refer to the STM32 Reference Manual for details.
#define PIN_MODE_INPUT(n)           (0U << ((n) * 2U))
#define PIN_MODE_OUTPUT(n)          (1U << ((n) * 2U))
#define PIN_MODE_ALTERNATE(n)       (2U << ((n) * 2U))
#define PIN_MODE_ANALOG(n)          (3U << ((n) * 2U))
#define PIN_ODR_LOW(n)              (0U << (n))
#define PIN_ODR_HIGH(n)             (1U << (n))
#define PIN_OTYPE_PUSHPULL(n)       (0U << (n))
#define PIN_OTYPE_OPENDRAIN(n)      (1U << (n))
#define PIN_OSPEED_VERYLOW(n)       (0U << ((n) * 2U))
#define PIN_OSPEED_LOW(n)           (1U << ((n) * 2U))
#define PIN_OSPEED_MEDIUM(n)        (2U << ((n) * 2U))
#define PIN_OSPEED_HIGH(n)          (3U << ((n) * 2U))
#define PIN_PUPDR_FLOATING(n)       (0U << ((n) * 2U))
#define PIN_PUPDR_PULLUP(n)         (1U << ((n) * 2U))
#define PIN_PUPDR_PULLDOWN(n)       (2U << ((n) * 2U))
#define PIN_AFIO_AF(n, v)           ((v) << (((n) % 8U) * 4U))
 * GPIOA setup:
#define VAL_GPIOA_MODER             (PIN_MODE_INPUT(GPIOA_ARD_A0) |         \
                                     PIN_MODE_INPUT(GPIOA_ARD_A1) |         \
                                     PIN_MODE_ALTERNATE(GPIOA_ARD_D1) |     \
                                     PIN_MODE_ALTERNATE(GPIOA_ARD_D0) |     \
                                     PIN_MODE_OUTPUT(GPIOA_ARD_A2) |        \
                                     PIN_MODE_INPUT(GPIOA_ARD_D13) |        \
                                     PIN_MODE_INPUT(GPIOA_ARD_D12) |        \
                                     PIN_MODE_INPUT(GPIOA_ARD_D11) |        \
                                     PIN_MODE_INPUT(GPIOA_ARD_D7) |         \
                                     PIN_MODE_ALTERNATE(GPIOA_USART1_TX) |  \
                                     PIN_MODE_ALTERNATE(GPIOA_USART1_RX) |  \
                                     PIN_MODE_INPUT(GPIOA_PIN11) |          \
                                     PIN_MODE_INPUT(GPIOA_PIN12) |          \
                                     PIN_MODE_ALTERNATE(GPIOA_SWDIO) |      \
                                     PIN_MODE_ALTERNATE(GPIOA_SWCLK) |      \
                                     PIN_MODE_INPUT(GPIOA_PIN15))
#define VAL_GPIOA_OTYPER            (PIN_OTYPE_PUSHPULL(GPIOA_ARD_A0) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ARD_A1) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ARD_D1) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ARD_D0) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ARD_A2) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ARD_D13) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ARD_D12) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ARD_D11) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOA_ARD_D7) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_USART1_TX) |  \
                                     PIN_OTYPE_PUSHPULL(GPIOA_USART1_RX) |  \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN11) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN12) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SWDIO) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SWCLK) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN15))
#define VAL_GPIOA_OSPEEDR           (PIN_OSPEED_HIGH(GPIOA_ARD_A0) |        \
                                     PIN_OSPEED_HIGH(GPIOA_ARD_A1) |        \
                                     PIN_OSPEED_LOW(GPIOA_ARD_D1) |         \
                                     PIN_OSPEED_LOW(GPIOA_ARD_D0) |         \
                                     PIN_OSPEED_HIGH(GPIOA_ARD_A2) |        \
                                     PIN_OSPEED_LOW(GPIOA_ARD_D13) |        \
                                     PIN_OSPEED_HIGH(GPIOA_ARD_D12) |       \
                                     PIN_OSPEED_HIGH(GPIOA_ARD_D11) |       \
                                     PIN_OSPEED_HIGH(GPIOA_ARD_D7) |        \
                                     PIN_OSPEED_LOW(GPIOA_USART1_TX) |      \
                                     PIN_OSPEED_LOW(GPIOA_USART1_RX) |      \
                                     PIN_OSPEED_HIGH(GPIOA_PIN11) |         \
                                     PIN_OSPEED_HIGH(GPIOA_PIN12) |         \
                                     PIN_OSPEED_HIGH(GPIOA_SWDIO) |         \
                                     PIN_OSPEED_HIGH(GPIOA_SWCLK) |         \
                                     PIN_OSPEED_HIGH(GPIOA_PIN15))
#define VAL_GPIOA_PUPDR             (PIN_PUPDR_PULLUP(GPIOA_ARD_A0) |       \
