build Chibios Under Atollic Topic is solved
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Post by Tabulous »
Just wondered if anyone had done this ?
I.e. the New Atollic for STM32 and Chibios 16.1 ?
Tabulous
Re: build Chibios Under Atollic
Post by Tabulous »
it builds but it gets linkers errors, note this project builds fine in chibistudio.
Linking build/debug/t7_app.elf
c:/program files (x86)/atollic/truestudio for stm32 9.0.0/armtools/bin/../lib/gcc/arm-atollic-eabi/6.3.1/../../../../arm-atollic-eabi/bin/ld.exe: section .test VMA [2001fffc,2001ffff] overlaps section .heap VMA [2001df1c,2001ffff]
c:/program files (x86)/atollic/truestudio for stm32 9.0.0/armtools/bin/../lib/gcc/arm-atollic-eabi/6.3.1/../../../../arm-atollic-eabi/lib/armv7e-m\libc.a(lib_a-mallocr.o): In function `_malloc_r':
mallocr.c:(.text._malloc_r+0x408): undefined reference to `malloc_getpagesize_P'
mallocr.c:(.text._malloc_r+0x410): undefined reference to `malloc_getpagesize_P'
c:/program files (x86)/atollic/truestudio for stm32 9.0.0/armtools/bin/../lib/gcc/arm-atollic-eabi/6.3.1/../../../../arm-atollic-eabi/lib/armv7e-m\libc.a(lib_a-freer.o): In function `_malloc_trim_r':
mallocr.c:(.text._malloc_trim_r+0xa8): undefined reference to `malloc_getpagesize_P'
make: *** [build/debug/t7_app.elf] Error 1
It looks like a customized compiler and library.
Tabulous
Post by Tabulous »
Yeah looks like it is. I copy over the files from Chibistudio and got it to compile ok.
If you can use the GCC provided by ARM then the rest of the environment should be OK, Eclipse basically.
Personally I prefer to avoid being bound by specific environments, ChibiStudio is an assembly of "standard" parts.
crispus
Has thanked: 4 times
Been thanked: 3 times
Re: build Chibios
Post by crispus »
I have a similar issue while trying to compile for STM32H743ZIT6
/usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/bin/ld: section .rodata VMA [0000000008008e90,0000000008009e77] overlaps section .text VMA [00000000080002c0,0000000008008eab]
I am using command line (Debian testing) with the Makefile from ChibiOS example (nucleo board). The difference is that I have some c++ files.
I use same Makefile (with the appropriate linker/headers/etc changes) to compile it for STM32F767ZIT6 and it works.
$ .vfp11_veneer   0x0000000008008eac        0x0 load address 0x0000000008008e90
.v4_bx          0x0000000008008eac        0x0 load address 0x0000000008008e90
.iplt           0x0000000008008eac        0x0 load address 0x0000000008008e90
.rodata         0x0000000008008e90      0xfe8
                0x0000000008008e90                __rodata_base__ = .
 .rodata        0x0000000008008e90        0x4 /usr/lib/gcc/arm-none-eabi/6.3.1/../../../arm-none-eabi/lib/thumb/v7e-m/libg.a(lib_a-impure.o)
                0x0000000008008e90                _global_impure_ptr
.text           0x00000000080002c0     0x8bec load address 0x00000000080002a4
                0x00000000080002c0                __text_base = .
 .text          0x00000000080002c0       0xd8 build_STM32H743ZIT6/obj/crt0_v7m.o
                0x00000000080002c0                _crt0_entry
I used two version of compilers: 6.3.1 and 7.3.1
L.E: I checked, same flags are used in both variations, same flags on nucleo H7 board example.
 -mcpu=cortex-m7 -mthumb -O0 -ggdb -fomit-frame-pointer -falign-functions=16 -Werror  -ffunction-sections -fdata-sections -fno-common -flto -nostartfiles  -Wl,-Map=build_STM32H743ZIT6/xxx.map,--cref,--no-warn-mismatch,--library-path=./os/common/startup/ARMCMx/compilers/GCC/ld,--script=./os/common/startup/ARMCMx/compilers/GCC/ld/STM32H743xI.ld,--gc-sections,--defsym=__process_stack_size__=0x400,--defsym=__main_stack_size__=0x400
What compiler are you using?
Those in distro repositories are known to NOT work.
crispus
Post by crispus »
Latest version from dev.arm.com: GNU Arm Embedded Toolchain Version 7-2018-q2-update (7.3.1) and 6.3.1 from debian repo.
Since STM32H7 is M7 I didn't expected to have an compiler/linker problem...
Same, I doubt that the problem is the device, there is something in the project. You may try excluding parts.
crispus
Post by crispus »
It seems that is coming from C++ stuff (commenting cpp out it will compile). I have nothing fancy/complex, just 2 classes.
On same configuration STM32F767 compiles just fine.
include $(CHIBIOS)/os/various/cpp_wrappers/chcpp.mk
