problem with frequent call of chIOGetTimeout( )
levrik
Post by levrik »
I'm a bit embarrassed asking so many questions. But there another phenomenon bothering me for which i cannot find the answer alone:
I've implemented a serial driver which puts data comming from SPI-based RF-module into an input-queue via chIQPutI() and makes it available via the serialDriver interface:
static msg_t gett( void *ip, systime_t timeout )
  return chIQGetTimeout( &( ( SerialDriver * ) ip )->iqueue, timeout );
In my code the following line gets very frequently called:
uint8_t pocketbus_recv(struct PocketBusCtx *ctx, struct PocketMsg *msg)
   int data;
   uint8_t c;
   while( (data = chIOGetTimeout( ctx->fd, MS2ST(50) )) >= Q_OK )
              /* Process incoming characters while buffer is not empty */
              // returns 1 if valid telegram
             // if errors occur (crc-error, length error etc.) the loop continues
             return 0;
Calling thread:
static WORKING_AREA(waThread2, 512);
static msg_t Thread2(void *arg)
  (void)arg;
  uint8_t rec;
  chRegSetThreadName("Pocket-RX");
  for(;;)
    rec = pocketbus_recv(&busCtrlRfm, &msg);
    palSetPad(GPIOD, LED_RED);
    if( rec == 1 )
      chprintf((BaseChannel *)&SD2, "payload: %s lenght: %d \n\r", msg.payload, msg.len);
    palClearPad(GPIOD, LED_RED);
    //chThdSleepMilliseconds(200); // uncomment to delay the described phenomenon
  return 1;
If the first telegram passes, the function pocketbus_recv returns with 1, but after calling it again it delivers garbage without any real incoming data! The input-queue is empty at this point, but chIOGetTimeout delivers something and doesn't stop. If i pause the program via debugger the input-queue shows a q_counter of zero. After resuming the program, this thread receives one telegram correctly and after that garbage again. If i put a chThdSleepMilliseconds(xxx) into the calling thread the phenomenon takes much longer to appear (10 - 15 min).
Is chIOGetTimeout( ) not meant to be called frequently?
Thanks for hints.
P.S.
Hardware STM32F4-Discovery, ChibiOS latest trunk.
Re: problem with frequent call of chIOGetTimeout( )
Is chIQPutI() invoked within a lock? in general make sure to enable the debug options in chconf.h, the state checker can catch most or this kind of errors. Be careful with I-Class functions.
That "often" also hints to a race condition somewhere :-)
Also, probably you should not use the Serial interface but extend/implement the BaseAsynchronousChannel interface.
levrik
Post by levrik »
chIQPutI() is invoked within a locked section, the debug-options are enabled and the state checker does not halt the system.
That is my thought also. But due lack of extended ChibiOS experience i do not know where to begin the search.
Why do you recommend that?
Could you try using -O0 while compiling? Is the result the same?
levrik
Post by levrik »
Sorry for not mentioning:
During debugging i use always -O0. So the described phenomenon was already compiled with -O0.
I should look at the whole code, "remote debug" didn't work. Alternatively you could create a test case that I can run for debug.
levrik
Post by levrik »
I've attached the project (without ChibiOS).
Thank you very much for your help.
The only problems I found so far: In prvRFM12XChangeI() a normal API is called inside a lock (Iclass functions can only call Iclass). Not a problem except that you do polling with interrupts disabled from an ISR.
I don't have an explanation yet for the apparent queue corruption.
levrik
Post by levrik »
i've managed to solve the issue: The reason for this phenomenon was defective hardware. The RF-Module was continously throwing rx-interrupts even if no data was incomming via RF and the MCU put the delivered garbage into the queue. Due lack of Oscilloscope it took some time to debug this by LED-output. Sorry for the noise and thanks for your help.
mabl
Post by mabl »
levrik wrote:Due lack of Oscilloscope it took some time to debug this by LED-output.
You know that Logic Analyzer are super cheap these days? The Open Workbench Logic Sniffer is only 50$ and there are also other options: viewtopic.php?f=8&t=228
:D :mrgreen:
