Virtual Timers
Moderators: tfAteba, barthess, RoccoMarco, lbednarz, utzig
levrik
Virtual Timers
Postby levrik » Sat May 05, 2012 9:47 am
Hi there,
I'm having problems implementing a RX-timeout with Virtual timers:
1. Is there a way to implement the vt-callback not in a IRQ-context?
2. Is there a way to reset the timer before it reaches its end to implement a timeout?
Momentarily i've implemented it this way:
if( chVTIsArmedI( &rfmp->vt ) )
      chSysLock();
      chVTResetI( &rfmp->vt );
      chVTSetI( &rfmp->vt, MS2ST(msec), vtmr_cb, rfmp );
      chSysUnlock();
This code does not work for me properly, because sometimes it seems, that the vt does not start. Looking into the vt-structure with a debugger shows that it contains a valid vt->vt-time, a valid vt->vt_func and a valid vt->vt_par, but the callback does not get called. Any hints?
Thanks in advance.
Has thanked: 1146 times
Been thanked: 960 times
Re: Virtual Timers
Postby Giovanni » Sat May 05, 2012 9:59 am
1) Not directly, you can wakeup a thread from there, then do processing from the thread. Alternatively you can use an "Event Timer" see under ./os/various.
2) Yes, it is done in several places, see the function chSchGoSleepTimeoutS() for an example.
You code is failing because before resetting a timer you have to check if it is armed. See the example:
  chSysLock();
  if (chVTIsArmedI(vtp))
    chVTResetI(vtp);
  chSysUnlock();
levrik
Re: Virtual Timers
Postby levrik » Mon May 07, 2012 3:11 pm
Hi Giovanny,
thank you for your answer. It works now with code similar to the example you've presented.
But i do not understand why the first version did not work, because there the timer was also checked if armed before it was reset.
Kind regards.
Re: Virtual Timers
Postby Giovanni » Mon May 07, 2012 3:26 pm
Because chVTIsArmedI() was called outside the lock, the whole operation is not atomic. The timer could expire after chVTIsArmedI() and before chVTResetI().
That "sometime", was a clear hint about a race condition somewhere.
Chudik
Has thanked: 7 times
Re: Virtual Timers
Postby Chudik » Fri Mar 06, 2015 5:03 am
Have a problem with sending data through SPI in Virtual Driver header. Symptoms are as same as I had when I just started to work with SPI and used wrong driver. Can't figure out how to solve it.
Shortly, what I need. I'm using OLED display in my design and since it has limited time of life, I want to switch off the display. So, after showing text on the display, I want to switch on the display, run virtual timer, dim the display after 1 sec and switch off after the next 1 sec.
Here is part of my code
uint8_t dt_data[2];
void  hDisplayTimer(void *arg);
static uint8_t  DisplayState = DISPLAYOFF;
static struct VirtualTimer DisplayTimer;
void UI_Send(ui_msg *msg, uint8_t *data, int cnt, ...)
   va_list ap;
   uint8_t i, checkcmd = 0, tag;
   int indata;
   uint32_t address;
   va_start(ap,cnt);
   indata = va_arg(ap, int);
   msg->tag = (uint8_t)indata;
    tag = msg->tag;
   switch (tag)
   chMsgSend(UI_Console,(msg_t)msg);
   if(tag==DISPLAY_TXT)
         DisplayState = DISPLAYON;
         dt_data[0] = DISPLAY_CMD;
         dt_data[1] = DisplayState;
         spiAcquireBus(&SPID2);
         spiStart(&SPID2, &display_cfg);
         UISendData(&SPID2, 2, dt_data);      //  <<<--- here it works without any problem
         spiReleaseBus(&SPID2);
         chVTSet(&DisplayTimer, S2ST(1), hDisplayTimer, NULL);
    switch(DisplayState)
        case DISPLAYON:  DisplayState = DISPLAYDIM;
                         break;
        case DISPLAYDIM: DisplayState = DISPLAYOFF;
                         break;
        case DISPLAYOFF:
        default:         DisplayState = DISPLAYOFF;
                         break;
         UISendData(&SPID2, 2, dt_data); //  <<<--- here it does not work, data sent to SPI, but can't get back from this function
         chSysLockFromIsr();
         chVTSetI(&DisplayTimer, S2ST(1), hDisplayTimer, NULL);
         chSysUnlockFromIsr();
Probably it happens because I send data to SPI from the timer interrupt handler (is it true?). So I tried to use chSysLockFromIsr() instead of chSysLock() (used in SPISend() anyway). It did not help.
What would be the solution for that?
And another problem related to that. Why after I ran the timer it calls the handler immediately, without actual waiting for one second? I watch window I see the values. Not sure that 0x205 (517d) is correct value for 1 second, though.
CH_FREQUENCY defined as 1000
skute
Re: Virtual Timers
Postby skute » Fri Mar 06, 2015 5:35 am
Chudik wrote:Have a problem with sending data through SPI in Virtual Driver header. Symptoms are as same as I had when I just started to work with SPI and used wrong driver. Can't figure out how to solve it.
uint8_t dt_data[2];
   va_list ap;
   int indata;
   uint32_t address;
   va_start(ap,cnt);
    tag = msg->tag;
   switch (tag)
                         break;
                         break;
        case DISPLAYOFF:
                         break;
         chSysLockFromIsr();
Chudik,
It's likely that the SPI driver uses interrupts and you are blocking them from happening because you are attempting a SPI transfer from an interrupt handler. However, even more incorrect is that you are calling spiAcquireBus from the timer interrupt handler because this will attempt to acquire a mutex and "block" the ISR if the mutex isn't available and cause an exception. As Giovanni always asks, please enable the state checker as it would catch these errors.
Chudik
Re: Virtual Timers
Postby Chudik » Fri Mar 06, 2015 10:21 am
Of course, my mistake was with setting the time - 1 min, not 1 second.
So, the last question in my previous post is not a problem,
However, all the other stuff is valid. When I try to send data to SPI from the handler, the system gets into _unhandled_exception() and stuck in there.
Chudik
Re: Virtual Timers
Postby Chudik » Fri Mar 06, 2015 10:31 am
skute wrote:It's likely that the SPI driver uses interrupts and you are blocking them from happening because you are attempting a SPI transfer from an interrupt handler.
Yes, it is correct statement. However, in my original version I was trying to send message to my UI_ConsoleServer with the same result. After that happened I decided to try such direct attempt.
I will try tomorrow to change it back to sending message to be sure that I get the same problem
skute wrote:As Giovanni always asks, please enable the state checker as it would catch these errors.
How to enable it?
Re: Virtual Timers
Postby Giovanni » Fri Mar 06, 2015 11:32 am
See the debug section in chconf.h, I recommend enabling assertions, checks and state checker during development. It stops your application in case of errors then inspect the global variable dbg_panic_msg, it points to an error message in memory.
Chudik
Re: Virtual Timers
Postby Chudik » Fri Mar 06, 2015 8:45 pm
OK, got panic message
SV#4, misplaced @p chSysLock().
Traced the program. Got this message in chMsgSend() (chmsg.c)
Line 80. Calling chSysLock()
Do I need to show where chMsgSend() called from?
Return to “General Support”
Users browsing this forum: No registered users and 12 guests