                                     PIN_PUPDR_PULLUP(GPIOA_ARD_A1) |       \
                                     PIN_PUPDR_FLOATING(GPIOA_ARD_D1) |     \
                                     PIN_PUPDR_PULLUP(GPIOA_ARD_D0) |       \
                                     PIN_PUPDR_FLOATING(GPIOA_ARD_A2) |     \
                                     PIN_PUPDR_FLOATING(GPIOA_ARD_D13) |    \
                                     PIN_PUPDR_PULLUP(GPIOA_ARD_D12) |      \
                                     PIN_PUPDR_PULLUP(GPIOA_ARD_D11) |      \
                                     PIN_PUPDR_PULLUP(GPIOA_ARD_D7) |       \
                                     PIN_PUPDR_FLOATING(GPIOA_USART1_TX) |  \
                                     PIN_PUPDR_FLOATING(GPIOA_USART1_RX) |  \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN11) |        \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN12) |        \
                                     PIN_PUPDR_PULLUP(GPIOA_SWDIO) |        \
                                     PIN_PUPDR_PULLDOWN(GPIOA_SWCLK) |      \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN15))
#define VAL_GPIOA_ODR               (PIN_ODR_HIGH(GPIOA_ARD_A0) |           \
                                     PIN_ODR_HIGH(GPIOA_ARD_A1) |           \
                                     PIN_ODR_HIGH(GPIOA_ARD_D1) |           \
                                     PIN_ODR_HIGH(GPIOA_ARD_D0) |           \
                                     PIN_ODR_HIGH(GPIOA_ARD_A2) |           \
                                     PIN_ODR_LOW(GPIOA_ARD_D13) |           \
                                     PIN_ODR_HIGH(GPIOA_ARD_D12) |          \
                                     PIN_ODR_HIGH(GPIOA_ARD_D11) |          \
                                     PIN_ODR_HIGH(GPIOA_ARD_D7) |           \
                                     PIN_ODR_HIGH(GPIOA_USART1_TX) |        \
                                     PIN_ODR_HIGH(GPIOA_USART1_RX) |        \
                                     PIN_ODR_HIGH(GPIOA_PIN11) |            \
                                     PIN_ODR_HIGH(GPIOA_PIN12) |            \
                                     PIN_ODR_HIGH(GPIOA_SWDIO) |            \
                                     PIN_ODR_HIGH(GPIOA_SWCLK) |            \
                                     PIN_ODR_HIGH(GPIOA_PIN15))
#define VAL_GPIOA_AFRL              (PIN_AFIO_AF(GPIOA_ARD_A0, 0U) |        \
                                     PIN_AFIO_AF(GPIOA_ARD_A1, 0U) |        \
                                     PIN_AFIO_AF(GPIOA_ARD_D1, 1U) |        \
                                     PIN_AFIO_AF(GPIOA_ARD_D0, 1U) |        \
                                     PIN_AFIO_AF(GPIOA_ARD_A2, 0U) |        \
                                     PIN_AFIO_AF(GPIOA_ARD_D13, 0U) |       \
                                     PIN_AFIO_AF(GPIOA_ARD_D12, 0U) |       \
                                     PIN_AFIO_AF(GPIOA_ARD_D11, 0U))
#define VAL_GPIOA_AFRH              (PIN_AFIO_AF(GPIOA_ARD_D7, 0U) |        \
                                     PIN_AFIO_AF(GPIOA_USART1_TX, 1U) |     \
                                     PIN_AFIO_AF(GPIOA_USART1_RX, 1U) |     \
                                     PIN_AFIO_AF(GPIOA_PIN11, 0U) |         \
                                     PIN_AFIO_AF(GPIOA_PIN12, 0U) |         \
                                     PIN_AFIO_AF(GPIOA_SWDIO, 0U) |         \
                                     PIN_AFIO_AF(GPIOA_SWCLK, 0U) |         \
                                     PIN_AFIO_AF(GPIOA_PIN15, 0U))
 * GPIOB setup:
 * PB0  - ARD_A3 ADC1_IN8           (input pullup).
 * PB1  - PIN1                      (input pullup).
 * PB2  - PIN2                      (input pullup).
 * PB3  - SWO ARD_D3                (alternate 0).
 * PB4  - ARD_D5                    (input pullup).
 * PB5  - ARD_D4                    (input pullup).
 * PB6  - ARD_D10                   (input pullup).
 * PB7  - PIN7                      (input pullup).
 * PB8  - ARD_D15                   (input pullup).
 * PB9  - ARD_D14                   (input pullup).
 * PB10 - ARD_D6                    (input pullup).
 * PB11 - PIN11                     (input pullup).
 * PB12 - PIN12                     (input pullup).
 * PB13 - PIN13                     (input pullup).
 * PB14 - PIN14                     (input pullup).
 * PB15 - PIN15                     (input pullup).
