How to properly pass argument to palSetPadCallback's callback? Topic is solved
Moderators: utzig, lbednarz, tfAteba, barthess, RoccoMarco
ceremcem
Has thanked: 7 times
Been thanked: 6 times
Postby ceremcem » Thu Jun 20, 2019 9:30 am
I have a function which takes the button_number as an argument and decides the action according to the button_number. My button setup is as follows:
    // forward button
    palSetPadMode(GPIOA, UPWARD_BUTTON, PAL_MODE_INPUT);
    palEnablePadEvent(GPIOA, UPWARD_BUTTON, PAL_EVENT_MODE_BOTH_EDGES);
    palSetPadCallback(GPIOA, UPWARD_BUTTON, button_callback, UPWARD_BUTTON);
    // backward button
    palSetPadMode(GPIOA, DOWNWARD_BUTTON, PAL_MODE_INPUT);
    palEnablePadEvent(GPIOA, DOWNWARD_BUTTON, PAL_EVENT_MODE_BOTH_EDGES);
    palSetPadCallback(GPIOA, DOWNWARD_BUTTON, button_callback, DOWNWARD_BUTTON);
My handler function is as follows (just FYI):
void button_callback(uint8_t pad){
    bool state = ! palReadPad(GPIOA, pad);
    if (pad == UPWARD_BUTTON){
        UPWARD_button(state);
    } else {
        DOWNWARD_button(state);
Problem
This code works as intended. However, compiler throws the following warning:
/home/aea/sw2/app/io.c:64:64: note: in expansion of macro 'DOWNWARD_BUTTON'
/home/aea/ChibiOS/os/hal/include/hal_pal.h:967:8: note: expected 'void *' but argument is of type 'int'
   void palSetPadCallbackI(ioportid_t port, iopadid_t pad,
How can I properly pass the BUTTON_NUMBER as an argument to the handler function (button_callback)?
Has thanked: 888 times
Been thanked: 768 times
Re: How to properly pass argument to palSetPadCallback's callback?  Topic is solved
Postby Giovanni » Thu Jun 20, 2019 9:33 am
By casting it to (void *).
ceremcem
Postby ceremcem » Thu Jun 20, 2019 12:31 pm
Now all warnings are vanished. Here is my changes:
I changed my handler function from:
to:
void button_callback(void * _pad){
    uint8_t pad = *((uint8_t *) _pad);
and palSetPadCallback() invocation from
to:
    uint8_t _DOWNWARD_BUTTON = DOWNWARD_BUTTON;
    palSetPadCallback(GPIOA, DOWNWARD_BUTTON, button_callback, (void *) &_DOWNWARD_BUTTON);
Return to “General Support”
