Some useful GDB scripts
faisal
Has thanked: 45 times
Been thanked: 62 times
Post by faisal »
Prints out the trace buffer. I found this online somewhere, and fixed a bug it had to make it actually print the entire circular buffer:
set $buflen = ch.dbg.trace_buffer.size
set $i=ch.dbg.trace_buffer.ptr-ch.dbg.trace_buffer.buffer-1
if $i < 0
    set $i = $buflen-1
end
set $ctr=0
while (ch.dbg.trace_buffer.buffer[$i].type != 0) && ($ctr < ($buflen-1))
   printf "%d,t=%d,rt=%d ", $ctr, ch.dbg.trace_buffer.buffer[$i].time, ch.dbg.trace_buffer.buffer[$i].rtstamp
   if ch.dbg.trace_buffer.buffer[$i].type == 1
        echo \ SWITCH \
        output ch.dbg.trace_buffer.buffer[$i].u.sw
    end
    if ch.dbg.trace_buffer.buffer[$i].type == 2
        echo \ ISR_ENTER \
        output ch.dbg.trace_buffer.buffer[$i].u.isr
    end
    if ch.dbg.trace_buffer.buffer[$i].type == 3
        echo \ ISR_LEAVE \
    end
    if ch.dbg.trace_buffer.buffer[$i].type == 4
        echo \ HALT \
        output ch.dbg.trace_buffer.buffer[$i].u.halt
    end
    if ch.dbg.trace_buffer.buffer[$i].type == 5
        echo \ USER \
        printf "%s,%s",(char*)ch.dbg.trace_buffer.buffer[$i].u.user.up1,(char*)ch.dbg.trace_buffer.buffer[$i].u.user.up2
    end
    echo \n
    if ($i == 0)
        set $i = $buflen-1
    else
        set $i = $i-1
    end
    set $ctr = $ctr + 1
end
Prints out all of the virtual timers:
printf "Virtual Timers\n"
set $ctr = 0
set $p = ch.vtlist.next
while $p != &ch.vtlist
    printf "%d\tt=%d\tpar=0x%08x\tfunc= ", $ctr, $p->delta, $p->par
    output $p->func
    echo \n
    set $ctr = $ctr + 1
    set $p = $p->next
end
Other debug info, and available stack for all threads (excluding main):
printf "Debug Info\n"
printf "isr_cnt=%d\tlock_cnt=%d\ttm_cal=%d\tpanic=", ch.dbg.isr_cnt, ch.dbg.lock_cnt, ch.tm.offset
output ch.dbg.panic_msg
echo \n\n
printf "Thread stack used\n"
set $filler = 0x5555555555555555
set $max_stack_size = 0xFFFF
set $tp = ch.rlist.newer
set $ctr = 0
while $tp != &ch.rlist
    printf "%d, %s, ", $ctr, $tp->name
    output $tp->wabase
    if strcmp($tp->name, "main") != 0
        set $unused = 0
        set $stk_ptr = (uint64_t *)$tp->wabase
        while (*$stk_ptr == $filler) && ($unused < $max_stack_size)
            set $stk_ptr = $stk_ptr + 1
            set $unused = $unused + sizeof(uint64_t)
        end
        printf ", unused stack = %d", $unused
    end
    echo \n
    set $ctr = $ctr + 1
    set $tp = $tp->newer
end
Re: Some useful GDB scripts
Never used GDB directly this way, it looks very interesting. It would be nice to have some kind of console in Eclipse with a way to launch scripts from a collection.
faisal
Post by faisal »
Giovanni wrote:Hi,
Yeah, necessity is the mother of invention ... I'm unable to use the ChibiOS eclipse debug plugin as I'm running Eclipse Neon.
You can launch the scripts from the debugger console by typing "source <path to script>"