#define VAL_GPIOB_MODER             (PIN_MODE_INPUT(GPIOB_ARD_A3) |         \
                                     PIN_MODE_INPUT(GPIOB_PIN1) |           \
                                     PIN_MODE_INPUT(GPIOB_PIN2) |           \
                                     PIN_MODE_ALTERNATE(GPIOB_SWO) |        \
                                     PIN_MODE_INPUT(GPIOB_ARD_D5) |         \
                                     PIN_MODE_INPUT(GPIOB_ARD_D4) |         \
                                     PIN_MODE_INPUT(GPIOB_ARD_D10) |        \
                                     PIN_MODE_INPUT(GPIOB_PIN7) |           \
                                     PIN_MODE_INPUT(GPIOB_ARD_D15) |        \
                                     PIN_MODE_INPUT(GPIOB_ARD_D14) |        \
                                     PIN_MODE_INPUT(GPIOB_ARD_D6) |         \
                                     PIN_MODE_INPUT(GPIOB_PIN11) |          \
                                     PIN_MODE_INPUT(GPIOB_PIN12) |          \
                                     PIN_MODE_INPUT(GPIOB_PIN13) |          \
                                     PIN_MODE_INPUT(GPIOB_PIN14) |          \
                                     PIN_MODE_INPUT(GPIOB_PIN15))
#define VAL_GPIOB_OTYPER            (PIN_OTYPE_PUSHPULL(GPIOB_ARD_A3) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOB_PIN1) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOB_PIN2) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOB_SWO) |        \
                                     PIN_OTYPE_PUSHPULL(GPIOB_ARD_D5) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOB_ARD_D4) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOB_ARD_D10) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOB_PIN7) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOB_ARD_D15) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOB_ARD_D14) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOB_ARD_D6) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOB_PIN11) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOB_PIN12) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOB_PIN13) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOB_PIN14) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOB_PIN15))
#define VAL_GPIOB_OSPEEDR           (PIN_OSPEED_HIGH(GPIOB_ARD_A3) |        \
                                     PIN_OSPEED_HIGH(GPIOB_PIN1) |          \
                                     PIN_OSPEED_HIGH(GPIOB_PIN2) |          \
                                     PIN_OSPEED_HIGH(GPIOB_SWO) |           \
                                     PIN_OSPEED_HIGH(GPIOB_ARD_D5) |        \
                                     PIN_OSPEED_HIGH(GPIOB_ARD_D4) |        \
                                     PIN_OSPEED_HIGH(GPIOB_ARD_D10) |       \
                                     PIN_OSPEED_HIGH(GPIOB_PIN7) |          \
                                     PIN_OSPEED_HIGH(GPIOB_ARD_D15) |       \
                                     PIN_OSPEED_HIGH(GPIOB_ARD_D14) |       \
                                     PIN_OSPEED_HIGH(GPIOB_ARD_D6) |        \
                                     PIN_OSPEED_HIGH(GPIOB_PIN11) |         \
                                     PIN_OSPEED_HIGH(GPIOB_PIN12) |         \
                                     PIN_OSPEED_HIGH(GPIOB_PIN13) |         \
                                     PIN_OSPEED_HIGH(GPIOB_PIN14) |         \
                                     PIN_OSPEED_HIGH(GPIOB_PIN15))
#define VAL_GPIOB_PUPDR             (PIN_PUPDR_PULLUP(GPIOB_ARD_A3) |       \
                                     PIN_PUPDR_PULLUP(GPIOB_PIN1) |         \
                                     PIN_PUPDR_PULLUP(GPIOB_PIN2) |         \
                                     PIN_PUPDR_PULLUP(GPIOB_SWO) |          \
                                     PIN_PUPDR_PULLUP(GPIOB_ARD_D5) |       \
                                     PIN_PUPDR_PULLUP(GPIOB_ARD_D4) |       \
                                     PIN_PUPDR_PULLUP(GPIOB_ARD_D10) |      \
