build Chibios Under Atollic Topic is solved
crispus
Has thanked: 4 times
Been thanked: 3 times
Re: build Chibios Under Atollic
Post by crispus »
Using F7 linker scripts it will compile (at least).
So, I was comparing the linker scripts for H7 and F7 and I see that flash0 anf flash1 although point to the same thing (?) they have different addresses, but not for H7 (bank1+bank2 vs bank1).
    H7
    flash0  : org = 0x08000000, len = 2M        /* Flash bank1+bank2 */
    flash1  : org = 0x08000000, len = 1M        /* Flash bank 1 */
    flash2  : org = 0x08100000, len = 1M        /* Flash bank 2 */
    flash3  : org = 0x00000000, len = 0
    vs F7
    flash0  : org = 0x08000000, len = 2M        /* Flash as AXIM (writable) */
    flash1  : org = 0x00200000, len = 2M        /* Flash as ITCM */
The issue seems to be here:
/* Flash region to be used for exception vectors.*/
REGION_ALIAS("VECTORS_FLASH", flash1);
REGION_ALIAS("VECTORS_FLASH_LMA", flash0);
If I change flash1 to flash0 the problem is fixed (aka linker error), if I put flash1 len = 0, the linker will complain that the .vector section won't fit.
Moving this in bug reports, I think it is related to another bug already reported.
crispus
Post by crispus »
TWIMC: As a workaround, replacing flash1 with flash0 on each alias compiles and works ok (on ST-Nucleo-H743ZI)
$ svn diff
Index: os/common/startup/ARMCMx/compilers/GCC/ld/STM32H743xI.ld
--- os/common/startup/ARMCMx/compilers/GCC/ld/STM32H743xI.ld    (revision 12278)
+++ os/common/startup/ARMCMx/compilers/GCC/ld/STM32H743xI.ld    (working copy)
@@ -49,15 +49,15 @@
    and a load region (_LMA suffix).*/
-REGION_ALIAS("VECTORS_FLASH", flash1);
+REGION_ALIAS("VECTORS_FLASH", flash0);
 /* Flash region to be used for constructors and destructors.*/
-REGION_ALIAS("XTORS_FLASH", flash1);
+REGION_ALIAS("XTORS_FLASH", flash0);
 REGION_ALIAS("XTORS_FLASH_LMA", flash0);
 /* Flash region to be used for code text.*/
-REGION_ALIAS("TEXT_FLASH", flash1);
+REGION_ALIAS("TEXT_FLASH", flash0);
 REGION_ALIAS("TEXT_FLASH_LMA", flash0);
 /* Flash region to be used for read only data.*/
@@ -65,7 +65,7 @@
 REGION_ALIAS("RODATA_FLASH_LMA", flash0);
 /* Flash region to be used for various.*/
-REGION_ALIAS("VARIOUS_FLASH", flash1);
+REGION_ALIAS("VARIOUS_FLASH", flash0);
 REGION_ALIAS("VARIOUS_FLASH_LMA", flash0);
 /* Flash region to be used for RAM(n) initialization data.*/
bump
Fixed as bug #998 exactly as described.