                                     PIN_PUPDR_PULLUP(GPIOB_PIN7) |         \
                                     PIN_PUPDR_PULLUP(GPIOB_ARD_D15) |      \
                                     PIN_PUPDR_PULLUP(GPIOB_ARD_D14) |      \
                                     PIN_PUPDR_PULLUP(GPIOB_ARD_D6) |       \
                                     PIN_PUPDR_PULLUP(GPIOB_PIN11) |        \
                                     PIN_PUPDR_PULLUP(GPIOB_PIN12) |        \
                                     PIN_PUPDR_PULLUP(GPIOB_PIN13) |        \
                                     PIN_PUPDR_PULLUP(GPIOB_PIN14) |        \
                                     PIN_PUPDR_PULLUP(GPIOB_PIN15))
#define VAL_GPIOB_ODR               (PIN_ODR_HIGH(GPIOB_ARD_A3) |           \
                                     PIN_ODR_HIGH(GPIOB_PIN1) |             \
                                     PIN_ODR_HIGH(GPIOB_PIN2) |             \
                                     PIN_ODR_HIGH(GPIOB_SWO) |              \
                                     PIN_ODR_HIGH(GPIOB_ARD_D5) |           \
                                     PIN_ODR_HIGH(GPIOB_ARD_D4) |           \
                                     PIN_ODR_HIGH(GPIOB_ARD_D10) |          \
                                     PIN_ODR_HIGH(GPIOB_PIN7) |             \
                                     PIN_ODR_HIGH(GPIOB_ARD_D15) |          \
                                     PIN_ODR_HIGH(GPIOB_ARD_D14) |          \
                                     PIN_ODR_HIGH(GPIOB_ARD_D6) |           \
                                     PIN_ODR_HIGH(GPIOB_PIN11) |            \
                                     PIN_ODR_HIGH(GPIOB_PIN12) |            \
                                     PIN_ODR_HIGH(GPIOB_PIN13) |            \
                                     PIN_ODR_HIGH(GPIOB_PIN14) |            \
                                     PIN_ODR_HIGH(GPIOB_PIN15))
#define VAL_GPIOB_AFRL              (PIN_AFIO_AF(GPIOB_ARD_A3, 0U) |        \
                                     PIN_AFIO_AF(GPIOB_PIN1, 0U) |          \
                                     PIN_AFIO_AF(GPIOB_PIN2, 0U) |          \
                                     PIN_AFIO_AF(GPIOB_SWO, 0U) |           \
                                     PIN_AFIO_AF(GPIOB_ARD_D5, 0U) |        \
                                     PIN_AFIO_AF(GPIOB_ARD_D4, 0U) |        \
                                     PIN_AFIO_AF(GPIOB_ARD_D10, 0U) |       \
                                     PIN_AFIO_AF(GPIOB_PIN7, 0U))
#define VAL_GPIOB_AFRH              (PIN_AFIO_AF(GPIOB_ARD_D15, 0U) |       \
                                     PIN_AFIO_AF(GPIOB_ARD_D14, 0U) |       \
                                     PIN_AFIO_AF(GPIOB_ARD_D6, 0U) |        \
                                     PIN_AFIO_AF(GPIOB_PIN11, 0U) |         \
                                     PIN_AFIO_AF(GPIOB_PIN12, 0U) |         \
                                     PIN_AFIO_AF(GPIOB_PIN13, 0U) |         \
                                     PIN_AFIO_AF(GPIOB_PIN14, 0U) |         \
                                     PIN_AFIO_AF(GPIOB_PIN15, 0U))
 * GPIOC setup:
 * PC0  - ARD_A5 ADC1_IN11          (input pullup).
 * PC1  - ARD_A4 ADC1_IN10          (input pullup).
 * PC2  - PIN2                      (input pullup).
 * PC3  - PIN3                      (input pullup).
 * PC4  - PIN4                      (input pullup).
 * PC5  - PIN5                      (input pullup).
 * PC6  - PIN6                      (input pullup).
 * PC7  - ARD_D9                    (input pullup).
 * PC8  - PIN8                      (input pullup).
 * PC9  - PIN9                      (input pullup).
 * PC10 - PIN10                     (input pullup).
 * PC11 - PIN11                     (input pullup).
 * PC12 - PIN12                     (input pullup).
 * PC13 - BUTTON                    (input floating).
 * PC14 - OSC32_IN                  (input floating).
 * PC15 - OSC32_OUT                 (input floating).
#define VAL_GPIOC_MODER             (PIN_MODE_INPUT(GPIOC_ARD_A5) |         \
                                     PIN_MODE_INPUT(GPIOC_ARD_A4) |         \
                                     PIN_MODE_INPUT(GPIOC_PIN2) |           \
                                     PIN_MODE_INPUT(GPIOC_PIN3) |           \
                                     PIN_MODE_INPUT(GPIOC_PIN4) |           \
                                     PIN_MODE_INPUT(GPIOC_PIN5) |           \
                                     PIN_MODE_INPUT(GPIOC_PIN6) |           \
                                     PIN_MODE_INPUT(GPIOC_ARD_D9) |         \
                                     PIN_MODE_INPUT(GPIOC_PIN8) |           \
                                     PIN_MODE_INPUT(GPIOC_PIN9) |           \
                                     PIN_MODE_INPUT(GPIOC_PIN10) |          \
                                     PIN_MODE_INPUT(GPIOC_PIN11) |          \
                                     PIN_MODE_INPUT(GPIOC_PIN12) |          \
                                     PIN_MODE_INPUT(GPIOC_BUTTON) |         \
                                     PIN_MODE_INPUT(GPIOC_OSC32_IN) |       \
                                     PIN_MODE_INPUT(GPIOC_OSC32_OUT))
#define VAL_GPIOC_OTYPER            (PIN_OTYPE_PUSHPULL(GPIOC_ARD_A5) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOC_ARD_A4) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN2) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN3) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN4) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN5) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN6) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOC_ARD_D9) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN8) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN9) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN10) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN11) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOC_PIN12) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOC_BUTTON) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOC_OSC32_IN) |   \
                                     PIN_OTYPE_PUSHPULL(GPIOC_OSC32_OUT))
#define VAL_GPIOC_OSPEEDR           (PIN_OSPEED_HIGH(GPIOC_ARD_A5) |        \
                                     PIN_OSPEED_HIGH(GPIOC_ARD_A4) |        \
                                     PIN_OSPEED_HIGH(GPIOC_PIN2) |          \
                                     PIN_OSPEED_HIGH(GPIOC_PIN3) |          \
                                     PIN_OSPEED_HIGH(GPIOC_PIN4) |          \
                                     PIN_OSPEED_HIGH(GPIOC_PIN5) |          \
                                     PIN_OSPEED_HIGH(GPIOC_PIN6) |          \
                                     PIN_OSPEED_HIGH(GPIOC_ARD_D9) |        \
                                     PIN_OSPEED_HIGH(GPIOC_PIN8) |          \
                                     PIN_OSPEED_HIGH(GPIOC_PIN9) |          \
                                     PIN_OSPEED_HIGH(GPIOC_PIN10) |         \
                                     PIN_OSPEED_HIGH(GPIOC_PIN11) |         \
                                     PIN_OSPEED_HIGH(GPIOC_PIN12) |         \
                                     PIN_OSPEED_HIGH(GPIOC_BUTTON) |        \
                                     PIN_OSPEED_HIGH(GPIOC_OSC32_IN) |      \
                                     PIN_OSPEED_HIGH(GPIOC_OSC32_OUT))
#define VAL_GPIOC_PUPDR             (PIN_PUPDR_PULLUP(GPIOC_ARD_A5) |       \
                                     PIN_PUPDR_PULLUP(GPIOC_ARD_A4) |       \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN2) |         \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN3) |         \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN4) |         \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN5) |         \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN6) |         \
                                     PIN_PUPDR_PULLUP(GPIOC_ARD_D9) |       \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN8) |         \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN9) |         \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN10) |        \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN11) |        \
                                     PIN_PUPDR_PULLUP(GPIOC_PIN12) |        \
                                     PIN_PUPDR_FLOATING(GPIOC_BUTTON) |     \
                                     PIN_PUPDR_FLOATING(GPIOC_OSC32_IN) |   \
                                     PIN_PUPDR_FLOATING(GPIOC_OSC32_OUT))
#define VAL_GPIOC_ODR               (PIN_ODR_HIGH(GPIOC_ARD_A5) |           \
                                     PIN_ODR_HIGH(GPIOC_ARD_A4) |           \
                                     PIN_ODR_HIGH(GPIOC_PIN2) |             \
                                     PIN_ODR_HIGH(GPIOC_PIN3) |             \
                                     PIN_ODR_HIGH(GPIOC_PIN4) |             \
                                     PIN_ODR_HIGH(GPIOC_PIN5) |             \
                                     PIN_ODR_HIGH(GPIOC_PIN6) |             \
                                     PIN_ODR_HIGH(GPIOC_ARD_D9) |           \
                                     PIN_ODR_HIGH(GPIOC_PIN8) |             \
                                     PIN_ODR_HIGH(GPIOC_PIN9) |             \
                                     PIN_ODR_HIGH(GPIOC_PIN10) |            \
                                     PIN_ODR_HIGH(GPIOC_PIN11) |            \
                                     PIN_ODR_HIGH(GPIOC_PIN12) |            \
                                     PIN_ODR_HIGH(GPIOC_BUTTON) |           \
                                     PIN_ODR_HIGH(GPIOC_OSC32_IN) |         \
                                     PIN_ODR_HIGH(GPIOC_OSC32_OUT))
#define VAL_GPIOC_AFRL              (PIN_AFIO_AF(GPIOC_ARD_A5, 0U) |        \
                                     PIN_AFIO_AF(GPIOC_ARD_A4, 0U) |        \
                                     PIN_AFIO_AF(GPIOC_PIN2, 0U) |          \
                                     PIN_AFIO_AF(GPIOC_PIN3, 0U) |          \
                                     PIN_AFIO_AF(GPIOC_PIN4, 0U) |          \
                                     PIN_AFIO_AF(GPIOC_PIN5, 0U) |          \
                                     PIN_AFIO_AF(GPIOC_PIN6, 0U) |          \
                                     PIN_AFIO_AF(GPIOC_ARD_D9, 0U))
#define VAL_GPIOC_AFRH              (PIN_AFIO_AF(GPIOC_PIN8, 0U) |          \
                                     PIN_AFIO_AF(GPIOC_PIN9, 0U) |          \
                                     PIN_AFIO_AF(GPIOC_PIN10, 0U) |         \
                                     PIN_AFIO_AF(GPIOC_PIN11, 0U) |         \
                                     PIN_AFIO_AF(GPIOC_PIN12, 0U) |         \
                                     PIN_AFIO_AF(GPIOC_BUTTON, 0U) |        \
                                     PIN_AFIO_AF(GPIOC_OSC32_IN, 0U) |      \
                                     PIN_AFIO_AF(GPIOC_OSC32_OUT, 0U))
 * GPIOD setup:
 * PD0  - PIN0                      (input pullup).
 * PD1  - PIN1                      (input pullup).
 * PD2  - PIN2                      (input pullup).
 * PD3  - PIN3                      (input pullup).
 * PD4  - PIN4                      (input pullup).
 * PD5  - PIN5                      (input pullup).
 * PD6  - PIN6                      (input pullup).
 * PD7  - PIN7                      (input pullup).
 * PD8  - PIN8                      (input pullup).
 * PD9  - PIN9                      (input pullup).
 * PD10 - PIN10                     (input pullup).
 * PD11 - PIN11                     (input pullup).
 * PD12 - PIN12                     (input pullup).
 * PD13 - PIN13                     (input pullup).
 * PD14 - PIN14                     (input pullup).
 * PD15 - PIN15                     (input pullup).
#define VAL_GPIOD_MODER             (PIN_MODE_INPUT(GPIOD_PIN0) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN1) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN2) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN3) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN4) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN5) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN6) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN7) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN8) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN9) |           \
                                     PIN_MODE_INPUT(GPIOD_PIN10) |          \
                                     PIN_MODE_INPUT(GPIOD_PIN11) |          \
                                     PIN_MODE_INPUT(GPIOD_PIN12) |          \
                                     PIN_MODE_INPUT(GPIOD_PIN13) |          \
                                     PIN_MODE_INPUT(GPIOD_PIN14) |          \
                                     PIN_MODE_INPUT(GPIOD_PIN15))
#define VAL_GPIOD_OTYPER            (PIN_OTYPE_PUSHPULL(GPIOD_PIN0) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN1) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN2) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN3) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN4) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN5) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN6) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN7) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN8) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN9) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN10) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN11) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN12) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN13) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN14) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOD_PIN15))
#define VAL_GPIOD_OSPEEDR           (PIN_OSPEED_HIGH(GPIOD_PIN0) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN1) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN2) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN3) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN4) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN5) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN6) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN7) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN8) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN9) |          \
                                     PIN_OSPEED_HIGH(GPIOD_PIN10) |         \
                                     PIN_OSPEED_HIGH(GPIOD_PIN11) |         \
                                     PIN_OSPEED_HIGH(GPIOD_PIN12) |         \
                                     PIN_OSPEED_HIGH(GPIOD_PIN13) |         \
                                     PIN_OSPEED_HIGH(GPIOD_PIN14) |         \
                                     PIN_OSPEED_HIGH(GPIOD_PIN15))
#define VAL_GPIOD_PUPDR             (PIN_PUPDR_PULLUP(GPIOD_PIN0) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN1) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN2) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN3) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN4) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN5) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN6) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN7) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN8) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN9) |         \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN10) |        \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN11) |        \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN12) |        \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN13) |        \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN14) |        \
                                     PIN_PUPDR_PULLUP(GPIOD_PIN15))
#define VAL_GPIOD_ODR               (PIN_ODR_HIGH(GPIOD_PIN0) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN1) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN2) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN3) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN4) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN5) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN6) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN7) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN8) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN9) |             \
                                     PIN_ODR_HIGH(GPIOD_PIN10) |            \
                                     PIN_ODR_HIGH(GPIOD_PIN11) |            \
                                     PIN_ODR_HIGH(GPIOD_PIN12) |            \
                                     PIN_ODR_HIGH(GPIOD_PIN13) |            \
                                     PIN_ODR_HIGH(GPIOD_PIN14) |            \
                                     PIN_ODR_HIGH(GPIOD_PIN15))
#define VAL_GPIOD_AFRL              (PIN_AFIO_AF(GPIOD_PIN0, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN1, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN2, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN3, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN4, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN5, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN6, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN7, 0U))
#define VAL_GPIOD_AFRH              (PIN_AFIO_AF(GPIOD_PIN8, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN9, 0U) |          \
                                     PIN_AFIO_AF(GPIOD_PIN10, 0U) |         \
                                     PIN_AFIO_AF(GPIOD_PIN11, 0U) |         \
                                     PIN_AFIO_AF(GPIOD_PIN12, 0U) |         \
                                     PIN_AFIO_AF(GPIOD_PIN13, 0U) |         \
                                     PIN_AFIO_AF(GPIOD_PIN14, 0U) |         \
                                     PIN_AFIO_AF(GPIOD_PIN15, 0U))
 * GPIOF setup:
 * PF0  - OSC_IN                    (input floating).
 * PF1  - OSC_OUT                   (input floating).
 * PF2  - PIN2                      (input pullup).
 * PF3  - PIN3                      (input pullup).
 * PF4  - PIN4                      (input pullup).
 * PF5  - PIN5                      (input pullup).
 * PF6  - PIN6                      (input pullup).
 * PF7  - PIN7                      (input pullup).
 * PF8  - PIN8                      (input pullup).
 * PF9  - PIN9                      (input pullup).
 * PF10 - PIN10                     (input pullup).
 * PF11 - PIN11                     (input pullup).
 * PF12 - PIN12                     (input pullup).
 * PF13 - PIN13                     (input pullup).
 * PF14 - PIN14                     (input pullup).
 * PF15 - PIN15                     (input pullup).
#define VAL_GPIOF_MODER             (PIN_MODE_INPUT(GPIOF_OSC_IN) |         \
                                     PIN_MODE_INPUT(GPIOF_OSC_OUT) |        \
                                     PIN_MODE_INPUT(GPIOF_PIN2) |           \
                                     PIN_MODE_INPUT(GPIOF_PIN3) |           \
                                     PIN_MODE_INPUT(GPIOF_PIN4) |           \
                                     PIN_MODE_INPUT(GPIOF_PIN5) |           \
                                     PIN_MODE_INPUT(GPIOF_PIN6) |           \
                                     PIN_MODE_INPUT(GPIOF_PIN7) |           \
                                     PIN_MODE_INPUT(GPIOF_PIN8) |           \
                                     PIN_MODE_INPUT(GPIOF_PIN9) |           \
                                     PIN_MODE_INPUT(GPIOF_PIN10) |          \
                                     PIN_MODE_INPUT(GPIOF_PIN11) |          \
                                     PIN_MODE_INPUT(GPIOF_PIN12) |          \
                                     PIN_MODE_INPUT(GPIOF_PIN13) |          \
                                     PIN_MODE_INPUT(GPIOF_PIN14) |          \
                                     PIN_MODE_INPUT(GPIOF_PIN15))
#define VAL_GPIOF_OTYPER            (PIN_OTYPE_PUSHPULL(GPIOF_OSC_IN) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOF_OSC_OUT) |    \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN2) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN3) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN4) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN5) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN6) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN7) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN8) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN9) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN10) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN11) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN12) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN13) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN14) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOF_PIN15))
#define VAL_GPIOF_OSPEEDR           (PIN_OSPEED_VERYLOW(GPIOF_OSC_IN) |     \
                                     PIN_OSPEED_VERYLOW(GPIOF_OSC_OUT) |    \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN2) |       \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN3) |       \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN4) |       \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN5) |       \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN6) |       \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN7) |       \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN8) |       \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN9) |       \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN10) |      \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN11) |      \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN12) |      \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN13) |      \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN14) |      \
                                     PIN_OSPEED_VERYLOW(GPIOF_PIN15))
#define VAL_GPIOF_PUPDR             (PIN_PUPDR_FLOATING(GPIOF_OSC_IN) |     \
                                     PIN_PUPDR_FLOATING(GPIOF_OSC_OUT) |    \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN2) |         \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN3) |         \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN4) |         \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN5) |         \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN6) |         \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN7) |         \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN8) |         \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN9) |         \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN10) |        \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN11) |        \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN12) |        \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN13) |        \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN14) |        \
                                     PIN_PUPDR_PULLUP(GPIOF_PIN15))
#define VAL_GPIOF_ODR               (PIN_ODR_HIGH(GPIOF_OSC_IN) |           \
                                     PIN_ODR_HIGH(GPIOF_OSC_OUT) |          \
                                     PIN_ODR_HIGH(GPIOF_PIN2) |             \
                                     PIN_ODR_HIGH(GPIOF_PIN3) |             \
                                     PIN_ODR_HIGH(GPIOF_PIN4) |             \
                                     PIN_ODR_HIGH(GPIOF_PIN5) |             \
                                     PIN_ODR_HIGH(GPIOF_PIN6) |             \
                                     PIN_ODR_HIGH(GPIOF_PIN7) |             \
                                     PIN_ODR_HIGH(GPIOF_PIN8) |             \
                                     PIN_ODR_HIGH(GPIOF_PIN9) |             \
                                     PIN_ODR_HIGH(GPIOF_PIN10) |            \
                                     PIN_ODR_HIGH(GPIOF_PIN11) |            \
                                     PIN_ODR_HIGH(GPIOF_PIN12) |            \
                                     PIN_ODR_HIGH(GPIOF_PIN13) |            \
                                     PIN_ODR_HIGH(GPIOF_PIN14) |            \
                                     PIN_ODR_HIGH(GPIOF_PIN15))
#define VAL_GPIOF_AFRL              (PIN_AFIO_AF(GPIOF_OSC_IN, 0U) |        \
                                     PIN_AFIO_AF(GPIOF_OSC_OUT, 0U) |       \
                                     PIN_AFIO_AF(GPIOF_PIN2, 0U) |          \
                                     PIN_AFIO_AF(GPIOF_PIN3, 0U) |          \
                                     PIN_AFIO_AF(GPIOF_PIN4, 0U) |          \
                                     PIN_AFIO_AF(GPIOF_PIN5, 0U) |          \
                                     PIN_AFIO_AF(GPIOF_PIN6, 0U) |          \
                                     PIN_AFIO_AF(GPIOF_PIN7, 0U))
#define VAL_GPIOF_AFRH              (PIN_AFIO_AF(GPIOF_PIN8, 0U) |          \
                                     PIN_AFIO_AF(GPIOF_PIN9, 0U) |          \
                                     PIN_AFIO_AF(GPIOF_PIN10, 0U) |         \
                                     PIN_AFIO_AF(GPIOF_PIN11, 0U) |         \
                                     PIN_AFIO_AF(GPIOF_PIN12, 0U) |         \
                                     PIN_AFIO_AF(GPIOF_PIN13, 0U) |         \
                                     PIN_AFIO_AF(GPIOF_PIN14, 0U) |         \
                                     PIN_AFIO_AF(GPIOF_PIN15, 0U))
#if !defined(_FROM_ASM_)
#ifdef __cplusplus
extern "C" {
  void boardInit(void);
#ifdef __cplusplus
#endif /* _FROM_ASM_ */
Is it actually correct? if your UART RX is not mapped correctly, or mapped twice then this could explain the problem.
robert_o
Post by robert_o »
I checked again. PA9 is USART1 TX and PA10 is USART1 RX and is only defined once.
Also i added
to main.c.
robert_o
Post by robert_o »
I just deleted the config in main.c and it still works which suggests the board.h is used.
I also checked the correct linked folder location and the board.mk - everything looks ok.
robert_o
Post by robert_o »
BTW: I am using Chibi Studio.
robert_o
Post by robert_o »
I've got it finally working.
After receiving my NUCLEO f030r8 i played around with the code and it worked immediatly. I used this as a starting point for the f030f4 board.
I ditched the registry and other entries i made and went with the f030f6 linker script and the type f030x6 in board.chcfg, i also removed every pin config from board.chcfg.
I also read the datasheet carefully and found out that the 030f4 doesn't have an USART2!
You can use PA2,3 OR PA9,10 for USART1!
The Problem was the pin configuration which i resolved with the following code.
    ChibiOS - Copyright (C) 2006..2015 Giovanni Di Sirio
#include "ch.h"
#include "hal.h"
#include "chprintf.h" //to get rid of compiler warnings
#include "stdlib.h" //to get rid of compiler warnings
#include "shell.h"
#define SHELL_WA_SIZE   THD_WORKING_AREA_SIZE(512)
  const char * const usage = "Usage: tst NUMBER\r\n";
  volatile uint16_t nr;
  if (argc != 1) {
    chprintf(chp, usage);
    return;
  nr = (uint16_t)atoi(argv[0]);
  chprintf(chp, "This is a Test\r\n");
  chprintf(chp, "You entered  : %i \r\n", nr);
  {"tst", cmd_tst},
  {NULL, NULL}
  commands
 * LED blinker thread, times are in milliseconds.
  (void)arg;
  while (true) {
int main(void) {
   *   RTOS is active.
  shellInit();
  // Pin config for Serial Driver 1
  palSetPadMode(GPIOA, 9,                 //USART1 TX
         PAL_MODE_ALTERNATE(1)    |
         PAL_STM32_OTYPE_PUSHPULL |
         PAL_STM32_PUPDR_PULLUP   |
         PAL_STM32_OSPEED_HIGHEST);
   palSetPadMode(GPIOA, 10,               //USART1 RX
  palSetPadMode(GPIOA, 4, PAL_MODE_OUTPUT_PUSHPULL);
  chprintf((BaseSequentialStream *)&SD1, "ChibiOS NUCLEO Shell v0.2\r\n");
  chThdSleepMilliseconds(100);
  chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO+1, Thread1, NULL);
  while (true) {
    if (!shelltp) {
              //shelltp = shellCreate(&shell_cfg1, SHELL_WA_SIZE, NORMALPRIO+10);
              shelltp = chThdCreateFromHeap(NULL, SHELL_WA_SIZE, "shell", NORMALPRIO+10, shellThread, (void *) &shell_cfg1);
         shelltp = NULL;
I used ChibiOS 17.6.
This means that the F030f4 requires a specific entry in the registry file or the USART2 would not have been allowed at compile time.
Moving this topic in "change requests".
Added STM32F030x4 support in registry, now the STM32F030x4 identifier is allowed in the board file.
